Old 08-11-2024, 05:22 PM
MUSLCAH MUSLCAH is offline
Looks nice ! So where did you end up getting it painted ?
  #2002
Old 08-11-2024, 06:41 PM
64speed's Avatar
64speed 64speed is offline
KMA Customs in Tampa
  #2003
Old 08-11-2024, 07:03 PM
Joe's Garage Joe's Garage is offline
Default If you look at the later factory setups, they all use pusher fans for AC cooling help
Originally Posted by 64speed View Post
IF I decided to put an electric fan on the condenser alone how do I want it configured? Pushing or pulling
All of the factory stuff we've fooled around with (mostly 1990s Cadillacs and Chevrolet Suburbans and Silverado trucks) use PUSHER fans that turn on with MAX AC or at a specified temp for additional cooling.
The FWD Cadillacs do have a temperature-controlled 'puller' fan for regular cooling, but the second fan - the one that kicks on for the AC - is a 'pusher'.
  #2004
Old 09-14-2024, 12:17 PM
64speed's Avatar
Little update. After terrible gas mileage with this Double Pumper and just generally not being satisfied I am having Cliffs former partner Ray Klemm build me a custom quadrajet. Anything I need to know before I make the swap in a couple weeks? I am so stoked
The Following User Says Thank You to 64speed For This Useful Post:
  #2005
Old 09-14-2024, 03:08 PM
TB1's Avatar
TB1 TB1 is offline
What intake are you running? hopefully something that doesn't require a square bore to spread bore adapter or hood clearance issues most likely in your future
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
  #2006
Old 09-14-2024, 09:59 PM
64speed's Avatar
No it’s a Performer RPM. I already have a serious drop base air cleaner
  #2007
Old 09-22-2024, 12:35 PM
64speed's Avatar
Well I can’t replace the shocks because the 3 inch tail pipes are in the way. I can’t unbolt them and even if I could I can’t get them between the axle tube and the pipe. I’m going Tuesday afternoon to have the pipes cut off and 2.5 inch pipes in their place. Not real happy about crush bent tailpipe but it is what it is.
  #2008
Old 09-22-2024, 12:53 PM
HWYSTR455's Avatar
Those lower shock mount bolts I PM'd a link to you are spaced out by an inch, which helps a lot with exactly the interference you are experiencing.
  #2009
Old 09-22-2024, 01:18 PM
64speed's Avatar
Thanks I’ll look into those. I am torn between the tips I have and the quarter panel exit. Also how much quieter will it be shrinking the tail pipe diameter. Every little bit would help
  #2010
Old 09-22-2024, 02:19 PM
HWYSTR455's Avatar
Tips that point to the ground or even to the side and down are a little quieter, going to a 2.5 tailpipe will help a little too, but the majority of it comes from the mufflers.
I don't think you can 'cheat' that by much without changing mufflers.
  #2011
Old 09-22-2024, 02:31 PM
I would think that you should be able to buy some mandrel bent 2-1/2” A-body tail pipes that with some minor tweaks involving a little cutting and welding would work.
My last choice would be crush bent tails fabricated by a local muffler shop.
  #2012
Old 09-22-2024, 02:32 PM
64speed's Avatar
It will neck down to 2.5 directly behind the 3 inch magnaflow
  #2013
Old 09-22-2024, 06:16 PM
64speed's Avatar
I can’t buy mandel bent pipes this close to Christmas. I am gonna let them fan up the tips and then when I have the money I’ll get an exhaust kit again. I just bought a quadrajet to replace the Holley. Between it and the adjustable uppers in the rear I am tapped out
  #2014
Old 09-22-2024, 06:29 PM
HWYSTR455's Avatar
Yeah, there's the problem, the magnaflows. Those are not 'quiet' mufflers.
Like I mentioned, you can't make loud mufflers quiet by dropping back to 2.5 tailpipes.
If you call Pypes, you can order just the tailpipes, and have them in 3 days. That would be cheaper than someone bending them for you.
Aren't others running 3" tailpipes on that body? I may not be understanding the problem.
  #2015
Old 09-22-2024, 06:42 PM
64speed's Avatar
All this noise I’ve been hearing and complaining about is poorly fitted pipe. It’s been hitting the axle tube on one side for one. For two it’s ran in such a way that even if I could get to the shock bolts I’d never get them off. I have no shocks to speak of in the rear right now and I gotta do what I gotta do
  #2016
Old 09-23-2024, 12:35 PM
HWYSTR455's Avatar
If the exhaust noise from the engine is not a problem, maybe just have the shop flatten or move the tailpipes? That would be less money than replacing them with junk.
  #2017
Old 09-23-2024, 12:36 PM
HWYSTR455's Avatar
Can you take a pic of the area in question? I'm curious to see what you're talking about.
  #2018
Old 09-23-2024, 01:16 PM
64speed's Avatar
I will try to get some pics tomorrow before they start just so you can see and see if they can just flatten it. The engine noise is fine. Exhaust note is perfect. It’s just poorly positioned. The pipe beat the hell out of the shocks on every bump and was even rubbing the axle tube until it self clearanced
  #2019
Old 09-23-2024, 02:48 PM
Murf Murf is offline
My wife’s 65 has 3” with an x to the mufflers & 2.5 tailpipes that turn down between the frame & trunk extension . Walker long case 3” mufflers. I don’t remember the number.
Anyway. They are too noisy inside the car for me. I just had Sue do a drive by while I stood on the side of the road. Sounds good going by. I’m not sure if the X pipe is making it drone & seem louder than it really is or not. Right now I’m contemplating going to 2.5 front pipes & mufflers over the winter. I won’t put an X pipe back on.
So, I don’t think the 2.5 tailpipes will help with the noise much. Might we worth going for whatever shock clearance issues you’re having, tho.
Good luck!
Murf
  #2020
Old 09-23-2024, 03:55 PM
JLMounce JLMounce is offline
Good luck!
Murf
Baffled mufflers and X pipes don't generally mix. They create a lot of resonance in the system that creates that drone you don't like. These types of mufflers are better suited to H-pipe or non-crossover true dual type exhaust systems.
Try a straight through packed muffler like a magnaflow or turbo style muffler like a dynomax with your x pipe. This should drone less.
-Jason
1969 Pontiac Firebird
