Old 02-03-2018, 08:46 PM
tom s tom s is offline
I have the indicator face plate,chrome is good,one crack going across just above the D and 2 shallow ones through the D$25 plus shipping.PM or text me at 5622430570.Tom
Old 02-04-2018, 11:17 AM
TRMarr's Avatar
TRMarr TRMarr is offline
Thanks Tom- Let me see what happens in regards to the housing first though, if I may.
Old 07-05-2018, 09:15 PM
Jmanaster Jmanaster is offline
Default 63 AT Floor Shifter Knob Needed and AC Kick Panel
Anyone have or can locate the white shift knob for 63 floor console? Also looking to find I cracked AC kick panel that is the type that has the bulge.
Thanks,
Jake in California
Old 07-06-2018, 08:48 AM
1979birds 1979birds is offline
Anyone have a good running 4cly engine for sale in the Richmond VA area?
Old 07-06-2018, 02:00 PM
rdtripn_rte66 rdtripn_rte66 is offline
Jim Genn on fb has one in NY Maybe Darrell Wheeler
Robin Triplett
Midwest Director of the Little Indians Club
417-456-9858 cell
63 Lemans convt. Present
1970 350 Firebird motor built to 69 350 HO specs
Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals)
700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup
65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8")
Old 05-10-2018, 07:42 PM
I have a NOS set of R&L tail light diecasts which have NOS lens.Still in the factory blk and yellow boxes.Might have to take a second on your house!LOL,Tom
Old 05-10-2018, 09:15 PM
AzMike AzMike is offline
How much do you want for the lenses ...if you would sell just the lenses?
Old 05-10-2018, 10:16 PM
Doug Doug is offline
Thumbs up 63 LENSES
I've got a pair in original boxes. Boxes are ragged, lenses are pretty much perfect.
Drop me a private message with your top offer.
Good luck!
ID:	482725   Click image for larger version
Old 08-30-2018, 07:06 PM
Default 63 Tempest or Tempest Lemans 326 PS Pump and two mounting brackets
Looking for the two piece mounting brackets for the 326 Power Steering pump and a pump or where to locate a remanufactured pump.
Brackets are those that locate to the drivers side head with three bolts.
Need this timely.
Thanks in advance!
Jake M
310-962-2026
Old 09-01-2018, 12:12 AM
All set.
Thanks all.
Jake
Old 11-24-2018, 01:12 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Default I could use those
Pm sent on Johns front end parts.
Old 07-06-2018, 10:17 AM
Default Offer
Tom would you take $350 incl shipped to CA for casts and lenses? Do you have gas door are well?
Thanks,
Jake in California
QUOTE=tom s;5880427]I have a NOS set of R&L tail light diecasts which have NOS lens.Still in the factory blk and yellow boxes.Might have to take a second on your house!LOL,Tom[/QUOTE]
Old 05-10-2018, 09:57 PM
Sorry,no.They show up on ebay from time to time.Tom
Old 05-20-2018, 10:10 PM
Hello All - I have a friend looking for pcs off a floor shifter - the plastic housing - the chrome top pc and the plastic indicator lens. Please any leads will help!!!
Thanks - Robin
Robin Triplett
417-456-9858 cell
Old 05-27-2018, 02:09 PM
Exclamation
Here is the AC pc I have. Solid - Unbroken. Call me for more info.... TYVM, Robin
ID:	483947   Click image for larger version
ID:	483948   Click image for larger version
Robin Triplett
417-456-9858 cell
Old 06-08-2018, 08:48 AM
TRMarr's Avatar
Looking for a convertible top hold down/ clamp ( top of windshield) passenger side. -Thank You-
Old 06-08-2018, 01:54 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
As I recall that chrome plated latch mechanism was shared with several other GM cars from the 1962-1963 era. The Buick Special/Skylark, and the Olds F85/Cutlass bodystyle had the same folding top arrangement as the Tempest.
I would check with the Chevy Impala or Full size Oldsmobile Convertible top parts vendors, they might be able to help you. If you need the latch assembly it's kind of an expensive part but those people need new latches. It's made from cast potmetal and used ones are always corroded.
Peter Serio
Owner, Precision Pontiac
Old 06-08-2018, 05:07 PM
TRMarr's Avatar
Thank you very much Mr Serio, I'll explore that avenue, then.
Old 10-02-2018, 10:47 PM
Default 63 Stainless Roof Drip Rail Trim
Any chance anyone has a straight 63 passenger side stainless roof drip rail trim piece to sell.
Someone put a screw through mine to hold it in place evidently. Ugh.
Thanks.
Jake in California
Old 10-02-2018, 10:48 PM
That would be stainless. Thanks.
