Old 12-05-2013, 04:12 PM
unruhjonny's Avatar
I know the early cars got them, I have one;
(old pic)
1970 Formula 400
Old 12-05-2013, 04:16 PM
Judge273's Avatar
Judge273 Judge273 is offline
Good stuff here:
http://forums.maxperformanceinc.com/...mp+alt+bracket
Mike/Illinois
Old 12-05-2013, 05:31 PM
transam1972 transam1972 is offline
Default missing alt. bracket
the one threaded hole on the back of my alt. appears never have to been used...certainly does not need it...I will have to check other 72 T/As....thanks
Old 12-05-2013, 09:53 PM
Formulabruce's Avatar
that rear bracket is different than other rear brackets used on smaller alternators and it curves away from the alternator at the top.
" Long may we DRIVE !"
Old 12-05-2013, 09:54 PM
(old pic)
The bracket above picture is for a NON 80 amp set up and that bracket will not line up to the Boss hole on the back of the 80 amp alternator
To illustrate, the picture below the bracket on left is the more common one for the 55 amp alt. The one on the right is for the fixed position 80 amp Alternator. Its like a mirror image of the other one.
Sorry for the short hijack...
Old 12-07-2013, 01:29 PM
Default bracket
I am confused..did 80 amp get a rear holding bracket or not...sorry about this
Old 12-07-2013, 02:44 PM
njsteve's Avatar
njsteve njsteve is offline
The 80 Amp alternator, which is the one that is mounted in a non-adjustable position (the idler pulley sets the adjustment) has a large bracket in the rear with a spacer. If you ordered A/C and the rear defogger - the glass with the electric grid, you got the 80 Amp alternator. Here is a shot of the bracket and spacer and bolt from my 73 SD. Both of my 72's had the same set up as well.
BTW, the bracket is actually grey phosphate and not painted.
ID:	345790   Click image for larger version
The Following 3 Users Say Thank You to njsteve For This Useful Post:
Old 12-07-2013, 11:38 PM
From what I have seen in Parts cars..., a Combo of AC and Power windows could get this 80 amp set up as well. Just an observation, not saying its Gold...
Old 12-07-2013, 03:18 PM
unruhjonny's Avatar
80 & 55 amp both had them, they were just slightly different.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 12-07-2013, 03:35 PM
Default bracket
I have a/c and edf...80 amp. setup but now realize I am missing the rear bracket...most everything seems to be complete and correct except that...I will have to find those parts.. at 58k it was missing some stupid stuff...like the clip for the purge hose..the passenger side heat stove and now this...thankyou for your help everyone
Old 12-30-2013, 09:58 AM
70RAlll 70RAlll is offline
Sorry..not Rustoleum, Krylon Semi Flat Black. Here is an Amazon link. $7.74 can with Amazon's free shipping. They show cheaper at $5.99 but you pay shipping..
http://www.amazon.com/Krylon-RTA9203...emi+flat+black
The Following User Says Thank You to 70RAlll For This Useful Post:
Old 12-08-2013, 09:43 AM
Pepi's Avatar
Pepi Pepi is offline
I haven't yet, will try later today or sometime this week.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 12-15-2013, 05:12 AM
Green/red scuff pad may tone that down, or 000 steel wool
Old 12-15-2013, 09:02 AM
Bentwheelbob's Avatar
One last post on plumbing the air cleaner vacuum lines on Ram Air cars.
This is a video. Click to play.
The Following User Says Thank You to Bentwheelbob For This Useful Post:
Old 12-15-2013, 11:20 PM
Bruce - thanks for the suggestion, but this stuff is basically a spray on vinyl coating that can be peeled off. I don't think it will ever get hard enough that it could be scuffed in a controlled. I may end up spraying both the snorkles and the lid.
I did the snorkles today and they turned out well. It still amazes how bad this stuff looks when you spray it on and then it cures and turns clear. It also seems to tighten up as it cures. The air cleaner lid looks even better today than last night with a smoother finish. Here's the snorkles.
The Following 2 Users Say Thank You to Bentwheelbob For This Useful Post:
Old 12-15-2013, 09:51 AM
Pepi's Avatar
Interesting information. Thanks.
Old 12-15-2013, 10:25 AM
The Boss's Avatar
The Boss The Boss is offline
That's cool!
And go racin' in the street.
Old 12-15-2013, 01:47 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Bob, what publication is that in?
Old 12-15-2013, 11:06 PM
Rocky - Here you go. BTW - thanks for the book you wrote. It has been a huge help.
Old 12-27-2013, 12:35 AM
Held for Ransom's Avatar
Come back to post in a few threads.
Why did you use the green 6484244 ('73-up, think EGR) sensor instead of the correct black 6484242 ('68-72) unit?
I thought the '70-2 RA vent pipe tubes had the bend and went away in '73 (which had an angle cut on the end). Yours looks like a newer ('77-9) unit.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
