Old 10-23-2023, 11:01 AM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Okay, Numbers are as follows:
VIN# = 233371P160219
Body build date = 05C which I understand means May 3rd week (05=5; C=3rd)
Engine block date code= E21 = May 2, 1971
Engine block VIN# 21P 160219
Transmission VIN number = 21P 160219
Transmission date code = B21 = February 2, 1971
So, it looks like all the numbers make sense that everything is original!
Name:	Trans VIN number.jpg
ID:	622112   Click image for larger version
Name:	Trans date code.jpg
  #202
Old 10-23-2023, 08:58 PM
If you find a Buildsheet in the car , it would have RM coded in the transmission designation box.
M13 also came behind 69 & 70 Ram3 engines and 70 455HO engines.
They are tuff units.
  #203
Old 10-23-2023, 08:59 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Fantastic!
Nice to have all the original parts if you decide to keep the car stock.
I built a mild stock 455 for my 72 GT, and simply set the original 350 on a stand in the corner of the shop as others have mentioned. I've learned that I enjoy the car much more this way.
Should I ever decide to sell the car, I would simply put the original 350 back in, and sell it that way. Most guys will want to install their own drivetrains, so original engines really never go back into a car once they're out.
That being said, put in what you want for now to enjoy, but keep the original in the corner for the day you decide to sell, then return it to original condition. Let the next guy decide what he wants to do with it then.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
  #204
Old 10-24-2023, 09:45 AM
79 Phoenix's Avatar
Yes, RM is in the transmission box on the buildsheet!
  #205
Old 10-24-2023, 09:59 AM
79 Phoenix's Avatar
Originally Posted by Mister Pontiac View Post
Fantastic!
I would love to set the original aside and build a 400 or 455 but am under pretty tight budget constraints.... It will cost about $3500 to have this original completely rebuilt at my local machine shop. I could buy a used 400 for maybe $2000 but then have to spend another $3500+ to have it rebuilt... So, as near as I can tell, I would have $5500 into the engine alone.
Part of my problem is my unfamiliarity with Pontiac engines with regard to interchangeability of parts, which are the best parts, where to get them, problems to look out for, etc. I successfully built the 350 chevy in my 79 Phoenix but SBC's are seemingly much simpler. I'm a little scared of the idea of building a Pontiac engine.
Does this reasoning sound realistic?
  #206
Old 10-24-2023, 10:28 PM
If you could happen to find a bare 400 block on the cheap side, you could use everything from the spare 350 - and have the crank rods pistons balanced.
Or a 400 short block on the cheap.
400 pistons are about the cheapest ones off the shelf.
350 oversize pistons are usually custom ordered these days $.
Maybe even a 455 short block ,, if the #94 heads are around 95cc combustion chambers
I wouldn't want to throw that kind of money at a 350 2bbl
  #207
Old 10-24-2023, 10:32 PM
"Almost" everything is interchangeable on Pontiac engines from 326 through 455.
421, 428, 455 use bigger crankshafts
  #208
Old 10-25-2023, 12:09 AM
Phoenix, I can understand your hesitation with budget constraints, but as far as your skills? If you have successfully built a SBC, you can certainly build a Pontiac. Sure, they're different, but they're actually extremely straight forward with a ton of interchangeable parts (as mentioned).
Another thought...
I love to find a 'good used' engine when possible. Someone will have a good running 400 they pulled to drop in a 455, or perhaps a wrecked car with a good running engine. If you can find one of those, I think you'll come in well under your stated budget. I've done this very thing for years when I need a 'place holder' and just want to drive the car.
You're well on your way with the brakes done and original engine/trans pulled. Finish up the fuel system rebuild, meanwhile, see if you can't find a good running 400 or the like for half the price of your estimated rebuild cost. Cleanup the Muncie, drop it back in, and go spin the rear tires! It's one of the fastest, most cost effective ways to get your car back on the road where it's always more fun.
To quote Frieberger from Roadkill, "Don't get it right, just get it running!"
There will be plenty of time to rebuild that 350 later as funds become available, but you'll be thousands of miles and smiles down the road by then.
Eric Mitten
Deuteronomy 8:3
The Following User Says Thank You to Mister Pontiac For This Useful Post:
  #209
Old 10-25-2023, 02:31 PM
79 Phoenix's Avatar
Default ARE THESE MARKS IMPORTANT?
