Old 10-17-2013, 12:48 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Found some light damage on the passenger side of the front bumper at the directional light area. I'm pretty confident that this was a factor in the distorted shape to the rubber nose. A little tin work on the bumper seems to have straightened it out. Hopefully this will help pull back some of the original shape to the nose piece. The inner section to the front bumper is fairly heavy. I'm going to lighten it up a little.
Name:	inner bumper 86 001.jpg
ID:	340061   Click image for larger version
Name:	inner bumper 86 003.jpg
Old 10-18-2013, 11:19 AM
I'm making a little progress. I got the front bumper parts sand blasted and primed. I have a little straightening left to do on the bumper. Then I can get these parts finished up and put on the car.
Name:	primed bumper 003.jpg
ID:	340170   Click image for larger version
Name:	primed bumper 004.jpg
Old 10-18-2013, 11:23 AM
Here's the front bumper's inner brace. Lightened up before I primed it.
Name:	primed bumper 001.jpg
Old 10-30-2013, 03:58 PM
Got some nice weather this week, 70's and low humidity. I was able to take advantage of it and got the Aero Coupe's nose pieces painted.
Name:	painted nose 001.jpg
ID:	341321   Click image for larger version
Name:	painted nose 002.jpg
ID:	341322   Click image for larger version
Name:	painted nose 003.jpg
ID:	341323   Click image for larger version
Name:	painted nose 004.jpg
Old 10-31-2013, 01:31 PM
Now that I got the nose painted. I need to address the 2+2 grills. The top two grills have been painted a light blue and the bottom two are an orange red. They were originally black. I want to remove those colors without damaging the grills. They are unique to the 2+2 and I imagine hard to come by. I was thinking I could use my bead cabinet to remove the paint. I don't want to try a paint remover for fear that it may react to the grill plastic. Here's a picture of the grills.
Name:	stacy's aerocoupe-work in progress 001.jpg
ID:	341426   Click image for larger version
Name:	2+2 grills 001.jpg
Old 11-01-2013, 07:16 AM
I ended up going with the bead blast cabinet to strip the paint off the grills. Worked out pretty good. The upper two are now ready for some paint. The lower grills need some repair. A few of the mounting tabs were broken off.
Name:	2+2 grills 002.jpg
Old 11-01-2013, 11:23 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... we'll be doin' burnouts in that baby soon !! ...
  #248
Old 11-01-2013, 01:51 PM
I'd like to see that myself ! 2014 should be the year.
Old 11-04-2013, 04:44 PM
mrrat1 mrrat1 is offline
Looking great!!!
Can't wait to see her done.........
  #250
Old 11-05-2013, 01:02 PM
rod cole rod cole is offline
Just a fyi float them in brake fluid removes paint no hurt plastic. Rod
  #251
Old 11-09-2013, 08:18 AM
Originally Posted by mrrat1 View Post
Looking great!!!
Thanks, just got back from a road trip. I'll be working on all the small parts associated with assembling the nose this week. I'm looking forward to seeing her all together too !
Old 11-09-2013, 08:23 AM
I've seen what brake fluid does to a paint job. I'll have to try that. Thanks for the info Rod.
Old 11-13-2013, 11:01 AM
Transporter Transporter is offline
At the risk of insulting some members on here, by looking at that paint job where did you buy that car from, Georgia woods or the mountains of NW Carolina?
  #254
Old 11-13-2013, 01:18 PM
lol Stan, it took me a minute to understand what you were saying. I had posted the old paint job. Actually I bought it in Conn. from a Linda Acevedo. Don't know if the car always lived in the salt belt though.
Old 11-13-2013, 02:57 PM
Yeah, I saw what you started with and reruns of "Dukes of Hazzard" came roaring back!
  #256
Old 11-14-2013, 12:58 PM
I've got the headlight buckets finished. Threw them in the bead blast cabinet, primed and painted them. Being that the Pontiac Aero Coupe's nose is similar to the Monte Carlo SS. I wonder if the headlight bucket assembly are the same ??
Name:	2+2 headlight buckets 001.jpg
ID:	343126   Click image for larger version
Name:	2+2 headlight buckets 002.jpg
Old 11-15-2013, 02:58 PM
Here's the bumper and headlight buckets back on the car.
Name:	aero nose 001.jpg
ID:	343222   Click image for larger version
Name:	aero nose 004.jpg
Old 11-19-2013, 08:56 PM
I installed the upper grilles prior to installing the nose on the car. The nose piece fit isn't too bad. I was able to get some of the distortion out. Just not near enough to make it acceptable. I'm beginning to run out of parts to put on the car. Here's a few photos, a couple didn't come out so good.
Name:	2+2 nose on 009.jpg
ID:	343756   Click image for larger version
Name:	2+2 nose on 005.jpg
ID:	343757   Click image for larger version
Name:	2+2 nose on 003.jpg
ID:	343758   Click image for larger version
Name:	2+2 nose on 008.jpg
Old 11-20-2013, 01:13 PM
Earlier in this thread I had welded a 65-67 hood scoop onto a stock Grand Prix hood. I had planned on using this hood on the Aero Coupe. That hood currently resides on my "driver" Grand Prix. I just measured the carb height as compared to the top of the fender and came up with 2 3/4 to 3 inches. I then measured the peak of the hood scoop on the driver. It measured about 3 inches as compared to the fender. That makes this set up no good for the aero coupe. I've attached a picture of the hood on the G.P. I'll have to look at some glass hoods to see what catches my eye.
Name:	white grand prix 012.jpg
Old 11-20-2013, 05:35 PM
looks like it's really coming together for ya Mike, although I usually don't care that much for cowl induction style hoods (read chevy) might flow pretty nice with the lines on that car and the slope back rear window, JMHO.
Or, possibly one of the bigger/taller T/A shaker scoops?
Stan
