Old 08-11-2015, 09:32 AM
weranc55's Avatar
weranc55 weranc55 is offline
Originally Posted by Brewster View Post
I know right, Well all we can do is try an hope things turn out okay. Have to remember its suppose to be fun kinda like that game of golf
Keep plugging away. Even if you don't get the car done for the nats at least it will be closer to being together than it is today. I would come and also give you a hand but my plate is full. One piece of advise I usually put my starter and manifolds on before I put the motor in. Since your core support is off I would mount my rad and fan shroud to it and mount it as one piece. Good luck
Old 08-11-2015, 10:15 AM
Judge273's Avatar
Judge273 Judge273 is offline
We will get that motor running this weekend....cue the Steppenwolf
Mike/Illinois
Old 08-11-2015, 01:12 PM
Brewster's Avatar
Brewster Brewster is offline
The exhaust and starter will be on before I bolt in the motor. Just have it in place attached to the trans for now. Thanks Chuck and see if you can make it theres plenty of rooms available and beer
Old 08-11-2015, 04:22 PM
Norwood's Avatar
Norwood Norwood is offline
The core support is off?????didnt you tell me today you didn't take it off?
Old 08-12-2015, 10:38 AM
weranc55's Avatar
The next thing that's coming off is the subframe. I've done this so many times it makes me sick. My one blue car has been of the road for 9 years now.
Old 08-18-2015, 11:02 AM
bird72's Avatar
bird72 bird72 is offline
Has anyone here done a roller HO??? Info on results if so..... Would you HO guru's expect what from that build? I am hearing on a performance cam you can bet better idle with roller over old style. Along with HP better. Imaginary balanced HO with good forged pistons, stock 71 heads / intake, RA exhaust.... what bang for buck might one expect HP wise going roller over stock? HP potential gain? I know grind determines.... this for street decent mannered driving engine to maximize HP in 0-5500 band. Want as big power in street band as possible and still drive decently idle..... run AC / auto tranny 3.23....... winter build planning.... THX
72 Bird
Old 08-18-2015, 11:33 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Here's our experience...
http://www.hotrod.com/how-to/engine/...fix-up-part-1/
http://www.hotrod.com/how-to/engine/...fix-up-part-2/
http://www.hotrod.com/how-to/engine/...fix-up-part-3/
Old 08-18-2015, 12:19 PM
bird72's Avatar
Holy Smokes Rocky, that is incredible info. You answered everything definitively in one shot. That is close in many ways to build I envision. Should I seek bigger quadrajet with a 750 on hand now? The numbers you achieved are what I hoped. Plus 500tq plus 400hp..... that makes for a fun driver and if it is streetable and decently mannered to boot that is very very sweet. I'll print out to give to builder, thanks so much. Confirms all I have been advised locally by smart folk in engine biz.... these are not cheap builds it is the proverbial cliff jump... I will want everything done right and thought out. You saved the day sir!
72 Bird
Old 08-18-2015, 06:14 PM
SD455DJ SD455DJ is online now
Bird72,
Dan built the numbers matching 455 HO for Darrell Davidson's '71 Judge tha basically followed the Pure Stock Drag rules with the exception of a roller cam with roller rockers, so Darrell doesn't have to worry about ZDDP heavy oils. The heads, intake / exhaust manifolds, and 800 cfm Q-jet (7041273) are all factory, no gasket matching or clean-up, 9.5:1 compression with forged rods and pistons, factory crank and dynoed at 475 hp and 575 lbft torque through the manifolds after a little tweaking.
Darrell or Dan can comment further if I got some of the details wrong. It did surprise us with the big numbers. I can't recall the specs on the cam, but, I believe they were around 230/240 @ 0.050" and 0.530" lift ground on a 112 LSA.
This motor made a clean 50 hp and 50 lbft torque more than the pure stock 455 HO's with the 068 HFT cam.
Dennis
Old 08-18-2015, 06:16 PM
71HOT/A 71HOT/A is offline
I've had mine back in the car for a few months and could not be happier with how it performs. All forged lower like Rocky's but small domes to bring the compression to 9.8 to 1. The cam is a solid roller, 4/7 swap .582 lift 243/[email protected] 112 lsa with H.S. 1.5 rockers. The heads were ported previously so we left the ports alone and concentrated on the most accurate valve job possible. I couldn't say how much hp or tq but flooring it in third at 60 mph will spin the tires.
Old 08-18-2015, 06:20 PM
I forgot to mention this is with the 2.5 outlet manifolds and pypes crossflow exhaust. It is still very street and actually gets a little better mpg.
Old 08-24-2015, 10:31 PM
2manyT/A'S's Avatar
Default Back again......
http://seattle.craigslist.org/see/cto/5178330124.html
Eye Candy......garage band?
Go full screen & turn it UP!
Old 08-24-2015, 11:22 PM
Alvin's Avatar
Alvin Alvin is offline
Wink
Originally Posted by 2manyT/A'S View Post
IIRC - same pix as last time?
Old 08-30-2015, 09:27 PM
165th's Avatar
165th 165th is offline
Brewster, here's a pic that may be helpful. Note the cylinder numbers are stamped on each plug wire.
Name:	distributor cap wiring 2.jpg
Old 08-31-2015, 11:55 AM
wwilder9's Avatar
wwilder9 wwilder9 is offline
Hey Brian,
I was the guy holding the phone with the wire numbers wrote down on it, What I had on the phone that you guys gave me (from another car) compairing with the numbers on the wires above, we had the 3 and 5 switched, I think that was your problem.
68 Firebird Coupe 350/Auto/Air
70 RA III Formula/Auto/Air
71 T/A 455HO/Standard/Air
73 T/A 455/Auto/Air
Old 08-31-2015, 04:37 PM
bird72's Avatar
Looking for 71 HO intake & X-over if any HO people like trip over one walking in the woods or anything
72 Bird
Old 08-31-2015, 09:36 PM
Brewster's Avatar
Originally Posted by wwilder9 View Post
Hey Brian,
Okay, that makes sense and a good possibility. Will check it out this weekend and post the result. Sure gets frustrating at times.
Old 08-30-2015, 11:32 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
We have built 2 numbers matching 72 HOs recently. These were machined and prepared to OEM specs except for valve seat angles, hyd flat tappet cam timing (230/240) and 1.65:1 stamped rocker ratio. 435-462 hp and 555 TA. No port work or gasket match needed. Both very nicely restored. The difference we concluded was in the carb...one was that much better. Stock jetting in both. The torque and power are in there with a few smart parts choices. Good luck.
Old 08-31-2015, 08:08 PM
PureSD's Avatar
PureSD PureSD is offline
Pm sent
1970 Formula 400 RAIII 4spd. Lucerne Blue 12k mile survivor
1972 Trans Am Lucerne Blue /white 4spd
1973 Trans Am 455 4spd, White, POCI Gold 2012
1973 Trans Am SD455. Brewster Green, auto, 29k miles
1948 Lincoln Continental Cabriolet V12. Restored.
1951 Willys Jeepster 6 cyl.
1970 Olds Cutlass W31 4spd Rallye Red/White
1970 Challenger RT Convert,383 4spd. Hemi Orange
1971 Datsun 240Z 4spd.
1978 Datsun 280Z Black Pearl edition 5spd.
1983 Jeep CJ7 Renegade 5spd.
Old 09-02-2015, 05:45 PM
alloy indian's Avatar
alloy indian alloy indian is offline
Not really the place for this but they don't speak of ebay cars on the 67-69 tech so. Did anyone else see the one of eight trans am verts on ebay with a non original ram4 engine! Looks pretty sweet! seems legit D80 code and PHS.
