Old 06-24-2026, 10:24 AM
Jonsie Jonsie is offline
Default ID center carb
I have a 2bbl Rochester carb that I have had for many years. Unsure of what year (s) it's correct for. Bowl is 7031576, AH 7031537, TB 31692. Thanks for your help in IDing this carb...........
Old 06-24-2026, 01:31 PM
correction: bowl is a 7031575
Old 06-24-2026, 03:05 PM
The bowl is for a 1966 center carb manual tranny.
Don't know the other numbers?
Jon may know.
Old 06-24-2026, 03:19 PM
Thanks Johntal, PY used to have an online parts lookup site, doesn't seem to exist anymore?
Old 06-24-2026, 03:27 PM
Kenth's Avatar
Kenth Kenth is offline
Center carburetor (S/T – 389/421) 7026075.
Airhorn casting 7031587, bowl casting 7031575, throttle body casting 31892.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-24-2026, 04:48 PM
Red face
Thanks to you HTH, those are the #'s, my eyes aren't so good anymore!
Old 06-29-2026, 02:23 PM
Dick Boneske's Avatar
Your center carb is the most difficult to locate, dur to it being used only on 1966 Tri-Powers. I believe Oldsmobile used the same casting number, but was machined for ported distributor vacuum.
BONESTOCK GOATS
'99 Bonneville SE Sedan
