Old 04-29-2019, 11:05 AM
Formulajones's Avatar
I think that's what we are all trying to do here, talk about cars. But your people skills are lacking a bit. I've seen nothing in here but help and good suggestions be ridiculed unnecessarily. More of an open mind and thicker skin would go a long way.
  #202
Old 04-29-2019, 11:17 AM
Stan Weiss's Avatar
This thread is like a train wreck that one can not stop looking at.
Just changing cams again is not the answer.
When the original Edelbrock cam had its phasing changed. Do not know if it was then exactly correct but it was much closer to correct then when you started. You said you could not get it to run right. That was the point to find out what was really wrong.
Stan
Pontiac Pump Gas List
  #203
Old 04-29-2019, 11:18 AM
TAQuest TAQuest is offline
Upon teardown I find that the lifters are still adjusted within the lifter plunger travel.
New parts will be here tomorrow and I will start the reassembly then.
Totally enjoying working on my car.
Should have it running again this week.
  #204
Old 04-29-2019, 11:23 AM
Stan
I posted all about why it didn't run. It's not an issue anymore.
  #205
Old 04-29-2019, 12:15 PM
STEELCITYFIREBIRD's Avatar
Originally Posted by TAQuest View Post
I will not have to get way more in depth with tuning with the right cam. I know that from experience.
Sooo, curious...what "right cam" is going in next?
  #206
Old 04-29-2019, 12:20 PM
2157
  #207
Old 04-29-2019, 12:25 PM
Wow, not going to make much use of those heads. Time will tell!!
Hope you got more RTV!
  #208
Old 04-29-2019, 12:30 PM
Steve C. Steve C. is offline
"Wow, not going to make much use of those heads"
X2
Ummmm...... .420" valve lift in heads that flow above .600" lift
And probably still with the Edelbrock single coil springs with the unknown spring pressure !!!!
Old information here:
  #209
Old 04-29-2019, 12:37 PM
Edelbrock Performer-Plus Camshaft # 2157 is designed for 350-455 Pontiac V8 engines and produce optimum torque from the low-end to the mid-range. Performer-Plus camshafts should be matched with Performer manifolds for vehicles operating from off-idle to 5500 rpm. The Performer-Plus # 2157 is a smooth idling cam for daily drivers, trucks, vans, RVs and 4x4s. You can expect a major improvement in throttle response and torque. In the manifold section you'll find torque graphs showing the power gains from Performer manifolds and Performer-Plus cams. All camshafts include flat tappet lifters (except for cams designed for use with stock roller lifters), assembly lube and instructions. This cam produced 387HP and 439 Ft Lbs of Torque when paired with Performer intake manifold # 2156 and Performer RPM cylinder heads # 60599.Camshaft specifications:• Intake duration: 204 Degrees • Exhaust duration: 214 Degrees • Intake lift: .420” • Exhaust lift: .442” • Lobe separation: 110 Degree • Intake Center Line: 105 Degree • Vacuum: 15”
  #210
Old 04-29-2019, 12:38 PM
It's got a TDC reference... FWIW now.
  #211
Old 04-29-2019, 01:08 PM
promptcritical's Avatar
promptcritical promptcritical is offline
2157
Oh my goodness...
  #212
Old 04-29-2019, 01:15 PM
https://www.youtube.com/watch?v=mIjZE4kcg_Q
  #213
Old 04-29-2019, 01:59 PM
Stan Weiss's Avatar
Chances are just about zero that Edelbrock ground that cam.
Chances are just about zero that Summit ground their 2800 cam.
Chances are very good that they are the same cam ground by the same company. Yet look at what Summit says about that cam.
https://www.summitracing.com/parts/sum-k2800
Stan
  #214
Old 04-29-2019, 02:00 PM
"This cam produced 387HP and 439 Ft Lbs of Torque when paired with Performer intake manifold # 2156 and Performer RPM cylinder heads # 60599."
Bingo...
  #215
Old 04-29-2019, 02:06 PM
Is that a roller cam?
  #216
Old 04-29-2019, 02:07 PM
Note here it indicates a single-plane intake in the attached dyno chart. ..
https://www.edelbrock.com/performer-...3-v8-2157.html
  #217
Old 04-29-2019, 02:42 PM
Dyno comparison on the intakes;
https://www.youtube.com/watch?v=i2DvnoHWagk
  #218
Old 04-29-2019, 03:13 PM
Your point ?
It really doesn't matter because you already have the Performer intake. And take the dyno numbers stated by Edelbrock with a grain of salt !
Onward thru the fog.
  #219
Old 04-29-2019, 03:30 PM
  #220
Old 04-29-2019, 04:01 PM
Stan Weiss's Avatar
While it is old school I would look at an "068" installed on the factory ICL. ....
Stan
I hope that it turnout that you are very happy with the Edelbrock cam. As we all have a different idea of how we want our car to behave, we will each chose a different cam. But I am still going to go with what I posted almost a month ago. Which is a Pontiac cam that is about one step hotter than the Edelbrock cam. I think that would be the best all around cam for you.
Stan
