Old 06-11-2011, 08:04 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Cool Twin Turbo 535 RA-V Build
Making some progress on the heads!
ID:	246730   Click image for larger version
Old 06-11-2011, 08:39 PM
TOP 452's Avatar
TOP 452 TOP 452 is offline
Send a message via Yahoo to TOP 452
Looking good ED. Waiting to here some thunder
Old 06-11-2011, 09:06 PM
Tom Vaught's Avatar
Boost Engineer
VERY IMPRESSIVE
Looking forward to watching a dyno test at some point.
Tom Vaught
Old 06-11-2011, 09:11 PM
bankbook's Avatar
bankbook bankbook is offline
Thats going to be a great combo!
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 06-12-2011, 07:48 AM
shaker455's Avatar
shaker455 shaker455 is offline
Very good Mr.Ed!
A great build takes time.
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 06-12-2011, 10:27 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Very Cool! Best of luck with it.
Old 06-13-2011, 12:12 AM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Are you planning on leaving the deck wet or plug the holes? Have you looked at the possiblity of adding the extra bolt holes in that head? Just curious if the layout allows it?
What size turbo's?
Old 06-14-2011, 11:34 AM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
We did the newly designed header flanges yesterday and put them on the heads. Now we can do the exhaust. These heads have the alternate valve spacing for the 4.350 bore. This head will have 2.30 intake valve.
This will be our standard CNC program for the stock head castings.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
Old 07-26-2012, 02:07 AM
john marcella john marcella is offline
I would like to get a hold of this head. I kinda got an idea
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 07-26-2012, 05:37 PM
RAIV-Z's Avatar
I'm all ears!
btw... Your mailbox is full.
Old 06-15-2011, 02:44 PM
RAIV-Z's Avatar
We’re going with Turbonetics 88mm turbos.
Old 06-15-2011, 03:13 PM
cgeise's Avatar
cgeise cgeise is offline
Plan ahead for back pressure issues -
Old 06-15-2011, 07:43 PM
RAIV-Z's Avatar
Anything specific we should watch out for?
Old 06-16-2011, 12:08 PM
cgeise's Avatar
On my 525 - it starts to get into back pressure "issues" at about 22 to 24 psi - we had the tubine housings modified and it helpped but is still there - I have been told the only way to fix it is 91s or 94s -- and those things are huge -
Old 06-16-2011, 09:28 PM
Tom Vaught's Avatar
Boost Engineer
I would like to hear more about these issues at 24 psi of manifold pressure in the intake. What is the pressure in the Turbines at the same boost levels?
Tom Vaught
Old 06-17-2011, 09:30 AM
Smile
Tom Vaught
OK CG you got the ears of the "big dog" boostman listening. I have the explanation from my engineering student son, but students are silent when the professor is ready to chime.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
Old 06-17-2011, 09:55 AM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
Did they go into specifics on why those would fix the problem? Better/bigger turbine housings than the 88s? just curious
Panos
Little Miss G Racing on Youtube
Old 06-16-2011, 05:58 PM
cg did you dyno this engine? Normally aspirated and then with boost?
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
Old 06-17-2011, 12:05 PM
cgeise's Avatar
I have never run the car on the dyno with no booste - but I know it will run mid to high 9s with out the turbos working - dont ask how I know - the back pressure starts to creap up into the 2 to 1 range when it goes over 24- to 25 psi - and yes - the bigger turbos seam to have a better - more efficient turbine housing - but the whole turbo is so big it would take a major rework to make them fit -
Old 06-17-2011, 06:52 PM
taff2's Avatar
taff2 taff2 is offline
Couldn't you bypass some of that backpressure through the wastegates? Back in the day,turbo drag racers used to use small turbine housings for quick boost response and then run a lot of the exhaust gases through the 'gates.
