#221
Nice port molds Jim, thanks for finally showing me pictures. We made the port bigger where it need to be bigger and smaller where it was needed (which was mostly the inlet).
The stock RAV has zero taper till after the push rod. Then it tapers like crazy: *We built taper from the plenum to the intake flange *maintain cross sectional area around the tube(Tony recommended gradual instead of a bugle) *maintain csa to the short turn(you need to keep velocity down to make the turn) *improve the short turn.
Lynn McCarty dba/McCarty Racing www.RamAirV.com lmc3470@aol.com www.ChemicalManagementIndiana.com 317-260-3486 |
#222
Detuning a "race breed" a motor for street use...kind of up side down, lol.
#223
Been thinking about it and maybe you guys are right!I should not try and run all this rare race stuff on the street!I think I will offer up for sale ALL my RA V stuff for anyone that has deep enough pockets.3 complete engines.303 based RA V short deck engine,4one of 25 made.446 CI alu V engine complete,one of 6 factory blocks and a 455 V engine complete with one of a handfull 4.21 stroke 3in main factory crank.All engines come with correct carbs,balancers etc.The McCarty alu heads and intake are avil also.PM or email if anyone is interested.I canceled the dyno deal on the alu heads.Tom
#224
No No No Keep it, Keep it, Keep it Run 'em, Run 'em, Run 'em on the street !
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
#225
I'd suggest thinking that over for a bit before pulling the trigger on selling everything. Your collection could not be duplicated again. Your knowledge and willingness to share the parts you've obtained over the years has been an asset to the hobby. You offered one of your V blocks (4.20 bore IIRC) and that 4.21" x 3" main crank to me years back at a very reasonable price. I passed, but most RAV collectors would never part with stuff like that or would ask the moon for it. I really respected that. IMHO I do feel you are getting sh*t on a little bit considering how much of your time and money you invested into those new RAV heads to make them work. Just my
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#226
Tom,
We all like you and support you 100%. We dont have to agree with your methods, but it is your car, do it the way you want. We hope to dyno this week, and I will show you how we do things. Tony will be the moderator. Lynn
#227
Tom,
What one or two think of your personal decisions should not and does not matter. Build 'em how you want 'em. Your stash is beyond comprehension: Use the parts and enjoy them as very few will ever have the chance/pleasure. You are the ultimate hard core Pontiac'er on this forum...we are all trying to catch up. Highly recommend you stay the course. |
#228
Tom,
It probably doesn't matter exactly what I say, due to the fact that I am a no body on this forum, but I agree with the two previous posts. I find your information very valuable to enthusiast and to the consumer who may purchase a set of these. As far as it being a "street" post, I have found that in the last 20 years that the word "street" is all relative. People have different tolerance levels of what is drivable. Back to the post, I find the information very valuable. My reasoning behind this is that if you pick up a copy of High Performance Pontiac Magazine and look at the most common combinations of engines you will find that they are largely the 462 through 467 variety. All of these combinations are similiar scenerio in that they are restricted on the bore size. So I think any information avalible to show what needs done to make them work on smaller bores is just as important as what would work on a larger bore. It also gives the consumer a chance to see what is the capability of such a cylinder head. I think what you have done with the Ram Air V stuff on your own accord is extremely impressive. It is truely a shame that Pontiac never had the oppurtunities to make some of the improvements that everyone (including yourself) is making to them. I would hope you would continue with your testing as stated earlier, it only makes all of us more informed.
Ben Mowery |
#230
Was joke'n, forgot to Seriously; "Handfull of 4.21 3" cranks". As soon as my "old" bud gets his new house built, will forward his address for payment for the one(mine) he broke. Once paid(doultful), send it straight to me. NOT HIM!
#231
Do the ports line up with the stock gaskets or not? Meaning specifically, are the ports completely inside the gasket port holes with no over hang as shown in Toms pic? Can you show a pic of the revised ports with a stock gasket? -Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
#232
I thought I would bring this to the top as there was questions of what the tube and foil do to flo compared to nothing in the port.Post 179 has some info.Tom
#234
The RAV heads were not drilled for 8 holes. So sometimes when dealing with the old stuff you see things all over the place.
#235
BTT: thought this thread may be of some interest since some of the things discussed were put into a running motor and dyno results thereof have been published.
#236
If I had the money I'd run a V on the street. I'm sure that there is an engine combo that would make it streetable to dive, I like the big thump of an engine running down the road.
#237
They are just another air pump.NBD,Tom
#238
Yes, but a good one. They also look really good to.
