#181
Curious if you mapped out your timing curve?
More initial, and less in the dizzy/total may clear up you spark knock issue, and increase low end torque. Some more fuel also. If your around 10:1, your in the right range compression wise for aluminum heads and should be able to tune for 93 pump gas. Also may need to limit amount of vacuum advance and tune where it comes in. What you have and where the knock is (assuming light load low rpm tip in).... If it knocks wide open, you may be after much more than a cam on your next parts order. ![]() Every one is trying to help you get it humming, don't take the advice as insults.... A lot of good experience to draw from here. Like a hot body...if it came in a box everyone would have one. ![]() I understand and will consider this closed if your done trying to get it better with what you got.
#182
Having tuned at least 3 E carbs with performance cams, one with a wideband. The factory calibration isn't going to cut it.
I see this as well. |
#183
The tick is lifters. If it's something else then I will be fixing something else some day, of course, doesn't that go without saying? Looking back, the only comments that really helped at all mostly came from Clay. Not saying that others weren't trying to help, their comments didn't help. Mostly condescending. You helped me make sure my pushrods were the right length, thanks. There's a lot of 'noise' around here that's not very positive. Sorry folks are not happy. Glad I have a life that keeps me positive and moving forward. |
#184
Thanks for that negative response. Maybe you should think about why you post here. If you aren't posting to help then you are posting for the wrong reasons.
#185
At some point you have to think it's the lifters. If it doesn't tick with the new ones then we will know it was the lifters and not the adjustment. |
#186
So you have a QJet from Cliff on another car? I would swap that QJet on this car so to see how it acts. As much as you like to change parts, it would be no big deal and cost nothing. Or just get another QJet from Cliff set up for this combo.
#187
![]() Maybe you should think about why you post here. If you aren't willing to listen to the posters for help then you are posting for the wrong reasons. From my standpoint I think it is time to just seat back and which how this all plays out. Stan
#188
Don't think he read the whole thread or the follow up thread after the engine got put in the car. I'm not going back to read all of both...But seems like there was 10° difference in where to set total timing. That's from where it made peak HP to being able to drive it on the street. Those reverse dyno pull numbers also dont tell us how hard the engine was bucking and jumping like it would on the street with a stick shift.
Engine also went in an automatic car with a 3,000ish rpm stall converter. That makes me think twice about how "useable" that low rpm power really was. About got sea sick watching the 302 video when he was lugging the engine around. Smoothed up a bunch when he actually drove it like them little engines were made to be drove. The china HEI I've got here was a gimme. I did not buy it. Centrifugal advance is slow with strong springs and very limited on how far it does advance. Engine tuned to scream has initial timing way too high for it to run smooth at low RPM's. If you just crack the throttle and vacuum advance comes in....Shouldn't need explaining. Pretty much useless for a stick shift street car with an engine like your's. At least how they come out of the box. Do believe with some distributor work and fine tuning you could get this thing doing better. Total cure with the Voodoo cam that builds higher cylinder pressure, in an engine that's already got high static compression. Still gonna feel every cylinder hit at low rpm's. Got more but need coffee Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
#189
When I first came here with my build receipts a lot of folks said 'itty bitty cam'. Or, 'no one with these heads runs a cam that small'. So I listened and tried a bigger cam. Now I'm going to use a cam that targets the usage of the car. Not what everyone else with these heads uses. I think the guy who made the build plans in the first place was spot on. He just made a mistake lining up the dots. So I went and saw what a big cam was all about. Now I'm going to be more practical and follow what the cam selection instructions say when applying them to what you use the car for. Wouldn't be the first time someone made a mistake and got too big a cam for what they use the car for. I'm just quick to admit my mistake and move forward. |
#190
When I, and others here, say it needs more tuning, we are talking about getting more in depth than just your simple setting idle mixtures and shutting the hood. That's not tuning. Like I mentioned earlier if you cared to read, you will need to get way more in depth with the carb than that. |
#191
Maybe people are just used to different things. |
#192
He hasn't been around here that long and doesn't understand some of the knowledge floating around here. All good advice and no one was out of line at anytime that I read, so take it with a grain of salt.Maybe he'll get it figured out if he just keeps throwing enough money at it. Last edited by Formulajones; 04-29-2019 at 10:30 AM. |
#193
That's not what you are seeing. Trust me. The engine is smooth everywhere. The roads unfortunately are rough around here. I have to drive several miles to civilization plus it's downright impossible to hold the camera still when it's resting on myself, so likely what you are seeing is just me moving around in the seat. It clearly shows these big cam engines are perfectly fine at low rpm if you know how to tune these things. Listening to the engine is what should be paid most attention to, not so much the video.
#194
So what did the first cam turn out to be?
Looked back thru the other thread and still unclear. |
#195
It's the one on the receipt from the build. 2157
#197
Yup. Not long. Since 2005. Most of my experience was back in 70's, 80's and 90's before I joined here. Won trophies at the Motorplex running my Pontiacs. I probably forgot more than you know. Been fixing presses and other industrial machines for a long time and I'm just getting back in the swing with these toys.
They are very simple machines. |
#199
I would rather talk about cars. But your drama queenness wants to talk about me. I'm just answering your posts. Done with that.
