Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-03-2006, 08:36 AM
superfreak superfreak is offline
Default TH 400
Looking for a TH 400 to rebuild? Have some back seats from a 64 tempest.
Craig
  #182
Old 11-16-2006, 02:56 AM
N0DIH's Avatar
N0DIH N0DIH is offline
I am looking for a decent set of stock rear lower control arms for a 68-72 A Body. Anyone have some collecting dust? I have a sway bar I want to mount, so I will be sending them to a local welding shop to box.
Thanks!
  #183
Old 11-16-2006, 10:00 PM
form74's Avatar
form74 form74 is offline
Default Free Mid 70's oil pans
GONE
Two free mid 70's oil pans, must pick up in western burbs of Chicago. Used dirty condition. Cleaning out Garage
  #184
Old 11-27-2006, 08:55 PM
tremo's Avatar
tremo tremo is offline
Default FREE '69 #45 heads
Got a set of '69 #45 heads in the Denver, CO. area. I've got them on craigslist currently for $60 (both), but they're Free to Pontiac folk on PY. Pick-up only.
http://denver.craigslist.org/pts/238350656.html
Drop me a PM or e-mail me at [email protected] if interested.
Seee-ya,
Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
  #185
Old 11-29-2006, 11:35 PM
form74's Avatar
Smile EGR's and & Original Bottom Core Support Hardware from 74 Formula
Title says it all, thought somebody might want original Hardware. EGR's from 74/75's and Core Support hardware from 74 formula.
Pick it up or Shipping shouldn't be more than a couple of dollars.
Have at least one bracket and bolt for the EGR's
ID:	73707   Click image for larger version
  #186
Old 12-17-2006, 02:38 PM
LeMans70Sport's Avatar
LeMans70Sport LeMans70Sport is offline
Send a message via Yahoo to LeMans70Sport
I have 2 bucket seats from a 70 Lemans. Frames and tracks are in good shape The seat upholstrey is in driver condition and are brown. I also 8 stock used 350 piston standard bore. The pistons I can send but the rest is pick up only from West Michigan area-49088.
Going as fast as I can afford on a fading middle class income.
  #187
Old 12-19-2006, 03:03 PM
Uncle Phil's Avatar
Uncle Phil Uncle Phil is offline
Default Needing some 68' Firebird Items
I'm looking for a right and left side seat support / seat frame for a 68 Firebird. The ones I have a pretty rusty, and had to cut them out. This is the brace/support that is right on top of the floor pan where the seat connects.
I have several extra items for a 68' I'll offer up if I can find these.
Also...........Needing a decent shape glove box door and a valance (which goes between front window and rear of hood). Mine is pretty pitted.
Let me know on any of these....I'll look over my items, and offer up a few of them.
Phil
Musician / 77 Formula / 68 Firebird Owner
http://www.Grasstowne.com
http://www.UnclePhilOnline.com
  #188
Old 12-24-2006, 09:02 AM
DScruggs's Avatar
DScruggs DScruggs is offline
70 400 Block (.030 over) with "N" crank - some rust
Pistons and rods for same
2nd Gen F Body 10 bolt 2.73 open complete assy
I set of 6X-8 heads
Assorted other F Body parts including shifter and cable, seat belt interlock, air cleaner housing etc.
All pickup only near DC
Need 4 cheap steel wheels and tires that hold air to remove racing tires for winter storage
  #189
Old 12-24-2006, 11:34 AM
Thomasmoto's Avatar
Thomasmoto Thomasmoto is offline
Hi, Is the air cleaner housing for a TA shaker? I need just the bottom part of the air cleaner for my daughters 77 TA. We have the scoop, just not the part that holds the air filter.
Thanks, David
  #190
Old 12-24-2006, 03:15 PM
DScruggs's Avatar
No. It is a plain 400-4V from about 74
  #191
Old 12-30-2006, 07:54 AM
Lemans1 Lemans1 is offline
Scruggs, do you think the 400 will need to be bored more than .040? I dont have any steelies around, only wheel I have with no purpose is a 60/70s style aluminum slot, but it has a tire and air and youre welcome to it. A buddy of mine might have something...you need all for? I will check it out.
Rich
"Artificial intelligence is no match for natural stupidity."
  #192
Old 12-30-2006, 09:04 AM
DScruggs's Avatar
.040 will PROBABLY be enough. I can't say for sure. I do need four wheels but you are welcome to the block regardless. If you want to come by and see lt let me know.
  #193
Old 01-02-2007, 03:53 PM
DScruggs's Avatar
Block goes to metal recycler Friday
  #194
Old 01-02-2007, 04:06 PM
kcompton kcompton is offline
In need of 15 inch (or larger) wheels. Upgraded to discs without a plan for the wheels, surely someone can help me out. Thanks in advance. not looking for handout, have a little $
  #195
Old 01-05-2007, 10:04 PM
Dscruggs, you have a pm.
  #196
Old 01-05-2007, 10:23 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
hi rich
hi scruggs
happy new year
-mike
is this thing on?
  #197
Old 01-20-2007, 10:15 PM
DScruggs's Avatar
Complete Big Car BOP TH400 - Was running fine when pulled.
I set of 6X-4 heads,
Assorted other F Body parts including shifter and cable, air cleaner housing etc.
Need a set of BBC rocker Studs, ARP connecting rod bolts, Decent Q-Jet core.
  #198
Old 01-22-2007, 11:19 AM
Thomasmoto's Avatar
Hi, Is the air cleaner housing for a Trans AM? I just need the lower part.
Thanks, David T.
  #199
Old 02-08-2007, 07:16 PM
mashedfinger67's Avatar
mashedfinger67 mashedfinger67 is offline
Default Motor mounts, FREE to good home
Brand: Anchor (Korea)
Part#: 2335 (R), 2336 (L)
I got em' at checkerautoparts for $7.79 each when I had a hair brained idea that I could move my new 462 back in my '67 by using these mounts. They are just sitting around collecting dust and I am sure someone could use them. New owner to pay shipping. PM me if interested.
This is what Checker's web page say's the mounts will fit;
1970 - 1971 GTO
1973 GTO
1970 LEMANS
1972 - 1974 LEMANS
1969 - 1979 FIREBIRD
1970 - 1973 GRAND PRIX
1973 - 1975 GRAND AM
1971 - 1972 BONNEVILLE, GRANDVILLE
1971 - 1978 CATALINA, GRAND SAFARI
The demon code prevents me from declining a rock-off challenge...........we are the D, we are the D, we are the D!!!
  #200
Old 02-08-2007, 08:53 PM
DScruggs's Avatar
I'll take 'em
