Old 03-19-2015, 09:30 AM
Chris Uratchko Chris Uratchko is offline
LOL... yeah pretty much.
Uratchko Racing Engines
www.ure-racing.com
Old 03-19-2015, 10:20 AM
Stan Weiss's Avatar
If the air foil (push rod) in the middle of the intake port works out, then how much help does the lift, push rod, rock arm dynamic need on a short deck block?
Stan
Pontiac Pump Gas List
Old 03-19-2015, 11:57 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Stan
... well from a reverse-engineering perspective, it appears that's what led to the Tunnel Port/RAV layout because the pushrods are virtually straight up and down, so less deck height wouldn't be a problem, and during the era' this layout was developed the focus was short deck, small c.i. TransAm road racing, so it's easy to see what the factories were after then, large csa ports with straight valvetrains ...
Old 03-20-2015, 10:52 AM
Ken Criss Ken Criss is offline
Call KRE they are the only ones that I know that have done it with Picketts 428 and track results back it up with 8.0"s in quarter mile.
Ken
Originally Posted by dci View Post
I seen here were Scott asked if anyone has made 2.3 HP per cube. My question is. What does it take to make 2.3 or more HP per cube? I want to clarify first I have not made 2.3 HP per cu. in. So I am not asking this to offend anyone.I just want to see what others have done or might think it takes. I think to make 2.0 HP per cube takes way more than the average guy is willing to spend or to make the effort to achieve. I have been fortunate enough to have seen some of what it takes to make 2.8-2.9 HP per cube in pro stock, and let me tell you. I do not have the funds or time to dedicate to such an endeavor. It gets way more involved at this level than I think most realize. Let's see what everyone's thoughts are. Let's use a 500 cubic inch limit with our current deck height of 10.240" and the cylinder heads that we have available right now. There are no limitations except the two I just mentioned. If the engine is capable of making a minimum of 2.3 HP per cube. Then this theoretical engine will make 1150+ HP. Let's not turn this into a cylinder head pissing match. I don't care what heads are used to achieve this goal. I just want to get people together to brain storm. We have some really smart guy's here and I think this will be of interest to everyone from the amateur racer all the way up to the professional level engine builder
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 03-20-2015, 08:19 PM
mjm421's Avatar
mjm421 mjm421 is offline
Ken
Weight and MPH needed.
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
Old 03-20-2015, 08:26 PM
tom s tom s is offline
I believe he went 8.30s at Norwalk at 6.5 per CI last year.Dont know what he weighed at the 8.0.Tom
Old 03-20-2015, 08:53 PM
slowbird's Avatar
slowbird slowbird is offline
He qualified with a 8.31 at 163.45 weighing around 2780lbs. Which shows 950hp 2.2hp/ci
Old 03-20-2015, 09:12 PM
mjm421's Avatar
Thank you sir!
Old 03-21-2015, 07:35 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Stop it with the facts, this is the internet damn it everything posted is the truth!
First Pontiac powered street car in the 7's
[email protected]. 3460#s
Old 03-21-2015, 08:03 AM
At least one can't go 'dark' with that fact.
Old 03-21-2015, 09:43 AM
mike leech's Avatar
mike leech mike leech is offline
unlike you.....Who can go "dumb" with any set of facts.
There is not enough light that can be shown that would be bright enough for you to see it.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 03-21-2015, 02:52 PM
No, unlike you, when you can't sway anyone with your 'facts' you deflect or resort to childish antics.
Old 03-27-2015, 05:29 PM
taff2's Avatar
taff2 taff2 is offline
I'm hoping to be somewhere close to 2 HP per cube @9000 rpm on the 400 I'm building for my sons car,but it's going to have a factory block and factory iron heads with a 'special' port job. Don't want to make it too easy with all this fancy aftermarket stuff!
Old 03-27-2015, 06:33 PM
LiL Jack's Avatar
Talking
9,000 RPM with a cast iron head?
Old 03-27-2015, 07:24 PM
Why not? HO was doing around that rpm in the 70's! Today's parts and porting techniques applied to old iron 2 per seems a doable goal..
Sounds like a plan to me Taff!
Old 03-27-2015, 07:48 PM
LiL Jack's Avatar
Sure, you can shift it that high, but it probably stop making power under 7,000.
Old 03-27-2015, 07:38 PM
taff2's Avatar
Or as close to 9000 as we can get. Obviously the heads will be seriously modified,I'm going to mill out the head port divider wall right back to the head bolt boss's to make one large 'siamesed' port that will tune at up around 10,000 rpm,then they will have a max port job, and then the intake manifold will have the same treatment. (similar to what I've done on my turbo combo,which works pretty good as far as fuel distribution goes). Compression will be up around 16-1 with all titanium parts up top and a super light rotating assembly. No it won't be on pump fuel, and yes it is going to be a challenge!
Old 03-27-2015, 09:06 PM
Dragncar Dragncar is offline
Jack, HO was doing that with a 326. But it was not a normal 326. It was a 50s block with a very short stroke and those real small mains. Factory modified forged crank. RAIV heads.
They modified a sbs Edelbrock two four tunnel ram.
You can bet it pulled well past 7000 RPM.
Old 03-27-2015, 09:14 PM
slowbird's Avatar
Did they dyno it? Where someone chooses to shift at and where an engine makes peak power at are two completely different thing.
Old 03-29-2015, 02:51 PM
cfmcnc cfmcnc is offline
Default 2.3HP per cu-in
Working on the AP 541Tiger Development engine we have got to 2.105 HP-CU with valve seat leakage,broken valve springs and rods to close to oil pan,Hate to do the shudda-cudda-woudda thing but we think when we get a solid engine it will be at 2.2+.Dont think 2.3 will happen with this combo .Engine has 2.350-1.670 valve size,1.040 net lift on int.15.2 cr.Peak HP at 8200rpms,This engine does not have all the Max Effort stuff available ,Just a development tool to evaluate Tiger heads and other AP products.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
