Old 06-21-2026, 03:47 PM
Ronj1969 Ronj1969 is offline
Default Pontiac 400 2801 cam stock quadrajet tune
Car seems to run fine under acceleration however it want to die when pulling up to stop. ( Kinda suspecting the choke) car is warmed up having issues maintaining a good idle I’m running the stock quadrajet carb for 1977 400 4 speed which previously before doing a head gasket worked fine. I smoked the upper half and didn’t see anything that would indicate a leak. I sprayed it with car cleaner and didn’t notice the idol jump or anything. I just had a little bit of a loss. I did notice, however, that the primary air flaps never seen to fully open with the car at 180°. The flaps don’t even appear to have changed from when it was cold.
Old 06-21-2026, 03:58 PM
steve25 steve25 is online now
You mean the choke flap is not firmly held wide open when the motor is up to temp?
If so and it’s just flapping in the breeze so to speak then that’s the source of your stalling out when coming to a stop.
Old 06-21-2026, 04:18 PM
67drake's Avatar
67drake 67drake is offline
Not to mention if your choke is on this far, your gas mileage and performance are going to suck.
Also, because of the secondary lock out, even when you floor it, you’re only running off the primaries. IOW, your 4 barrel ain’t 4 barreling.
‘55 Catalina
Old 06-21-2026, 06:05 PM
No the choke is open just a little bit pretty much the same as when it just starts. I’m going to run it some more tonight and see what’s up
Old 06-21-2026, 06:18 PM
Sounds like your fast idle cam follower is not pivoting freely on its shaft.
Some carb spray and then a bit of auto trans fluid might be all it needs.
Old 06-21-2026, 06:46 PM
Also so that where all on the same page so to speak, in a different post you mentioned that you had adjusted your idle vacuum to 17 lbs, but vacuum is measured I. Inches of Hg not lbs.
Old 06-21-2026, 06:50 PM
Steve I haven’t adjusted it yet with the vacumm gauge it’s just bouncy all over as far the Vacum gauge plugged into the emissions port
Old 06-21-2026, 08:19 PM
If your gauge is hooked up to read full manifold vacuum it should not be moving around , it should be steady if all is well.
With what you have had to repair on the motor and the bouncing vacuum reading your getting at this point I really think you need to do a compression test with only one plug in at a time.
In doing this I would bet that you find two cylinders right next to each other with low compression because the head gasket is leaking between them .
It would be 30 minutes well spent to check this possibility out.
Old 06-21-2026, 09:35 PM
Steve I had it hooked up to the pvc line at the carb base. But you are correct with the compression test. I’ll probably ought to do that just to make sure it’s not valvetrain or head gasket issue. I’ll test the cranking pressures tonight and report back what I find
Old 06-21-2026, 10:52 PM
Steve
I just completed compression check I only did it 1 plug at a time and all pegged 120 I’m sure with all plugs out everything would have been above 140. Considering the 2801 cam bleeding some compression as well. I guess we can at least rule out head gasket or valve hanging open. As normally
Old 06-22-2026, 02:05 PM
My 2801 in a low compression 400 and a Q jet idle pretty good.
Old 06-22-2026, 03:15 PM
Hey Skip do you recall what your cranking compression might have been on your 400 with the 2801 cam.
The OP stating that he’s got only 120 psi with number 62 heads on the motor sounds low , and even considering that the 1977 pistons have a chamfer on there OD.
His erratic vacuum reading makes me wonder if his Cam is retarded.
Old 06-22-2026, 05:24 PM
Mine degreed in right on the money dot to dot. Not sure what cranking psi is. I can try and check maybe this weekend -in the 81 TA and at the shop.
Old 06-22-2026, 06:04 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
So your saying the choke is not opening after it heats up? If so wire the sucker open and try it.
Old 06-22-2026, 09:02 PM
Steve
I did the compression check with all the plugs in and took one out each time. The dial pegged 120 in every cylinder. I’m assuming would have gone higher but with all the plugs in I think they stole some of the compression. The 2801 is basicly the ram air with more lift and duration so there is a little loss from that as well. The car ran 13”s before the head gasket went. On the compression test I did at that point it had two cylinders at 0 cranking pressure
Old 06-23-2026, 01:10 AM
chiphead's Avatar
chiphead chiphead is offline
My 69 400 with 62 heads, 2802 cam pumps 160 to 170psi, every time I've checked it. Same heads with smaller cam should pump at least on 150. Something is up. Was it spinning over very slow? That's why you do compression test with all the plugs removed.
Old 06-23-2026, 09:19 AM
chiphead's Avatar
Also keep in mind that a stock '77 Quadrajet is set up pretty lean, especially the idle circuit. You may need to enlarge the idle feed tube restrictions, the idle mixture screws and other orifices in the idle circuit to provide enough fuel.
Old 06-23-2026, 03:31 PM
Late Q jets are really lean in idle tubes and down tubes. Even with a little cam my stock 180 HP 400 and the 78 Qjet would nozzle drizzle at an idle. Fatter 73 Q jet was fine.
Old 06-23-2026, 03:36 PM
67Lemons 67Lemons is offline
I think the OP has to pull all the plugs and take another cranking compression test just to verify that it’s a sound engine then continue tuning from there.
1972 GTO
The Following User Says Thank You to 67Lemons For This Useful Post:
RocktimusPryme's Avatar
I had one where someone (me) hooked up the needle and seat incorrectly. It just hangs from a hook. I cant recall the exact scenario but you arent supposed to put it through a hole I think and I did?
Long story short, it was totally fine after the rebuild and then after a few weeks it started doing exactly what you said. It would flood and die and a stop after it was warm, but would be okay as long as you were cruising. I too thought I had a choke issue, but eventually narrowed it down to the needle and seat. It just worked its way into not seating after a period of time.
Took it back apart and moved the little hook/clip deal for the needle and its been fine ever since.
