Old 09-13-2011, 11:49 PM
LeighP's Avatar
LeighP LeighP is offline
Yeah...sounds good!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #222
Old 09-16-2011, 01:20 PM
Rick,
The rear of the car still sits a little too high for my liking but I'll wait till the end to deal with it. The biggest problem I had with the exhaust was on the passenger side where the pipe came out of the muffler and went over the differential. The pipe literally sat on the fuel line at the corner of the tank. It's still pretty close so I will be swapping out the rubber hoses to something more heat tolerant just to be safe. I was also very unhappy with how low the pipes sat where they came off the manifolds. I wanted them to tuck up close so I had them cut and shortened there. It's a good fit there now.
Originally Posted by RicksGTO View Post
looks great Chris! Ride height is coming out nice too. I'm finishing up the install on the same exhaust system that you used and had to bend the passenger over the axle pipe a good bit to get it away from the driveshaft/u-joint and to line up with the legs of the X pipe. No way would it have lined up right out of the box. The sound on yours is great, congrats on reaching this point and look forward to hearing about your first drive in it.
ID:	256899   Click image for larger version
ID:	256900   Click image for larger version
  #223
Old 09-16-2011, 01:21 PM
Lloyd,
I used the RacePro muffler.
Originally Posted by Lloyd-TX View Post
Love it! Congrats!
Which muffler did you choose with the PYPES system, by the way? It sounds fantastic at idle!
  #224
Old 09-16-2011, 02:12 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thumbs up
Originally Posted by eaglesan13 View Post
Lloyd,
Thanks!
Regards,
"455HO" Lloyd
  #225
Old 09-16-2011, 08:59 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
looks like it ended up fitting great and has a lot of ground clearance. I'm cutting the head pipes the same way to make them tuck up better. I think they use the same headpipes for several applications and aren't really designed specifically for our cars.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #226
Old 10-14-2011, 07:19 PM
Default On the road again...
I've been tinkering with the carb for a while now and finally got it dialed in. It's still a little cold blooded but it runs pretty well when at operating temperature. I went to the DMV this morning and got my registration, so now I'm legal. So, after owning the car for three years, I finally took it for a drive today. It still needs the interior done, and I will need to lower it down a bit, but at least I have a driver.
http://www.youtube.com/watch?v=KX0hdJ76xfc
http://www.youtube.com/watch?v=SL6o8lbDnL0
  #227
Old 10-14-2011, 08:03 PM
Awesome, Chris. Congrats!
  #228
Old 10-14-2011, 10:19 PM
Formulabruce's Avatar
Nice to see those Videos Chris!! Look great!
" Long may we DRIVE !"
  #229
Old 10-15-2011, 07:11 AM
cnc's Avatar
cnc cnc is offline
Looks and sounds Great Chris....keep goin.....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #230
Old 10-17-2011, 11:24 AM
damannhw's Avatar
damannhw damannhw is offline
Way to go Chris ! Bet that first drive was a blast. Congrats
'70 Formula 400
'64 Tempest
David
  #231
Old 10-17-2011, 10:44 PM
Thanks Dan. I keep waiting to see pics of your car posted on the forum, can't you quit driving it long enough to have a picture taken?
  #232
Old 10-18-2011, 07:27 AM
damannhw's Avatar
You betcha !
'70 Formula 400
'64 Tempest
David
  #233
Old 10-18-2011, 11:41 AM
OVERULD's Avatar
OVERULD OVERULD is offline
Car looks great Chris - great videos. Is that a flex fan sound I'm hearing as the car approaches the camera?
BJ
  #234
Old 10-18-2011, 10:03 PM
Yes, I used a flex fan I had and it's pretty loud. I will swap it out this weekend and hopefully I'll be able to hear a little more exhaust and a lot less fan.
BJ
  #235
Old 10-19-2011, 12:06 PM
OVERULD's Avatar
Yep - that will make a difference. Car looks great - sort of reminds me of my 74 Fire Coral Bronze Formula 455. Love to have that one back!
BJ
  #236
Old 04-01-2012, 06:41 PM
I'm back working on the car. I was trolling Craigslist a few months ago and saw an NOS set of wheel opening moldings so I bought them. I installed them today along with the wheel trim rings. The trim pieces on this car really accents this color well. Maybe I should add the roof moldings and decor trim.
  #237
Old 04-01-2012, 08:59 PM
Very nice !
  #238
Old 04-01-2012, 09:08 PM
The carpet arrived this week along with a bunch of other stuff I ordered. My upholstery guy told me to lay it out in the sun to get rid of the wrinkles before we install it. The second picture shows the under dash filler panel sitting on the carpet. The panel has already been painted the correct dark sandlewood and it's an almost perfect match for the rubber pad in the driver's foot well.
ID:	280306   Click image for larger version
  #239
Old 04-02-2012, 10:36 PM
My new rear inner trim panels arrived last week and the console showed up today. I am using the 71 style panels since the 70 style is not available, besides, I think the stitched insert looks nice. It was 70 degrees today so I went ahead and painted them. I'm using the PY interior paint which is a pretty good match. Picture number three shows one of the door panel pockets. The inside of the pocket has been painted and the outside is unpainted, so you can see how close the color is.
As for the console, I'm not sure how to prep this for paint. I used plastic prep on the inner trim panels but the console looks like it may have a vinyl "skin" on it which means maybe I should use vinyl prep on it. Has anyone painted a repop console?
I think I read somewhere on the boards that the metal brackets should be removed from the original console and used on the repop, and to use special bolts with with a head that looks the same as the original rivets, does anyone know where to get those?
ID:	280427   Click image for larger version
ID:	280428   Click image for larger version
ID:	280429   Click image for larger version
ID:	280430   Click image for larger version
  #240
Old 04-03-2012, 06:46 AM
LeighP's Avatar
That is a nice match.
I just received my new set of these upper and lower rear trim panels for my 71. They are very nice looking pieces.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
