Old 07-09-2011, 11:18 PM
cnc's Avatar
cnc cnc is offline
Chris ......Fabulous lookin machine................love it
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #202
Old 07-10-2011, 05:50 AM
LeighP's Avatar
LeighP LeighP is offline
Love the colour combo....already looks great!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #203
Old 07-10-2011, 09:52 PM
Wow, Chris... getting really close! Still love that color - it really pops.
  #204
Old 07-30-2011, 03:16 PM
Default Getting close
I'm almost to the point where I can start up the car. I would have been there a month ago if not for the fitment issues I have had with the Pypes system I bought. As it stands right now I will need to take the car to a muffler shop for final fitment, but that is a story for another day. Everything on the engine is ready to go. I hooked up an oil pressure gauge in the engine bay so I can monitor the pressure during cam break-in. I primed the system with a drill and I have 60 PSI, so I'm good there. I poured the coolant in this morning and filled the block through the temp sender hole in the intake. The distributor is in and the plug wires are on. I just need to drop the car down and put gas in it. I bought a cheap fluid pump to prime the fuel lines and I intend to hook it up at the fuel pump so I can get gas all the way up to the carb. That way the system will be fully primed (and the carb bowl full) when I crank it over. If I did everything right it should start right up. A good friend of mine is coming up next Friday and we will go ever the car together to recheck everything. If all goes will, it will be running then.
ID:	251911   Click image for larger version
ID:	251912   Click image for larger version
ID:	251913   Click image for larger version
ID:	251914   Click image for larger version
  #205
Old 07-30-2011, 03:20 PM
More pictures. The last one shows the open face alternator. I bought it off a guy on ebay who rebuilds alternators. It cost me about seventy bucks shipped, and as you can see, it is rebuilt and in nice shape. It does not have the correct rear case, and there are no numbers on it, but on first glance it appears correct, and I see no need in using my 1100902 on a non-numbers matching car.
ID:	251916   Click image for larger version
ID:	251917   Click image for larger version
ID:	251918   Click image for larger version
  #206
Old 07-30-2011, 04:38 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Wow - looks great! Get Kenny (Getridaone) to tell you the story of starting up his formy for the first time! Good luck with it - I bet you break out in a big grin everytime you look at this car now that its back together...congrats!
BJ
  #207
Old 08-06-2011, 12:23 AM
I finally started the Formula up today. I had some trouble with the fuel lines, for some reason the metal line from the middle of the car up to the fuel pump is completely plugged. I couldn't even clear it with 100 psi of air pressure. I bypassed it with rubber hose in order to start the car but I'll need to replace the metal line. It would have been easy with the engine out, but now I expect it will be a real pain in the a**. Anyway, the car started right up and ran fine during break in. (Sorry, no video since I had my hands full, but here is a picture of it out in the sun). The engine had good oil pressure and the temp never went above 190. I have some things to take care of before I take it for a drive, but it sure was nice moving it back into the garage under it's own power instead of having to push it.
  #208
Old 08-06-2011, 07:37 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Looks great, nice work! Bet you can't wait to take it for a spin.
  #209
Old 08-06-2011, 08:01 AM
Pepi's Avatar
Pepi Pepi is offline
Looks really sharp. It's always something like that with the fuel line,. good ole hind sight.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #210
Old 08-06-2011, 08:45 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
congrats on getting the motor running, the car is looking great!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #211
Old 08-07-2011, 12:05 AM
LeighP's Avatar
Car looks great. Congrats on the start up going well!
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #212
Old 08-07-2011, 10:26 PM
wwilder9's Avatar
wwilder9 wwilder9 is offline
Great car!!!!!
68 Firebird Coupe 350/Auto/Air
70 RA III Formula/Auto/Air
71 T/A 455HO/Standard/Air
73 T/A 455/Auto/Air
  #213
Old 08-07-2011, 11:25 PM
FirebirdScar FirebirdScar is offline
Car looks Great, you have really done a nice job!
  #214
Old 09-10-2011, 01:11 PM
I towed the Formula to the exhaust shop yesterday and had them "massage" the Pypes kit. It took them three hours to get it to fit correctly. I'm real disappointed in the overall cost of the exhaust system, but that is a story for another day. I have been slowly getting the little stuff taken care of. I fixed the gauges, tail lights and flashers, installed the rear window trim and trunk weather strip, etc.... I had hoped to take it for a drive today but there is something wrong with the carb. I'm not getting a pump shot. I've had the top off and blown the passages out but to no avail. as soon as I come off idle it falls on it's face. I'm going to try a known good carb before I do anything else to this one. It's always something, but at least it looks good sitting in the garage. Anyway, here is some video.
http://www.youtube.com/watch?v=u4Dt0b73Zrc
  #215
Old 09-10-2011, 01:33 PM
unruhjonny's Avatar
nice!
So (at the chance of repetition) what's going on with the interior?
I saw no carpet, missing console, a nice stock dash, and some nice (albeit customized cloth covered) seats...
1970 Formula 400
  #216
Old 09-10-2011, 01:44 PM
Those were the seats that were in the car when I got it. I don't recognize those seat covers as being from a Pontiac so I assumed they were custom made (or maybe from a camaro?). A previous owner had rattle canned the interior in saddle but I intend to return it to deluxe sandlewood. I don't have the money to do the interior right now but needed shelf space so I stuck the seats in the car.
Originally Posted by unruhjonny View Post
nice!
  #217
Old 09-10-2011, 01:52 PM
unruhjonny's Avatar
oh no, those are 1970 Firebird seats ~ but they were recovered an the inner section was replaced with a cloth;
other than that, they're done correctly (as in pattern)...
I've seen some terrible recovers - and I wouldn't put those in the terrible group...
also, if your rear seatback & seat bottoms are a wire seat with burlap materila, you're set ~ because after 1973 the seat construction changed and the seat width actually changed;
if you have the right seat backs, then you're going to be good with a set of repop covers should you ever decide to go that route.... otherwise you're going to need to get a set of corresponding 1970 front covers and later back covers...
I found out all this the hard way;
I threw out my original rear seat back (back in 1995);
then upon purchasing seat covers ended up stealing the seat back out of my '73 for the '70 (otherwise the repop seatcover I had bought would have been useless - later seats are thinner);
I just recently acquired a correct replacement seatback for the 73.
1970 Formula 400
  #218
Old 09-12-2011, 07:49 AM
damannhw's Avatar
damannhw damannhw is offline
Looking good Chris. The paint sure looks nice out in the sunlight !
'70 Formula 400
'64 Tempest
David
  #219
Old 09-12-2011, 02:36 PM
RicksGTO's Avatar
looks great Chris! Ride height is coming out nice too. I'm finishing up the install on the same exhaust system that you used and had to bend the passenger over the axle pipe a good bit to get it away from the driveshaft/u-joint and to line up with the legs of the X pipe. No way would it have lined up right out of the box. The sound on yours is great, congrats on reaching this point and look forward to hearing about your first drive in it.
  #220
Old 09-12-2011, 03:52 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thumbs up
Love it! Congrats!
Which muffler did you choose with the PYPES system, by the way? It sounds fantastic at idle!
Regards,
"455HO" Lloyd
