OHC-6 TECH Over Head Cam projects, questions and advice.
Old 07-05-2026, 05:08 PM
Cammer-6 Cammer-6 is online now
Default Compression ratios of uncommon combos
67 4 bbl head,250 block and .030+ stock configuration pistons
Ive run this combo before but never run the numbers.
Any idea what this combo yields?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-05-2026, 05:24 PM
Your putting a 67 head on a 68 250 short block mainly? (at .030 over)
I don't know the cc of that head off hand, but it would probably be around 10.25/10.5 CR?
Old 07-05-2026, 08:04 PM
that would be about right if I was using a 68 4bbl head
Im away from all my books and notes,but somewhere I have
the CCs
Old 07-05-2026, 08:32 PM
einstein's Avatar
einstein einstein is offline
Remember you loaning me a ported/polished 66 Sprint head that I ran for a while on the 69 OHC TH350 coupe? Those 66/67 Sprint head chambers were pretty shallow. 55, 56cc? Not sure which engine (std or .030) it was but all I had were 69 250 blocks.
My notes are currently inaccessible as well.
If my seriously compromised memory isn't too far off, I was thinking it was well over 11:1, maybe closer to 12:1. Hottest OHC combo I've ever driven. Damn, that was over 30 years ago...
Old 07-05-2026, 08:40 PM
Found it in Petes book.I remember giving him all the info for OHC-6,thinking it was close to 50 yrs ago.
67 4 bbl head CC is 47.7
68 4 bbl head CC is 55
so its gonna bump compression by 7.3CC
Old 07-05-2026, 08:49 PM
If 47 cc head would be around 12 to 1 cr.
Old 07-05-2026, 09:47 PM
einstein's Avatar
That comports with my recollection.
Old 07-05-2026, 11:46 PM
IIRC you can bump about .4 due to overbore also
Old 07-06-2026, 05:13 AM
Jeff Hamlin's Avatar
Thumbs up
If interested Rob still offers Jerry Woodlands REBUILD GUIDE with updates.
It covers all this type info in one convenient package.
Cheers.
Old 07-06-2026, 08:31 AM
Jeff are you keeping it a secret?
Old 07-07-2026, 10:31 AM
I used an online calculator to try and get close.
The variable is what the piston head cc is.
Specs say 5cc but dont say if thats + or -
11.27 if the dome is negative
13.05 if its positive
I have popup pistons that I think are +12cc
that would be 14.73
now thats what makes an engine bark
Old 07-07-2026, 11:36 AM
Pic of piston
ID:	672954   Click image for larger version
Name:	DCP_2227 piston.jpg
Old 07-07-2026, 12:11 PM
IIRC or if CRS hasnt completely set in,I remember some 50 ft patches you left from your 1ST to 2ND gear in the 69 coupe
Old 07-07-2026, 12:45 PM
einstein's Avatar
That combo was pretty impressive.
Old 07-08-2026, 01:07 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
that would be 14.73
My experience is the factory under states the head cc's. I'd have to check my notes but I believe those 55cc heads are closer to 60cc. I haven't measured a '66 4bbl head. In any case, I'd measure the head if you can, but odds are you'll end up with a bit less compression than expected, with the exception of the '69 1bbl head that is significantly off published at 80 cc's.
I measured two types of over-bore replacement pistons and both were -5 cc's.
I suspect the heads cc high with factoring in future rebuilds shaving the head a bit and min-spec hits the published number. Similarly with block deck, the pistons are not zero decked from the factory and likely in the hole a fair bit. Need to measure. I've never measured an untouched OHC block. Buick's are often ~0.050" in the hole on a giant bore so cc's add up, the smaller bore has less impact, but still an impact. Then there is head gasket selection, factor in if you are using the steel shim gasket or a ~0.040" composite gasket.
MY opinion is, with an iron head, I get nervous about 91 pump gas over 9.5:1 measured static compression. Especially without a good cam with lots of overlap to bleed dynamic compression at low rpm. There's no E-85 around where I live.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 07-08-2026, 05:22 PM
E85 very plentiful here
I used all factory specs on the CR calc
.014 deck height
Felpro HG .058 but I do have a few that are. 021
I may need to contact Cometic
block is O ringed
.540 lift cam
Old 07-08-2026, 08:17 PM
sprintbird sprintbird is offline
A couple years ago or so a fellow Cammer reached out to Cometic to make a head gasket. They said they could do it, but wanted about $4K? to cover necessary tooling. That tells me that they don’t want to do it. Probably because there is no market.
Old 07-09-2026, 10:05 AM
I have a CAD plotter I use to cut gaskets but cant do anything as thick as that with the knife.
In this day and age of scanners,3D printers,laser cutters etc this shouldnt be a challenge.
I would explore intake/exhaust gasket too.Ive always run the fiber Cliffords but am now out.
Old 07-09-2026, 10:29 AM
Best Gasket makes composite manifold gaskets as well as Flatout Gasket. So they are out there for purchase. I have the Best Gasket version in stock.
The Following User Says Thank You to sprintbird For This Useful Post:
Old 07-09-2026, 11:10 AM
If I can find proper sheets or rolls of composite,I may be able to cut,just need to do multiple cuts.
But I still like the idea of copper.
