Old 10-12-2017, 12:35 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
Originally Posted by OVERULD View Post
MIke, you've probably already memorized it so you don't really need it anymore!
Hah...now that's funny
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 10-12-2017, 06:48 AM
The Boss's Avatar
The Boss The Boss is offline
BJ, I have a copy of Rocky's version, upper left in Mikes picture - you are welcome to it.
Text me your address & I'll try to get it out to you in the next couple of days.
And go racin' in the street.
Old 10-12-2017, 09:28 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
I just looked at the price of the jim hand book. What happened? ��
Old 10-12-2017, 09:35 AM
It's out of print.
Old 10-12-2017, 10:14 AM
HO Kenny's Avatar
But all the Pontiac guys I know are cheap.
Old 10-13-2017, 11:03 PM
BobC BobC is offline
My HO intake is dated 2/22/71. The timing cover bolt hole is 1/4"-20 instead of 5/16"-18. Just curious if this has to be an incorrect repair or a factory mistake.
Old 04-08-2018, 03:03 PM
birdsandgoats birdsandgoats is offline
If you convert to US dollars that is only $3500 and it does have the correct carb . I don't think that is a bad deal.
Old 05-27-2018, 01:05 PM
poncho4554spd poncho4554spd is offline
I saw that one about a week ago. Gonna need a lot of TLC and a whole lot more money.
Old 10-13-2017, 11:56 PM
1971455HO's Avatar
Hi Bob,
You are correct about it should be 5/16" not 1/4". The proper bolt is 5/16-18 x 3 5/8 long.
If your intake has 1/4-20 thread it is one of the two things you mentioned.
02/22/71 was a Monday back in 1971.... Machinist may still have been suffering from the brown bottle flu Monday morning from the weekend. Hard to think it though. You sure it's not just a banged up starting thread on your intake? Or does a 1/4-20 work just fine. If so, I would get me a 6" long 5/16 bolt, cut it to 3 5/8 and have a machinist cut it down and put a 1/4-20 thread on the end of it. No body will ever detect it. Or install 5/16-18 helicoil in the intake. Guess which ones easier!
Good Luck
Ol' man Smith
Son video'd this...
Old 10-15-2017, 06:18 PM
Held for Ransom's Avatar
Congrats BJ.
Old 10-15-2017, 10:52 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Thanks Mike - appreciate the lead.
BJ
Old 10-16-2017, 10:04 PM
I removed the intake and was able to get a closer look at the 1/4"-20 tapped hole. Definitely signs of a helicoil...
I'm short one of the 4 studs that secure the intake to the heads. Cutting one of the currently available hex head studs to the same length as the OEM studs and then turning the threads down on a lathe should make a close duplicate.
Old 10-16-2017, 11:09 PM
1971455HO's Avatar
That explains it. Somebody repaired it with a 1/4" helicoil instead of 5/16". I tried to send you a copy of all the stuff with the exact dimensions for the all the 455HO fasteners from Pontiac for this, but the format on the forum is different than mine and it all ran together, left it unintelligible. Good luck on sorting it out.
Ol' man Smith
Son video'd this...
Old 10-17-2017, 07:08 AM
Norwood's Avatar
Norwood Norwood is offline
Pretty sure that a striped out 5/16 threaded hole would be to big to accept a 1/4 20 helicoil
Old 10-17-2017, 10:58 AM
bird72's Avatar
bird72 bird72 is offline
Let's just say this project has had some "bumps". Ray of hope shining, despite losing a season. Unchained by non-correctness is fun. Cliff supplied cam, roller. Praying for a run before winter. We've had snow already. Be kind, "It's A Driver"
ID:	465575   Click image for larger version
72 Bird
Old 10-17-2017, 11:27 AM
4birds's Avatar
4birds 4birds is offline
Thumbs up 455 HO
Get ready to enjoy that torque Anthony! Keep up the good work.
Old 10-17-2017, 11:34 AM
Judge273's Avatar
Judge273 Judge273 is offline
Nice work Anthony! Color looks good too. What did you use?
Mike/Illinois
Old 10-17-2017, 12:06 PM
bird72's Avatar
Thanks y'all. Chris at C&C Performance here in Kalispell MT is doing work. I should give them credit, they are talented. They have affiliated painter who did mix on engine paint, he did well it seems. He (Mitch's) will do my minor lower L door paint repair in spring, he will spend he estimates most of a day on getting mix right to not do a big "blend & fade" job on car. The aged Revere greenish silver is a toughie. He also is really good.
72 Bird
Old 03-25-2018, 12:11 AM
Formulabruce's Avatar
Looks sweet and clean, Nice Job !!
Old 03-25-2018, 11:23 AM
4birds's Avatar
Thumbs up
Looking good Anthony. Walk softly and carry a big stick!
