Old 05-19-2026, 02:49 PM
RAIIIJudge's Avatar
RAIIIJudge RAIIIJudge is offline
Nice, Scott! Interesting the negligible hp/tq differences between headers and R.A.R.E. manifolds. Good stuff.
How far up into ME are you? Is your nearest track NE Speedway?
Mike
'69 Midnight Green Judge 462 Ported 48s RAIII Exh Manifolds 4spd 3:73s
The Following User Says Thank You to RAIIIJudge For This Useful Post:
  #42
Old 05-19-2026, 03:50 PM
scott70's Avatar
scott70 scott70 is online now
Last time I was using standard ram air manifolds with 2.5” headpipes and I think it lost about 15 hp over headers . I was really surprised this time it only lost 4hp with the better manifolds and 3” pipes over headers.. It made the same 570 trq as it did last time but got a decent bump in hp. Peak rpms is now 200 rpms higher with the new HR cam.
The closest track to me is new Oxford dragway,about 50 miles.
Looking at the 2019 dyno sheets it looks like it’s a little lower oil pressure this time. Maybe a 8 psi average lower now through out the pull. The mains are .0028 but the rod clearance is .0029,, last time it was like. .0023 rods. That might be causing the lower pressure. Idling today was around 19-20 psi at 800 rpm at temp.
The Following User Says Thank You to scott70 For This Useful Post:
  #43
Old 05-19-2026, 07:49 PM
scott70's Avatar
It now has a Cloyes double roller racing Z timing chain. Whats does the Z add over the standard racing double roller?
  #44
Old 05-19-2026, 09:00 PM
grivera's Avatar
grivera grivera is offline
What oil viscosity?
Will Rivera
  #45
Old 05-19-2026, 10:09 PM
scott70's Avatar
Originally Posted by grivera View Post
What oil viscosity?
15w 40 cenpeco
  #46
Old 05-20-2026, 10:01 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Outstanding results!!! Really impressive for iron heads and intake manifold. Even better with RA manifolds
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following User Says Thank You to OCMDGTO For This Useful Post:
  #47
Old 05-20-2026, 10:57 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice! Good job
Go fast, see Elvis!
  #48
Old 05-20-2026, 11:50 AM
scott70's Avatar
Not bad for a junky old quadrajet,,, or so I’m told.
  #49
Old 05-20-2026, 12:29 PM
grivera's Avatar
That’s a great build!! Congrats
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
  #50
Old 05-20-2026, 01:19 PM
scott70's Avatar
Looking at the 2 dyno sheets it looks like switching to the manifolds and pipes richend up the air fuel ratio some.
  #51
Old 05-21-2026, 10:14 AM
Jay S's Avatar
Jay S Jay S is offline
That may indicate there was a little more power left on the header test with some tuning. Probably not much though, 510HP with RA manifolds is really getting it done. Makes me want to try a set of those RA manifolds with the 3” outlets.
  #52
Old 05-21-2026, 11:57 AM
scott70's Avatar
Yeah they call these 2.5”outlets but actually they’re a little smaller than that. Rare then adapts a 2.5” end to a 3” pipe. I run those into a 3” x pipe system with 2.5” mufflers and tailpipes.
  #53
Old 05-21-2026, 12:15 PM
A little shocked the headers were not worth more. On my 455 dyno yesterday the Tri Y headers lost a lot to the 2" and my cam was kind of close, bigger heads and intake runners though.
I had issues with my RARE 2.5 manifolds sealing at the head pipes on the 81 car. It is getting the 455 dynoed yesterday in place of the mild 400.
  #54
Old 05-21-2026, 12:42 PM
scott70's Avatar
The headers were 1 3/4 hooker super comp the engine shop has.
  #55
Old 05-21-2026, 12:53 PM
grivera's Avatar
Do the 3" headpipes use different manifold flange adapters than a 2.5"?
Will Rivera
  #56
Old 05-21-2026, 01:52 PM
scott70's Avatar
I believe what he did was use the very beginning of a 2.5” pipe with flare, maybe 2” and then welded that onto a 3” mandrel bent head pipe. So the very beginning is necked down but the rest is all 3” . Not ideal I guess compared to 3” the whole way. I believe it’s the same flange as a standard 2.5”. Like I said they call these oversized but comparing the ID of these compared to my other standard aftermarket manifolds there wasn’t much of a upsize but there is some.
The Following 2 Users Say Thank You to scott70 For This Useful Post:
  #57
Old 05-21-2026, 03:15 PM
67Lemons 67Lemons is offline
I was wondering what the difference was with the R.A.R.E. OS manifolds but the webpage is gone now. I wonder how they compare to the new Ames 2.5” outlet versions?
1972 GTO
  #58
Old 05-21-2026, 03:23 PM
TXSTARFIRE TXSTARFIRE is online now
Maybe can get the old page using the wayback machine?
  #59
Old 06-02-2026, 08:55 PM
scott70's Avatar
I asked today for some valve spring specs from the engine builder. Using my previous 995 comp springs they were shimmed to a height of 1.685 which resulted a 130 lb closed and 370 open pressure.
Did a 3/4 turn on the comp evolution which was .063 preload.
Piston to valve clearance was .185
I asked about shimming the springs a little more but he said he really didnt want anymore than the 370 open pressure. Peak HP on the dyno was 5400 with the 236/244 .580 HR cam.
  #60
Old 06-09-2026, 01:25 PM
scott70's Avatar
Got the engine home today, they had to replace a rear main seal and pan gasket from a leak on the Dino ,ran it for a a total of a couple of hours on the Dino. Don’t see any leaks so that’s good. Here’s the old bearings that came out of it from the 2019 rebuild. I was hoping they’d look a little better.. The engine doesn’t get babied
