Old 05-30-2026, 06:49 PM
SD455DJ SD455DJ is offline
Default Proto-Systems, Inc. "Hoodscoop Kit"???
Anyone ever see, or heard of, or have one of these electric solenoid operated flapper systems in their shaker? We're looking at a nice '78 180 hp L78 TA that has one installed, probably back in the early 1980's. Here are the installation instructions.
The flapper door is inset about an inch from the rear opening and looks to be bent metal sheet painted matt black hinged from the top. I didn't get any pictures of it, unfortunately.
Dennis
ID:	671137   Click image for larger version
ID:	671138   Click image for larger version
Old 05-31-2026, 10:15 AM
There were a few out there. 81 Z28 also had one with a switch on the accelerator pedal like a TH400 kickdown
Old 05-31-2026, 11:06 AM
Thanks Skip! Actually, this has a sliding door, not top hinged. The door moves forward to open, back to close.
Dennis
Name:	Ptoto Sys '78 TA Open Scoop.jpg
ID:	671146   Click image for larger version
Name:	Proto Sys Solenoid 1.jpg
ID:	671147   Click image for larger version
Name:	Proto Sys Solenoid 2.jpg
Old 06-06-2026, 01:19 PM
The 81 Z8 metal pedal bracket had a sliding switch on it. Not sure if they repop the TH400 ones for an F body.
Old 06-08-2026, 07:14 PM
jerry455 jerry455 is offline
1980 and 1981 had the opening scoop. I used to own a 1980 back in 1981. I bought a THM 400 kickdown bracket for my 1976 Firebird, when my 400 trans gets finished. It was the same bracket for the cowl induction Chevelle. It seemed a common bracket for the accel pedal.
