I've spent countless hours researching online over the past year and several thousands on parts and my car is still kind of sluggish IMO.
I have a hard time seeing my 350 producing much more than 300 horsepower. The below is what is on it:
Any idea of what I can look at that may be wrong with this set up? Or what upgrade I should do to get this thing to over 350 horsepower? I was expecting some decent power but boy this thing is kind of a dog. I have a hard time seeing it do less than 15 seconds in the quarter mile but I haven't tested yet. When I asked Kaufmann what kind of power he thinks it can produce, he said I may be around 375-400 hp. |
Glad to see you are giving it a run. You have a build that on paper sounds similar but better than mine.
Cam: your 60916 is just a couple more degrees more than my 10510702 Voodoo cam, same LSA. The lift is slightly less than mine, but very close. Heads: your KRE d ports undoubtedly flow better than my 2.11/177 mildly ported #12 iron heads. I run FiTech for fuel system. It's likely not faster than a Holley, but might be easier to tune. What is your ignition setup and timing curve? My best et was 14.04 with awful air and embarrassing 60 foot times. I think mph was something in the 100 ballpark. This was during my last track trip years ago, where I had just got into data logging my runs and adjusting afr settings for best et/mph. I have no problem admitting I suck as a driver. But I have no doubt I could've had 13's. The rest of the package was th350, 2000 stall converter (more stall would've helped), and 3.73 in a 1st gen. Stall and gears with a cammed up 350 really helps. The power band really comes in above 2000 rpm. As a point of reference, I broke out of the 15's with a 69 350, stock 47 heads, Summit 2800 cam, same trans/2k converter, and 3.23 gears. I can't remember if I was running a qjet or Holley then. The point of telling you what I ran is not to peacock on my setup, but that I think you are selling yourself short, or something is off in your tune. I am really not that good at this compared to many people. Dare to be different! Btw, welcome, congrats on post #1.
"...ridge reamer and ring compressor? Do they have tools like that?" Last edited by Squidward; 05-13-2025 at 12:28 AM. |
Have you done a cranking compression test? If so what are see seeing.
Stan
| The Following 2 Users Say Thank You to Stan Weiss For This Useful Post: | ||
I agree do this. Engine should work pretty well. What gearing convertor and weight of car?
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
Cliff always said that the Crower cams always need 4 to 6 degrees advance to get to correct 108 or 109 centerline. If its retarded it will be sluggish.https://forums.maxperformanceinc.com...ighlight=60916
| The Following User Says Thank You to 400 Lemans For This Useful Post: | ||
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
As was mentioned above, steeper rear gear and some stall will allow the engine to perform in its power band. Start with ignition curve and timing. Most aftermarket camshafts require 16 to 18 degrees initial as a starting point. Then knowing your timing advances coming all in at specific RPM allows for fine tuning. Example: 36 total all in by 2,800 RPMS……
Several things are wrong with your combo!
1) The larger port volume of those aftermarket heads or any of the available aftermarket heads only serves to harm throttle response and torque in your CID motor below 4000 rpm. 2) You want more then 300 hp you say, well stock heads are more then capable of producing that along as a stated above. Producing superior throttle response. You only need 175 cfm@28” to make over 350 hp. Good port velocity in the motors average rpm range is just as important or more then cfm if the motor will not run above 5500 rpm. 3) your choice of intake manifold is harming the motors power production just like your choice of heads is. 4) if your cam is not producing at least 175 to 180 psi of cranking compression then that’s a issue also and a big issue at that! In short and in my opinion everything you have bolted on above the deck of the block is fully counter productive to your stated goals.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 05-13-2025 at 06:58 AM. |
| The Following User Says Thank You to steve25 For This Useful Post: | ||
![]() The heads were a little bit of an investment so I would like to see if I can get those to work. I thought about taking them off to port them but you're suggesting I should definitely not do that? I kinda get the impression that the engine isn't really flowing well. I did recently stumble on the suggestion of checking the pushrod length and that if they are too short, the valves won't open to its full potential. I do not believe I checked that and hope to get to that today. |
Secondary problems: 600 cfm DOUBLE BARREL Holley carb??? Apparently with no tuning Cam installed "dot-to-dot" when there's a half-dozen things that all are needed to be precisely machined for that to be accurate--and "accurate" may still not be "optimum". No mention of timing advance tuning No mention of piston design/quench distance/ring package/block honing As said--compression test needed. Fuel pressure test needed, with engine at WFO and max RPM. Verify throttle plates open fully, and the trans TV cable and shift-points match the torque curve. Last edited by Schurkey; 05-13-2025 at 07:32 PM. |
| The Following User Says Thank You to Schurkey For This Useful Post: | ||
opps, I meant to type 600 cfm four barrel holley carb. It actually has a vac secondary. The other one I tried was a 750 double pumper but sold it since it was too much carb |
If it has a throttle cable on it.
I was driving my LS Sonoma to work and it lost power. On the way home I wrung it out really good (been trying to blow it for bout 7 years). Got it home and thought, yep, she's done... ![]() On a hunch I popped the hood jammed a broom on the peddle and the throttle barley moved, and the cable coiled up like a spring.
HP is in the heads,start there.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
In the Nov 2000 issue of muscle car review a stock rebuilt RA3 400 fitted with long branch Firebird exhaust manifolds and the 068 cam was dyno tuned on race fuel ( just to be safe ) to 368 hp @4700 rpm and 448 ft @ 3500 rpm.
So you should have no problem making 350 hp with stock heads with your 354 cid motor if your cylinder pressure is up where it should be.
Which 600 and 750 Holley’s were you running? We have had a lot of trouble with new Holley stuff make decent power without an extraordinarily amount of tuning. OTB they have been 50 HP short of a well prepped carb. I can’t imagine a newer 600 DP running well at all on that combo without and insane amount of tuning. The bogging on the 750 DP is easily fixable. It could also be a sign you have some issues with the timing and carb tuning.
The smaller the cubic inch in any engine brand the more you have to rely on the RPM factor to make HP / Speed ... The 350 Pontiac spent most of its life in fuel mileage and emissions era... So they were paired with bad rear gear ratios, low compression and old school transmission tech a;; of which are counter productive to fun..
I always find it funny how every Pontiac guy will admit our stock head flow suxx but the minute you bolt on a flowing head OMG that's not the way to go To have fun with a smaller N/A engine you have to make it easy and in a short time to get from idle to a productive torque output A 462 engine is a no brainer with its almost linear torque curve That cam isn't really that big but in a 350 it will noticeably soften the off idle response and while the engine is loafing around trying to get out if its way the clock is ticking
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
| The Following User Says Thank You to Formulas For This Useful Post: | ||
The 600 is a Holley Model 4160 vac secondary. The carb was rebuilt because it was dumping fuel in it and running rich. I put a lighter vac spring and really doesnt seem much faster. |
What transmission, torque converter and rear gears does it have?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
