Old 11-22-2022, 04:30 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
This is an incredible story. Thanks for sharing it with us. Just curious about what intake manifold you plan to use.
  #222
Old 11-23-2022, 12:15 AM
mscicluna007's Avatar
mscicluna007 mscicluna007 is offline
Default Intake
Good Question.
This motor came with an intake manifold which is also pre production. I am just in the middle of going over everything and trying to document it all and than will put it up also. But here is a sneak peak.
  #223
Old 11-23-2022, 01:05 AM
nytrainer's Avatar
Gotta ask. What became of the 455 SD shortblock I sent you from NY? Hope all is well with your family Mike.
The Following User Says Thank You to nytrainer For This Useful Post:
  #224
Old 11-23-2022, 03:51 AM
Default SD Block
Hi Dave,
I still have it here also. Nice and safe. I wasn't looking but it was hard to look the other way on this piece due to all the early pre production gear my car would have been running.
I have alot of options to think about now.
I had a bit of a rough time with health a few years back but all is back to normal now and fighting fit.
Hope you guys are all well also.
Did your son ever get through his build in the Le Mans I think it was.
Michael
  #225
Old 11-23-2022, 12:01 PM
nytrainer's Avatar
Glad you’re on the mend Mike. We still have both 68 convertibles and are just finishing up an interior resto on his. Of course I can’t even find time to even drive mine as I am the family mechanic and painter lol. We just painted his 600 HP 2008 Civic SI (his first car he won’t part with it) and we brought back his 2008 M3 from South Carolina that he bought. Here’s pics of his cars. Be well.
ID:	602489   Click image for larger version
ID:	602491   Click image for larger version
  #226
Old 11-23-2022, 12:25 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Originally Posted by mscicluna007 View Post
Good Question.
Please post more pictures of the manifold when you can. By the looks of this picture this manifold is missing something that is unique to the SD-455 manifold.
Go fast, see Elvis!
  #227
Old 11-23-2022, 03:14 PM
Default INTAKE
I will do Paul.
It definitely does not have LS2 cast into it. There is a part number also at the rear of the carb pad. I will definitely be posting pics up of it.
The Following User Says Thank You to mscicluna007 For This Useful Post:
  #228
Old 11-28-2022, 03:12 PM
Hi Paul,
Here is the manifold 490471.
Its very different to how we expect to see it. LS2 is nowhere to be seen and part numbers ground off everywhere . I have tried not to miss any details on this motor so it has taken time to get photos and do some homework
Enjoy.
Michael Click image for larger version
ID:	602714Click image for larger version
ID:	602715Click image for larger version
ID:	602716Click image for larger version
ID:	602717Click image for larger version
Sent from my SM-G973F using Tapatalk
  #229
Old 11-28-2022, 03:23 PM
The cylinder heads their was some holes that have been plugged .
One of Rocky's photo's from the press release showed these early developmental heads.
The stamping INSERT from what I understood from Rick was in testing they were burning out valves real bad. Louie Clemens modified the heads with an insert in the coolant area to divert coolant.
Rick arrived in 78 until around 84 so was able to learn from who was left at the Proving Grounds. This motor sat quietly in the back of the shed. Most stock was already movedon or scrapped. So I am really glad it survived.
MichaelClick image for larger version
ID:	602719Click image for larger version
ID:	602720Click image for larger version
ID:	602721Click image for larger version
  #230
Old 11-28-2022, 03:27 PM
Another interesting part is there is no 132 cast into the side of thebblock like production SD 455.
Instead this one sports 212. ThebBlock code sports 490132 at the rear of the block.Click image for larger version
ID:	602723Click image for larger version
ID:	602724Click image for larger version
  #231
Old 12-03-2022, 10:59 AM
PAUL K's Avatar
Hi Paul,
Enjoy.
Michael Attachment 602714Attachment 602715Attachment 602716Attachment 602717Attachment 602718
Thank you! I will post some pictures and explain what I'm not seeing on your manifold that the production engines had.
Is that manifold off the engine? If so would you post a picture looking at the intake ports please?
