#241
Tim Hansberry http://www.hansberryinc.com/index.html
Route 724 PO Box 391 Parkerford, PA 19457 1-610-495-5344 I'd expect we'll have Steve's hood within 2 weeks. Bolt-On and Pin-On are available, both come with the raised cowel panel. |
#242
I called Hansberry about a bolt on trunk and a full pro front clip for a 70 gto...
Second day they answered the phone... been two days with no response if they make the parts... guess ill try vfn or glasstek |
#243
Latest update: Bolt-on Super400 hood finished yesterday.
#244
Thanks RAIV-Z.
Been on list since Paul Spotts sold'm. Time to save up again...
#245
This one is for Steve's 67 firebird, we'll trial fit it and take some pictures with it on my 69
#246
Bolt-On Super 400 hood arrived today.
#247
Tim Hansberry http://www.hansberryinc.com/index.html Route 724 PO Box 391 Parkerford, PA 19457 1-610-495-5344 |
#248
Just read through the build. Very Cool!
I will be curious to see how well you like the sound of the exhaust and if the super 400 hood fits. You have a very tall set up. |
#249
How's the quality and fit of the new Super400 hood?
#250
Thanks!!! The motor is running and the exhaust sounds Great. We may need to remove the 1 inch spacer for the Super 400 Hood to fit. We haven't put the nose on the car yet, but will shortly and then be able to give some feedback on this Hood. Steve |
#251
Ed and I decided to put the nose on the car today to make sure its still a Firebird.
#252
Here is the complete car once again. YEAH!!!!! Also, last picture is our rear hanger installed on the exhaust.
#253
This thread is FANTASTIC!!
I have a few questions. As you remove and reinstall panels to test fit how do you know it's going back in the same exact spot? How did you determine where and how many plug weld holes to use? Does the rain gutter stay on the car even when the roof and quarter is removed? Keep us updated. John |
#254
Thank ponjohn, Answers below.
A few updates...
We installed the Transmission Cooler with Fan, the Electric Fan for the Radiator, Fan Shroud and the Derale Fan Controller. The real tail-Pipe Hangers we welded on too. Steve |
#256
didn't you want to bolt them on like the factory did ?
#257
I needed the welding practice in tight spots.
It looks cleaner this way. Originality can be Improved. Those little factory bolts wouldn't hold up this 3" tailpipe. HAHAHA |
#258
We put the "Super 400 Hood" on the car. The fit is OK, it does need some time for overall clean-up from the mold process. the middle sides of the hood which run along the fender seem about a 1/4" high. I may need Dzus fasteners to run along side the hood for proper fitment to pull it down. Pictures to follow.
#259
I received the "Universal Spinners" 2" Drop Base and Flat Lid with middle recess for the Air Cleaner Bolt. This stuff is Very Nice and I recommend them to anyone who need more hood clearance.
http://www.racingjunk.com/Drag-Racin...-drop-16-.html Once installed with my Super 400 Hood and 3.5" K&N Air Cleaner the hood still doesn't close all the way and it needs about 1/2" More clearance minimum. Instead of cutting the Victor Intake down I am going to order the Northwind Intake which is 1.25" shorter than the Victor with comparable flow. http://www.krepower.com/Pontiac%20Intakes.htm Steve |
#260
4500 Northwind RAIV Ports Intake being Delivered today.
