#221
Great post but I think things have been derailed. We're now on the "who has the best tow vehicle" part ...but I'm seeing things the same way you are.
#222
I say instead of talking about transplanting LS engines from trucks into Pontiacs, we talk about transplanting Pontiacs into trucks!
#223
"My truck will downshift to second gear and fly up to around 5 grand on hills occasionally. But it just stays there very briefly, gains speed, and upshifts."
Unacceptable for a heavy duty towing vehicle gas, diesel or otherwise.....IMHO. If the engine can't pull it's own in the 3000-4000rpm's range with heavy loads on steep grades it's not up to the task. Not being able to keep it from doing that 3-4 gear downshift deal doesn't cut it for me, when I select the "manual" mode the ECM shouldn't go ahead and seek lower gears then "buzz" the engine in my $60,000 truck to and past 5000rpms. Doesn't matter how well it's made or designed that kind of RPM isn't cutting it for me and it can't be good for the engine in the big scheme of things.....IMHO "The surging and the transmission lugging and then all of a sudden downshifting with the grace of a buffalo in a china shop is annoying." Excellent description and the dealership thought that deal was perfectly fine. I tell everyone I know about it even if some folks on these Forums get their panties all wadded up about getting a little off-topic. The general public needs to know the good and bad points of these vehicles before going out and paying more for one than I paid for my last house!.......FWIW.......Cliff
| The Following User Says Thank You to Cliff R For This Useful Post: | ||
#224
Sounds to me like you have a truck to roll down the hill behind your shop. ![]() The OP got his answer in post #35 I definitely could careless how derailed any thread gets, but I do find it amusing how many issues there are with tow vehicles in the street section. ![]() I also find it annoying how our GM vehicles hunt for a gear when towing up and down a grade. My brother solved his by wiring a switch into the system to keep that from happening. I solved the issue by putting the shifter in "D" when towing in an area with a lot of hills...FWIW Last edited by PAUL K; 12-31-2019 at 09:07 AM. |
#225
A 455 would make a heck of a tow engine! TH400 and a 3:08 gear with no need for over drive... We would need to start a thread to determine the best compression ratio and whether a 041 w/ Rhoades lifters should be used or an OF cam.
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
#226
I understand. Your truck is perfect (of course) and everyone else's is $h!t. Just like everything you discuss. "I'm liking my 2018 Silverado with the 5.3 LS engine. Does everything I want and no problems whatsoever anyplace." Someone else's truck: "The truck was fantastic on flat ground" "I wasn't the least bit impressed with the 6.0 HD set-up anyplace. " Which is it? |
#227
Application-specific!
So, for best Towing, i suppose a Continental Aircraft 4 CYL is best for towing, maybe Lycoming. Just er ah 4L80, an ECM you like and 2" 4:1 Header. My 95 Lincoln(s) seem to tow Class III very well for MPG & comfort. Becomes a laugh, not a pucker when i hit WV mountains: see the engine has limiter power, and i can find the peak TQ Converter TQ multiplier, butt hay everyone else can see the little engine that could so they pass happily rather than angrily. Oh i've dreamer of putting a PMD 455 in the 95 Lincoln and grafting the EFI, & O2, & Coil Plates. Reuse the 4R70W & Converter as-is. Big-Stroke & Low RPM is my idea of MPG & Towing. 5000 RPM pucker-climb is real (U-Haul Trucks). Us Drivers putting all our car enthusiast faith into "i guess the designer(s) assumed the valvetrain can do this awhile". Bad MPG for any load or "hauling sailboat fuel" LS....Im afraid of the ECM Reliability; those LS vehicles are plenty in the U-Pull-its for some reason: WHY ARE LSs so plenty? I sure loath a generic Check-Engine lamp. Gonna need a Decoder tool someday. Oh Auto-Zone does it free ☃️ Last edited by Half-Inch Stud; 12-31-2019 at 10:31 AM. |
#228
Yeah, the LS in my H2, as I stated in a previous post, was running around 4,400 at 70 mph on that trip to and from Lake Mead, pulling the "ultralight" 22 ft trailer and the bass boat behind that.
It was August...in the DESERT! It cracked the pressurized antifreeze reservoir on the way out of Lake Mead, and we had to have the H2+trailer+boat combo towed in. We wound up in Kingman, AZ at a GM dealership, so my wife and I went to the Mother Road Harley-Davidson dealership to get the first oil and filter change and service done on the V-Rod we had bought in Las Vegas, NV. ROUTE 66 on the V-Rod was a blast! |
#229
Doing it now. Putting a 614 headed 428 into my ‘69 C10. With a tunnel ram, hydraulic roller and a T56.
| The Following 2 Users Say Thank You to 3fastgtos For This Useful Post: | ||
#230
1973 Jeep J4000 (3/4 ton) 1972 455 from a GP, 068 cam, reworked 3 tube headers headers to clear the front driveshaft on right side, reworked OJet, T 400 transmission, shift kit, 4.10 axles. Towed, pulled, plowed until 1999 with it when the rear frame rail succumbed to rust near the shackle mount. I sometimes wished I hadn't scrapped it, but at the time I was divorcing, so didn't have the means, to keep it, nor a place to fix it. |
#231
Is that the same GP that runs elevens? Did you guys tow with the 068 then install the 274 XE cam to race?
#234
| The Following User Says Thank You to slowbird For This Useful Post: | ||
#235
There is a lot of $ involved in doing an engine swap from scratch when you don't have any parts at all. Things like alternator and PS brackets, pulleys, timing cover, oil pan, oil filter adapter, stuff that you'd reuse if you had to rebuild your engine but you have to pay out of pocket for the first time you do a build. |
#236
290B and an 850 double pumper on a Victor with E-heads, 4.56 gears and a loose converter. Everyone knows that's how you tow! How long you think those rear mud tires will last????
#237
No no no....you got it all wrong! OF cam hy'brid set-up, advanced four degrees, iron intake manifold with RPM plenum, Q-jet, TSP wiz bang tight converter with a Continental stator and 3:08 gears.... With an overdrive tranny..... The 290B would have too much stinky smell.
#238
The ultimate guide to getting smells out of your hair
https://www.thelist.com/19468/ultima...g-smells-hair/ .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
#239
Lol
#240