I went through a Super Duty engine that was pieced together by the Pontiac Corporate Service Garage back in the day. They really liked using those hand stamps. It was fun trying to decipher what they all meant.
Go fast, see Elvis!
  #232
Old 12-03-2022, 03:50 PM
Hi Paul,
Sure no problems. Its still off the engine at the moment so I will get some photos for you.
Would be great to learn more.
Did tou want me to email them if there is too many pics.
Michael
  #233
Old 12-04-2022, 03:55 AM
Hi Paul,
Let me know if you need more.
ID:	602977Click image for larger version
ID:	602978Click image for larger version
ID:	602979Click image for larger version
  #234
Old 12-04-2022, 03:56 AM
Couple more of the intake ports.
ID:	602991   Click image for larger version
ID:	602992   Click image for larger version
ID:	602993   Click image for larger version
The Following 2 Users Say Thank You to mscicluna007 For This Useful Post:
  #235
Old 12-04-2022, 03:03 PM
PAUL K's Avatar
Thanks! It looks like that flange is taller so it will cover the taller ports (kinda obvious). What I noticed was the scallop at the top of the manifold ports that the production manifolds used is missing on yours. I'm guessing maybe after your manifold was designed they figured the valve cover was getting too close to the manifold and added the scallop for additional clearance.
Thanks again, what a great project! I'm glad that engine was saved and can't think of a better car for it to go in since the Grand Am didn't survive.
ID:	603019   Click image for larger version
Go fast, see Elvis!
  #236
Old 12-10-2022, 08:18 AM
Yes it has a Partial Vin at the front of the block and i was able to get PHS on this Vehicle.
I will share the PHS and VIN.
Good Lord !
Hollywood can't even write stuff this good
... remember that time a guy over in Australia bought a run of the mill Y-Code 73 TA project , and decided to get the PHS Invoice just as a formality ? It was a pre-production SD magazine test car
... remember that time a guy over in Australia bought an Eng/Dev pre-production SD engine , and it had a VIN stamp . It came from the ultra-mysterious 1 of 1 SD Grand Am magazine test car
The dynamics have been astounding
More congrats to you Michael
The paper trails of Pontiac have been amazing and invaluable.
  #237
Old 08-31-2024, 10:15 PM
Ganggreen Ganggreen is offline
Default Can I get more info on the incorrect vin# s on test cars
Good Lord !
Can I get more info on these sold test cars with incorrect vin #’s?
  #238
Old 08-31-2024, 11:27 PM
Not sure what you are asking for exactly.
This 73 TA subject car is the one I was writing about. (Magazine test car)
Read the whole thread from start to finish , everything should be covered.
He also bought that engine that wound up having a VIN for a 73 Grand Am.(Magazine test car).
I'm pretty sure the invoices regarding both are posted within.
Rocky Rotella wrote features on both calamities.
Can check out www.pontiacV8.com for condensed details.
  #239
Old 08-31-2024, 11:44 PM
Default 1973 Pontiac formula 455SD with Y code
Hi, I’m new here, brought my brothers (he passed) 1973 Pontiac formula 455 SD home, it has a Y code in the Vin# but has a 455SD in it, I’m trying to figure out if it is a true 455SD car with the incorrect vin # or if somebody way back dropped in a 455SD in it, it’s in great original condition, saddle interior, automatic, air, auto windows, console, clock, ram air 4, all in working condition, it feels like low butt gears, I’m not a Pontiac guy, I’m a Chevy guy, trying to figure out where to start. The car was built in Ohio and sold in California and lived its life in L.A., , it’s now in Oregon . Thanks
  #240
Old 09-01-2024, 12:04 AM
Check the partial VIN on the engine .
Passenger side , front flat face of block , down low , alongside timing cover.
Then start documenting things like block code , head codes , intake code , carb code.
And also the dealer invoice from PHS.
That will list the engine option.
This TA had SD engine option on the Invoice.
Pretty sure the GA did also. Been a while since it was discussed on here.
Rocky's site has the feature articles about them both.
Originally it would have been 3.08 10bolt axle.
Upgrade would be understandable.
