68 69 70 71 72 Lemans GTO Horn Relay --Delco-Remy
Real GM firewall mounted horn relay--clean-- tested working-- $45 plus shipping from CT 06410. email [email protected] or call 203-651-9990. Enjoy real GM quality and fit I have lots of nice 68-72 parts--www.ros6872parts.com. Contact me with needs-- thanks for looking! |
Still available
Still available
Still available
Still availablle
Still available
Still available
Still available
Still available
Still available
Still available
Still available
Does the Buzzer still work while the key is left in the ignition in the off postion?
color me gone |
Its not a horn buzzer |
Horn Relay is the buzzer.
Relay should have four wires; Red - Battery Black - Horns Green - Horn Switch Pink - Key switch The other side of the column key switch goes to the drivers door jamb switch * See: Getting Key Buzzer Working : 02-02-2026 for more information
color me gone |
Oh--Ok-- makes sense since there are 4 spade lugs on this
I assume the buzzer works as it should but that is untested |
| The Following User Says Thank You to ros6872 For This Useful Post: | ||
Still available
