EHTTFMF!!!!!!!!
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Is your record player stuck ??!!
![]() ![]() Happy New Year Jeff...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
yep! Just like the way it sounds.
Happy New Year to you too Troy.
EHTTDMMF
Its time you step up to 10.5 and something better Jeff. Tigers would look good in there and get the job done. Maybe these new Pro-ports. Might have to become a part time plumber to afford either though. Best of luck whatever direction you go! You know I'm a fan!
. Maybe when my kids are older I will try something different. I wish the RAM Racing Series South would have worked out for you!BTW what is EHTTDMMF?
Not sure right now. I want to see a couple sets done first.
I simply couldnt get enough to sponsor Ram South properly. Plenty of racers interested, tracks too. Big area lots of costs to cover. Couldnt find enough volunteers, no way could I handle a payroll without sponsor money. Economy was tanking at same time. Rich wasnt in good enough shape to help. If it starts booming again I might give it another look. Potential is huge. |
I have a question. I have heard through the grapevine that the spark plug location changed from where it was on the very earliest castings. Can anyone confirm that?
Recent picture posted leads me to believe it may have been revised some. |
The person that told you would know better than anyone. I haven't heard that. There is no issue if the chamber is shaped correctly and I think that is why you see a difference in the pics.
More unsubstantiated rumor....LOL
As far as I can tell my plug location is in the same location as Jim's heads which was said to have a plug location problem.
If there was a change it was very slight and not noticeable. |
.... i'm pretty sure nobody was talking about Jim's ProPort head having the issue, the concern came from the pics of Calvin's ProPort head/half ....
If that is the case then why was this "concern" ever brought up? The issue was corrected before Jim got his heads. So why even mention it? I guess Bruce brought it because........????????? |
.... so basically, the concern was correct, but has since been addressed, so what is the big deal ?? .... i was just trying to show where the concern came from, and it looked like Calvin's head-half had the issue, and Jim's did not .... it's not the end of the world .... .... as for why Bruce brought it up ??? i'd say because he wanted to .... but i'd have to ask him to be 100% .... |
Actually it was first mention by Jim of Rolanding racing on the Channel, I checked the dates. There was no mention by Bruce before that date. Bruce then bought up the subject here, the funny part was watching him obsessed about it, when we knew long before it wasn't a problem. The way it all came about didn't look good. Suddenly we had Calvin posting pictures, We just sat back kind of giggling as it was coming from the CV-1 boys.
Visited with another CNC guy last week. We are moving forward on CNC'd extensively ported 11 degree Pro Ports. Working all the details...
Great news Jim! can hardly wait to see the results!
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads Faster on nitrous… |
Thanks 69...These should be good
In an attempt to continue the flow of info on 11 deg head dimensions, I posted this on another thread and I thought I would add it here for the continuity. Center of guide opening to center of rocker stud hole - Since these openings are not on the same plane and are drilled at different angles it is hard to measure however I measured 1.463" from closest side of guide opening (guides are not installed yet) to the closest side of threaded rocker stud hole. Guide opening is .502" diameter and stud hole is .442" therefore a very rough center to center is 1.935" Center of head bolt hole (between intake ports) to center of intake guide opening - These are closer to being on the same plane but again these are drilled at different angles...we measured 1.31" from closest side of guide opening (guides are not installed yet) to the closest side of head bolt hole. Guide opening is .502" diameter and head bolt hole is .530" therefore a rough center to center is 1.826" Head bolt hole to other adjacent intake guide opening is the same within .001" So head bolt hole is centered nicely between the two intake guides. Valve cover rail to deck at its closest point is 4.99" |
