Old 12-29-2011, 08:11 PM
LeighP's Avatar
LeighP LeighP is offline
Well, to complete the facia of the dash, I finished the LH side where the switch gear goes. No face level vent in my car (was an A/C car) so I used that area for locating some switches for lighting etc.
Made up a doubler to fit the back of the dash, painted satin black to match the other side.
Urethaned that into the dash facia and when cured, mounted up the switch gear.
Switches are (from top Left)
Dome Lt Head Lt
Rear Demist Park Lt
Trunk Release Inst Lt
The wiper switch opening is set up for the DSE wiper kit switch and the old headlight switch position was perfect for the starter switch. I have to research up a little first, but if my alternator requires a warning lamp (some do, some don't), I'll mount one where the "LIGHTS WIPER" plastic sign used to sit.
Now all I have to do, is loom it all up and fit some plugs, so I can easily fit/remove the facia as needed.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #222
Old 12-29-2011, 10:54 PM
lumarkhood lumarkhood is offline
Can't wait to see more green paint!
Those gauges look very cool...have a "retro" look. Nice choice.
Mark
Trans Am's, Formula's, Mustang, GN...
  #223
Old 01-06-2012, 01:28 AM
LeighP's Avatar
Been working on the wiring looms for the dash, I want to make it modular so I can remove and replace the dash just by disconnecting some plugs.
Panel shop guys are still playing with the gaps, trying to get the nose right....they fitted up the Aerocatches yesterday. Their painter isn't back from holidays for another week, so I guess theres time for them to tweak the bodywork.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #224
Old 01-07-2012, 04:40 AM
LeighP's Avatar
Still playing with the dash wiring...today I got the main instruments and the starter switch wired to plugs.
Just the billet switches on the side to do now...those are a little fiddly as I have to solder the wire connections to the pins on the switches.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #225
Old 01-08-2012, 03:31 AM
LeighP's Avatar
Had a quiet afternoon - everyone was out, lol.
Got a chance to finish off the dash wiring.....a couple of more plugs than I intended, but with the pulse generator for the speedometer and all the button switches with LEDs in them it got a little more complicated.
Annoying soldering wires to the button switches....my small circuit board soldering iron doesn't put out enough heat to solder the wires, and the larger one I have is a bit tight to work with in the small spaces between the pins....
Heres the connections on the button switches, the LEDs light up when the switch is selected on...I tested them and they work fine.
And heres the finished dash from the rear. All the looms are designed to pass through the structure of the dash itself, so I didn't have to cut anything behind there for clearance.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #226
Old 01-08-2012, 04:02 AM
Formulabruce's Avatar
Great work!! Ever try a "Cold solder" iron? Only heats when it touches, runs on batteries and has pointed tip. Would be perfect for that work.
Looking good though! Guess that hood will be secure!
  #227
Old 01-08-2012, 04:14 AM
LeighP's Avatar
Interesting...never heard of a "cold solder" iron...guess it shows I don't do much electrical work, my soldering irons would be 25+ years old probably. lol.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #228
Old 01-13-2012, 11:03 PM
LeighP's Avatar
So, I'm still doing small projects to fill in time and save time later.
Fitted up the Autometer Trans Oil and Engine Oil Temp gauges to the A pillar pod housing I got from Anvil Autos. They do lots of cool CF parts for 2nd gens.
And I fitted up an eye level centre brake light to the rear headliner trim retainer, as well as refinishing the front and rear trims in satin black.
The pegs are just holding the wiring where I've bedded it into some sealant while it sets - to stop it moving around.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
The Following User Says Thank You to LeighP For This Useful Post:
  #229
Old 01-20-2012, 10:19 PM
LeighP's Avatar
OK...so we've reached the stage where theres enough progress to warrant more pics.
Car is back in pieces, getting the final undercoat - it'll be blocked and get the base colour on it next week.....theres a public holiday coming up, so its a short week, but at least it should be in the base colour.
Heres a pile of Firebird parts ready for priming.
Doors are done.
And the body freshly primed.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #230
Old 01-25-2012, 12:13 AM
LeighP's Avatar
WE HAVE SOME COLOUR!!!!!!
Well, its only the base colour, they still have to apply the top colour (pearl green) over the base, but he's identified a couple of extremely slight low spots he wants to fix first....so since tomorrow is a public holiday, the guys are also getting friday off to make a long weekend...so mine will sit till next week...hardening up a little.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #231
Old 01-26-2012, 02:01 AM
1973T/A's Avatar
1973T/A 1973T/A is offline
WOW. I love the green! great looking car! coming along nice.
Pax
  #232
Old 01-26-2012, 08:25 AM
LeighP's Avatar
Wait till you see the final colour!!!
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #233
Old 02-01-2012, 03:38 AM
LeighP's Avatar
FINAL COLOUR!!!!!!!
They phoned me late today....seems the booth was free and the painter was keen to paint it....
Even the panel shop owner is impressed with the colour choice.
Without further delay.....the shell - freshly painted.
Is that cool, or what? The pearl in the paint really shows off under the lights of the booth - I can't wait to see this in the sun. And this is just "off the gun".
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
The Following 2 Users Say Thank You to LeighP For This Useful Post:
  #234
Old 02-01-2012, 08:38 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Looks great Leigh! You can see that it needs the final color sand and buff but wow, it looks amazing! Congratulations!
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #235
Old 02-01-2012, 10:48 AM
72Formula's Avatar
72Formula 72Formula is offline
I have never been a fan of green on a car...til now. Very Sharp!
  #236
Old 02-01-2012, 11:49 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Leigh, that looks awesome, love the color!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #237
Old 02-01-2012, 02:46 PM
ClobberBird70's Avatar
ClobberBird70 ClobberBird70 is offline
I've always had a soft spot for Green, that will REALLY pop when its together with some chrome/stainless. Very cool!
  #238
Old 02-01-2012, 04:38 PM
LeighP's Avatar
Thanks guys....and its a factory GM colour, too.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #239
Old 02-01-2012, 10:11 PM
165th's Avatar
165th 165th is offline
I guess it's white cotton gloves from here on in. Great looking color and lines. Good luck with the buff and completion of the project.
  #240
Old 02-04-2012, 05:46 PM
niceta's Avatar
niceta niceta is offline
Very nice paint. Looks like it's comming together. You are really moving on this car.
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes.
https://www.facebook.com/media/set/?...7567172&type=3
The Following User Says Thank You to niceta For This Useful Post:
