#241
Looks like it got thrown out with all the others ![]() Who knew you save something for 22.5 years, and in year 23 you need it right after throwing it away
Panos Little Miss G Racing on Youtube |
#242
Got the finished polyethylene valance installed today. It was reasonably uneventful. I made sure that all the lower mounting bolts have the large flat washers in place and are finger tight so the valance can move and flex with the nose. The upper mounts use #14 screws with attached washers. These, I wrapped in Teflon tape and finger tightened as well. The Teflon tape allows the screws to remain in their position even though they are not fully tightened to spec.
The front end sure looks a lot more streamlined with the polyethylene valance than it did with the warranty replacement steel valance that was installed by the dealer when the original poly valance shattered. Before, with the steel valance: ![]() And after: ![]() ![]() In this shot you can really see the difference in the hue of original paint on the bumper as compared to the front fenders. The flexible nose/bumpers were painted by the manufacturers and installed on the cars in their prepainted configuration, while the body sheetmetal was painted on the Norwood/Fisher Body assembly line. ![]()
#243
I had no idea there was such a significant difference in the valences appearance!
Very nice Steve - as always!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#244
Thanks!
Yes, the poly valance mounts flush against the bumper and the radiator support, versus the steel valance which mounts to the lower fender edge, lower hood latch support, and radiator support, leaving a 1/2" to 1" gap under the bumper. |
#245
No black bolt either!
Makes a happy face more pretty....
Mike/Illinois |
#246
That is very nice piece...fits up beautifully.....makes the nose look very slick!
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
#247
It just occurred to me while looking out in the garage that I have seen this car's face somewhere before:
Is this one of those "separated at birth" photos?
#248
Hey Steve-
I really like the look of the plastic valance. What parts do you need to swap from metal to plastic? Do you have any idea how the repop models compare with the originals? I am willing to do the body work even on a new repop. Let me know what you think. Thanks,
1972 Formula 400 |
#249
looks great
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
#250
Great job Steve....
#251
It's subtle, but the poly valence really does look better. Nice work!
#253
Someone on the Yenko.net site where I have a companion thread to this one, brought up a good point that it appears the color match for the valance is not very close to the body color.
I responded that these valances were not painted originally: they were molded in body color, or at least what they thought was a semi-close match for body color. So being a shade off, actually looks more original than being an exact match. Back then, polyethylene was a new "Space Age" polymer and the engineers had not figured out a way to get paint to stick to it so they did the best they could by making them in every single color the cars were available in. |
#255
This is it, fits 71-75. It can be bought from PY and others
#256
Thanks guys. I actually have an original poly valance bracket. It was on one of my cars that had the metal valance. I don't quite remember how both brackets were in place at the same time. Now I just need to find a poly valance. I know a guy that may have one.
1972 Formula 400 |
#257
OK, here is today's conundrum: I was looking at the hood latch assembly and it appears that the grommet that the hood cable goes through is partially broken (lower locating tab is broken off) and has been for a long while. The cable is actually sawing its way through the bracket. It also appears that the grommet that the pull handle passes through has a broken piece as well. Does anyone have the grommets? It appears that they may be the same grommet for both the upper cable guide and the lower handle guide.
#258
#259
Fom the link it looks like it is part GM part number 488442 and two are needed. Anyone have any?
