#201
Here is more progress, and in picture 4 you can see Ed's 68 Convertible Firebird, and 69 Camaro awaiting an IA2, Heads not yet determined. Oh and Picture 3 is Ed and 'Craig the truck driver.'
#202
merry christmas to you!
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
#203
I dropped of my '7F6' heads at R&L engines in Dover NH today. Having a few things done.
#204
Received a call from Leo at R&L Engines:
The heads have been disassembled, cleaned and checked for cracks; everything looked good. No problems with the guides and the valve seats are standing proud - new term I learned. We're gonna check the flow on a few ports before we move forward. I am probably gonna have the crossover filled. He said the existing port work was very mild, the stock shape was barely modified, all good news he said. Head flow results in a few days. Steve |
#205
Here are the Flow numbers.
Intake is listed first as 7F6.pdf, Exhaust is listed as 7F6E.pdf. Last edited by 67'7F6'Bird; 02-05-2010 at 04:35 PM. |
#206
Here is a chart comparing my 72 7F6 heads to my brothers RAIV's.
#207
Click on Chart.
#208
Here's a picture of the head, valve bowl area cleaned up and valve job performed.
Still need a little more work before reassembly. |
#209
I got my heads back from R&L today. The ports look really good and the flow has now been corrected and increased. Thanks to LEO at R&L and Len Caverly for their help on these old heads.
#210
I have attached the FINAL FLOW CHART for my 72 7F6 heads.
Click on link. |
#211
My 455 block has finally been rebuilt by Lawrence Crankshaft.
I should be able to pick it up this weekend. Honed, new bearings, turned crank. |
#212
My Brother Ed and I started to get the engine back together. Cleaning out all the threads to get ready to install the ARP Head Studs. Twist them in until they bottom out, then loosen a 1/4 turn. Molly lube is used on all the threads. More assembly today.
#213
More assembly pictures.
We did find out that my new louvered CANTON Windage Tray doe not fit with my aluminum rods. The lower 2 louvers need to be modified. |
#214
We installed the Solid Roller Cam this weekend. We are going to degree the cam in next.
#215
Working on installing the fuel system.
Aeromotive A1000 Pump 10 and 100 micron filters 10 AN push lock hose for both the feed and return line |
#216
Installed the new disc brake dust shields, painted all the support bars for the front suspension and brakes. Installed the master cylinder and new stainless brake lines from INLINE TUBE.
#217
Great work, I have been following this thread for a while. From pics 1 and 4 in post #216 it appears that the calipers have been installed on the wrong sides, as I believe the bleeder should be on the top side of the caliper, this will allow air to escape the system when you bleed. Please others chime in to confirm this.
#218
Good catch Tempest, you're right, the bleeder should be up.
#219
HO 455 Being installed today.
#220
I don't think it will fit under the hood!
