#1961
Car Show Continued: A few Third Gen cars were there as well, with one in full "Kit" makeup. A couple of early GTOs showed too. All in all, a good group in about 150 cars that were there. June 6th is the big one in downtown Arlington, TX.
#1962
Well, if three 2 barrels are good (TriPower), then six should be outstanding, right?
This is a real Pontiac "Six-Pack". Wieand Drag Star. For those in the know- it's a 1955-60 intake. Rather than modify it for late model heads- it's going on top of a 1959 389. Won't be the first time I've built a whole new car around a set of carburetors. (then replaced the carburetors). Not sure what the body style the engine will go into just yet. TBD. An early coupe, no hood. And some body lines & tail lights that appeal to me. That's all I have for a concept so far.
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI Weiand Dragstar with 6 Strombergs 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) |
| The Following 8 Users Say Thank You to 3X24SPD For This Useful Post: | ||
#1963
Fabricated some prototype actuation linkage for the Bug Catcher, and a throttle return.
Works great. The mockup 3D Printed Bracket will be replaced by 4" 6061 Angle as soon as I get done machining it- and the temporary 12" 1/4" steel rod will be replaced with SS & Heims. The temporary Weber 4" 5mm Heim linkage will also be replaced with 1/4" SS & Heims as well, soon as those parts arrive. Replaced the 3D Printed Bellcrank yesterday- with one from Ron's FI that arrived yesterday.
| The Following 9 Users Say Thank You to 3X24SPD For This Useful Post: | ||
#1964
Replaced the repro 1/4 panel GTO decals with a set of NOS decals. Big difference in the weight and crispness of the letters! NOS on the bottom.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
#1965
Drove it to a local cruise night. Beautiful weather for checking out some classics!
Design Engineer | Dakota Digital 1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras |
#1966
Monday I used our survivor 59k mile now 60K mile 66 Star Chief Executive sedan to kick off the Pole Barn Garage Poverty Tour 2026 to cruise Route 66 and did first Day 1 of a week long torture test but went back home for work. It was flawless just hot for me not the car it was fine and drove around 900 miles in a day and a half . Didn't even use any oil ! https://www.youtube.com/watch?v=N1xlCtKnzP4&t=305s
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a 66 Star Chief Executive 59k mile 389 67 IH Scout project 2WD "Indian Scout" 69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2008 Saab 9-3 2.0T convertible |
| The Following 8 Users Say Thank You to PONTIAC LARRY For This Useful Post: | ||
#1967
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#1968
Spent Saturday reinstalling a freshened up headliner in the Ventura then cleaning up and doing a health check on the GTO. I ordered headliner material for the Ventura from SMS about a year and a half ago...still MIA . I busted out the Krylon Satin Italian Olive again. Sounds like a bad idea, but it actually looks pretty decent if you later it on in thin coats.
GTO is doing well, everything under the valve covers looks like the way I left it. I have been chasing a drooping passenger side headlight door which is driving me nuts. Adjusted the spring tension, arm to door position, replaced a check valve, 1/2 the vacuum lines, a vacuum actuator and the headlight switch and it still sags when the car is off. This is new since it got back from the body shop. I have no idea what could have happened but it's annoying. Got it working well enough to attend a show on Sunday with Cole.
#1969
Started bleeding the brakes on my 67 GTO. Car has been sitting for several years now so I used a pressure bleeder and found multiple leaks. Fixed all but one.....at the front distribution block which will require removal of the booster, master cyl. to get to. Ugh.
My money talks to me-it usually says goodbye! |
| The Following 3 Users Say Thank You to carcrazy For This Useful Post: | ||
#1970
#1971
Finished fabricating my one off throttle cable for my dual quad setup. Required cutting, fitting and creating a new end with solder. Ended up being about 6” shorter that when I bought it in order to fit my dual quad setup.
1964 Tempest Custom 421 SD clone KRE 74cc heads KRE 230°/236° hydraulic roller cam Rebuilt 3.23 rear end |
#1972
And here it is installed. You can see how the bracket is moved rearward. Still tried to go for a stock type look.
1964 Tempest Custom 421 SD clone KRE 74cc heads KRE 230°/236° hydraulic roller cam Rebuilt 3.23 rear end Last edited by tempest1964; 06-12-2026 at 01:39 PM. |
#1973
Covered the 63 Lemans after 4 week ends of car shows,put it on the lift and lowered the 62 GP for a AM show in the morning.Nice not having to work on them.Tom
#1974
FINALLY got the ‘55 Catalina out of upholstery jail today! It was done a few weeks ago, but between my schedule and all the rain we’ve had, this was the first chance I’ve had to run down to Illinois to get it picked up.
Hope the link works. I took a short video. https://m.youtube.com/watch?v=-8AYLyQUmyU
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride Last edited by 67drake; 06-12-2026 at 06:18 PM. |
#1975
Super interior!!!
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
| The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
#1976
Wow, really nice!
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles |
| The Following User Says Thank You to Skidmark For This Useful Post: | ||
#1977
It was trim day on the 2+2. Cleaned two different colors of paint off of some ebay beltline moldings and buffed them out. Had fun getting to all of the backsides of the clips to get nuts on them. Stripped, painted, and installed the rear seat fill panels to match the original Blue Charcoal. re-stretched the headliner and put the A-pillar and windshield trim in.
Next is the sail panels and rear window moldings. I looked at what it will take to replace some rear seat bottom springs, but the frame is too far gone.
65 Catalina 2+2, 455, 6x-8, 2802, 4-spd 65 Catalina 4dr Hardtop, 389 4v, Auto |
#1978
Nice day for a change here in SW Wisconsin. I was itching to drive so I took the ‘55 and my son took his ‘71 to grab a bite to eat in a town about 25 miles away.
Called my engine guy today too. Dropping my 400 off next weekend for him to deal with and assemble. My wife wants me to get the ‘63 running again so she can have her own car to run around in. Yeah, I have kinda been dragging my feet on that one.
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
#1979
Went to buddies logging operation on Youngstown Ridge near Latrobe. Reason he told me Friday he has a Ford 750 .I got the hood scoop for my 63 Lemans. I cut the truck hood all around the scoop now bolts are soaking in penetrate. It looks just needs sanded grille is with it. I had force $20.00 on him. We go back maybe 40 years.Working at his home, his sisters,bought a lot of rough cut lumber from him. I have dome rough cut pine stored in garage ,it is not warped.
#1980
Bled the brakes on my '64 and slapped the new rubber on.
Next: replace broken accel linkage and get ready to drop the 389 back in. |