I'm cleaning off the firewall... Are these marks important regarding the car's value? This restoration is intended to be really nice but not Concourse.
  #210
Old 10-25-2023, 06:15 PM
It wouldn't hurt to document them with some clearer pictures.
I can make out the 19 - which should be paint code for Black.
But I wouldn't put them back on it. (personal opinion / preference)
The 69 engine & tranny deal isn't real bad..
The others are really high.
73 TA only came with 455's and 4bbl's - you will have to crunch the numbers and letters on any prospect to authenticate - like you did on your blocks and heads.
Very few folks actually know what they have or have not.
All you need is a good 400 block.
Or maybe even check with a company like Jasper on a 400 short block already assembled.
You would have to eat the core charge though.
The best deals on full engines are usually from 68-70 Grand Prix 400
You get really good heads and 4 bbl intake/carb
  #211
Old 10-25-2023, 07:10 PM
SD455DJ SD455DJ is offline
I totally concur with the 400/455 sentiment from Mister Pontiac and BVZ if you have to rebuild the original 350 anyway. You might as well invest the same $$$ into a bigger engine, which will not hurt the value of an original 350 GT-37 one bit...most likely add value. Just store the original engine in the garage and it stays with the car if you ever sell it down the road. You can still find the early (pre '75) 400's relatively easy and affordably. Like BVZ mentioned, that '69 400 2-bbl engine looks like a great candidate.
I have a '70 Lemans 4-dr post sedan that I swapped out the original 350 for a 455 from a '70 Bonniville. I found the 455 for $500. It was the small valve 360 hp variant and I kept the small valve heads and log exhaust manifolds and it made 390 hp at 512 lbft torque on the dyno with a little bigger cam (Summit 2802) than stock. I'm so glad I did as the car is a blast to drive.
You'll be glad you made the upgrade to more cubes for the same costs.
Dennis
ID:	622237   Click image for larger version
Name:	70 YH 455 Dyno.jpg
  #212
Old 10-25-2023, 07:26 PM
79 Phoenix's Avatar
Yes 19 is the number for Starlight Black which my car's color. There is an "X" below that. I can't make out the other mark.
I might inquire for more info on the 69 engine & tranny. Don't need the tranny. Maybe he would sell the engine alone for less. Sounds like it has been inside for some years but maybe he knows more. I assume it would be better to have an engine that has original parts...rods, crank, etc.
  #213
Old 10-25-2023, 10:44 PM
79 Phoenix's Avatar
The 69 400 engine could be had for $500 without the transmission.
STORY ON THE ENGINE GOES LIKE THIS: It ran 12 years ago when the guy bought a 68 firebird with this engine in it. The guy he bought it from had started building the Firebird back in the 80's but never got it on the road. The current owner ran it for just a few minutes just to make sure it ran and said it sounded ok even though it was loud with no exhaust. Thinks it's from a B body car originally. Current owner never finished the car and then junked the car and moved the 400 into his garage for the past 4 yrs. Now he needs the space and wants to sell.
I wish it wasn't 4 1/2 hrs away....
https://pittsburgh.craigslist.org/pt...674541487.html
  #214
Old 10-27-2023, 12:35 AM
Couple thoughts of mine, Phoenix...
I would preserve the markings on the firewall if it were me (I did on my 67 GTO), but as others have said, personal preference. I don't know if it's make or break to the next guy. I would want them, others could care less.
That 400 is interesting. To me, $500 is fair for a complete engine. Being 1969, it could still be a higher compression engine. No way to know unless the guy can get you the head numbers, but before I did a 4.5 hour drive, I'd want to know what exactly it is. I'd ask for the block code and all the date codes too, but he may or may not be willing to help.
In this day and age, if you're planning a lot of driving, I'd look for a 71-74 engine. If it's still untouched, you would get a low compression (pump gas friendly) hardened valve seat version, and the stronger (relatively speaking) block vs 75 & up. Additionally, a 71-74 is probably less desirable to most guys than the 70 and earlier versions. But for your purposes, absolutely perfect. Drop it in and go. That would be my vote. I'd keep looking.
Keep up the good work, and keep after it! While you've got the project momentum, don't stop until it's running and driving again. Nothing more motivating than that!
