Old 05-30-2026, 10:49 AM
cmoc-bob cmoc-bob is online now
Default Mahle PowerPac pistons - new ?
Saw this in Engine Builder magazine, just happened
to see what they had for Pontiac.
Our 400 sized pistons are listed under the "Big Block 455" PDF.
Coated, 2 forgings available, thin low drag rings.
https://www.us.mahle.com/media/usa/m...bp-webpage.pdf
Old 05-30-2026, 11:26 AM
From Mahle.
POWERPAK feature includes:
Forged piston for performance applications
Fully-machined crown
GRAFAL anti-Friction coating on skirts*
Phosphate-coated to reduce micro-welding and pin galling**
Pin bores finished on CNC boring equipment
Hand deburred
High-strength steel pins
Race-proven round wire locks
Low-drag ring pack
Light weight slipper skirt forgings
* MAHLE’s GRAFAL skirt coating reduces drag, scuffing, friction and cylinder bore wear and piston noise.
** Phosphate coating provides the grey appearance to the MAHLE piston. This dry lubricant coating (not to be confused with a thermal film coating) provides a lubricant film in the pin bores and ring grooves until the oiling system of the engine reaches operating pressure; particularly useful during the initial start-up or break-in of engines to protect against galling and microwelding. The piston crown is still machineable.
Old 05-30-2026, 11:31 AM
firechickenman's Avatar
firechickenman firechickenman is offline
I went with Mahle pistons for my 520. They were a custom order and sold as a Power Pac with pins, locks and rings. All very nice pieces in my opinion. The custom order was fairly easy with a lot of help from one of their sales associates.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
The Following User Says Thank You to firechickenman For This Useful Post:
Old 05-30-2026, 12:38 PM
performerrpm's Avatar
i have a set of those that came with a 467 stroker short block kit i bought off market place. they seem to be a nice piston, i havent assemble that motor to know yet
Old 05-30-2026, 01:52 PM
Here's a few pics of mine.
ID:	671131   Click image for larger version
ID:	671132   Click image for larger version
Greg Weigart