Eric Mitten
Deuteronomy 8:3
  #215
Old 10-27-2023, 09:53 AM
79 Phoenix's Avatar
Thank you guys for all the input on this.! I appreciate it your help. I have checked with Jasper and they have no 400's or 455's --short or long block-- on the shelf but would only take a 400 from me and rebuild it. So that's out...
Regarding the $500 400 , I have asked him for block code, block date code and head code...Says he hurt his back and off his feet now... when he's able he will send pictures... I don't want to drive 4 1/2 hrs one way without knowing what it really is.
I have checked in classifieds on this site but haven't found anything yet that seems right. I live in PA so distance can also be an issue. If anyone hears of a possibility, please let me know.
So, at present engine progress is stopped... Much more to do on the rest of the car though so progress overall will continue.
  #216
Old 10-27-2023, 07:24 PM
79 Phoenix's Avatar
I checked with JASPER and the only way they could get me a rebuilt 400 short or long block is if I sent them one to rebuild... So that not an option.
I got more info from the guy with the short block (link below). He took some pictures for me (below). It is a YS block dated April 21, 1971. The 71 YS block was apparently for 300 HP 400's backed by Turbo 400's. They put them in GTO's, Firebirds and B-body cars. He said he sold the heads #96 off it in years past... Said he thinks it's std bore but couldn't find any markings...
$1400 seems like a lot for a short block without heads... I would also have to assume it needs bored, new pistons and crank turned*(not sure what all that would cost). It's only 2 1/2 hrs away.
https://annapolis.craigslist.org/pts...675788752.html
ID:	622356   Click image for larger version
ID:	622357   Click image for larger version
Name:	71 YS  3.jpg
ID:	622358   Click image for larger version
Name:	71 YS  2.jpg
  #217
Old 10-27-2023, 11:35 PM
That would be a fairly 'correct' 71 400 for you (YS would have been from an automatic car, but regardless), $1400 is too high for a core short block, IMO.
If it was a complete engine, especially with the #96 heads, then I would say you might have something.
Personally, I would pass on this one too.
But since you have a lot of other things to do on the car, keep at it. The right engine will pop up. Keep an eye on the classified's here on the forums too. Someone up in your neck of the woods may have just what you need.
Eric Mitten
Deuteronomy 8:3
  #218
Old 10-28-2023, 07:58 AM
X2! Way too expensive for a short block! That's the price of a complete engine in my book...carb to pan. Keep looking like Mr. Pontiac said. I paid $400 each for the last '70 400 (complete std. bore) and '73 455 long block (+ .030"). A couple of my cars have 'transplant' engines in them and 99.99% of people never know, look, or ask...even a Pontiac shows. Some have the same year heads so the casting numbers look kosher to the inspectors.
Dennis
  #219
Old 10-28-2023, 09:45 AM
79 Phoenix's Avatar
Yes, seems very high. I blew up the photo of the top of the piston and see what may be a .040.
I'm almost tempted to go get the $500 one but what if I get there and find it's not really a 400? It could be but without pictures, who knows?
So I will keep working and keeping my eye open for the right engine.
Name:	71 YS  3.jpg
  #220
Old 10-28-2023, 04:18 PM
79 Phoenix's Avatar
I found another 400 on craigslist that posted today... It's a 76 which I know are not the most desirable blocks but sounds like it shouldn't need a lot of machine shop work... I asked several questions and his answers are below...
He was asking $1800 for both engine and transmission... However, I see ad is already gone so it may already be sold. But what do you guys think of a later 400 like this? It sounds stock and it has 6X heads... probably quite tame... ANY THOUGHTS?
1. Was rebuilt before I got the car , which I bought from second generation engineering shop in NJ right before Covid. Has rebuilt starter, rebuilt alternator , cam bearings ,timing chain,etc
2. I believe its bored 30 over
3. Pretty much stock
4. The rope seal leaks it’s 2 piece stock Pontiac and they are known to leak ,I would put a new one piece rope seal solve the leak issue. Doesn’t knock smoke or tick runs great. It has a Quadrajet on it I would change to Holley unit personally.
5. I removed it because my friend convinced me to go to a newer fuel injection LS motor which I still regret doing, I should’ve kept this drivetrain in cost me a lot of $ to changeover and now no going back.
6. Would like to sell the drivetrain as a whole.
Thanks for your interest in it any other questions let me know I’ll try and answer best I can
