Old 10-27-2007, 02:45 AM
2manyT/A'S's Avatar
Thumbs up 455 HO FORUM
I've been kickin' this around for a while & feel the time is RIGHT!
The SD guys have had their forum going for a while now & it's working well so it's time for the FASTER round port 455 motor to have it's OWN forum.
Old 10-27-2007, 02:46 AM
2manyT/A'S's Avatar
Thought this one might be of interest!
Lets have some feedback here.
http://cgi.ebay.com/ebaymotors/ws/eB...m=230185575300
If any of you SD guys got this far,you might want to read down to the end of the first paragraph in the auction description.
Old 10-27-2007, 07:11 AM
rock rock is offline
I just bought their ram air III exhaust manifolds, casting and machine work look excellent.
Old 10-27-2007, 08:14 AM
Brewster's Avatar
Brewster Brewster is offline
Good luck with that Brian,
I've requested a SD Forum on a thread many moons ago but with NO reply. Its appears that Performance Years is runned by a bunch of GTO guys and gals since there the only one with separate Forums.
Good luck with your new thread,
Brewster
Old 10-27-2007, 08:26 AM
Default Repro round port heads
Would be cool if they could make them out of aluminum....
Old 10-27-2007, 08:44 AM
The Boss's Avatar
The Boss The Boss is offline
I'd buy a pair of those!
And go racin' in the street.
Old 10-27-2007, 12:32 PM
2manyT/A'S's Avatar
I've requested a SD Forum on a thread many moons ago but with NO reply. Its appears that Performance Years is run by a bunch of GTO guys and gals since there the only one with separate Forums.
Brewster
THANKS for your SUPPORT!
Old 10-27-2007, 10:43 PM
greyno3's Avatar
greyno3 greyno3 is offline
I want a Formula 350/6-cylinder forum since they aren't a desired model!! That way all you big wigs won't have to answer any questions. I just don't don't get this forum separation thing. Rich...Poor..
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
Old 10-28-2007, 10:08 PM
2manyT/A'S's Avatar
Greg
It's NOT really a RICH/POOR thing.
The majority of the guys here with round port engines are "car poor" just like you & me.
They bought their HO's & SD's at an affordable price.
It's just like Real Estate.
Sell your house NOW & you've got a TON of DOUGH,but if you have to buy another one,you're back to broke AGAIN!
The 455 HO engine has ALWAYS been the Rodney Dangerfield of Pontiac's Round Port & High Performance engines.
In February of 1970,when our FAVORITE car/platform came to life,the automotive press went WILD over it. I'll bet the 70 1/2 F-cars were revued in over 20 different magazines.
6 months later when the 71's came out,NOBODY from the automotive press even gave them the time of day. the cars basically looked the same as last years,but compression was way down,as were HP ratings & everybody assumed that performance would have gone the same way. NOT SO!
72 was a strike year (longest strike in GM history) & the press couldn't have gotten a car to test even if they had wanted one.
By 73 (fall of 72) the SD was the BUZZ WORD & it became a legend in EVERY Pontiac Enthusiasts mind. (although they had NEVER seen or driven one)
Car Driver roadtested an early 73 & was into the 13's as I recall,but the engine had a pre-production cam. (which the EPA caught & Pontiac had to revise)
When the 74's finally came out & there were a few tests published,but performance (out of the box) was not that impressive. The tuners (Nunzi & co. got ahold of one) & with headers,gears,Holly & slicks,were starting to crank some #'s,but it wasn't STOCK anymore.
The SD motor STILL seems to be the LEGENDARY one,but as discussions in past threads regarding actual testing confirm,the 455 HO IS the faster/quicker of the two round port 455's (in stock form)
The SD motor is stronger,from an engineering perspective,but all of the HD parts DON'T make HP!
Out of the BOX the HO makes MORE power & the 71/72 T/A's & Formula's were likely a couple hundred pounds LIGHTER than the 73/74's which makes for quicker trip down the quarter.
The purpose of the 455 HO thread/forum HERE is to give the FASTER round port motor the recognition it DESERVES!
I like Sd's as well as the next guy,but the HO will get the groceries home SOONER.
Old 10-28-2007, 10:37 PM
I think they were always expensive, from the late eighties till today. I went to see a 73 sd with auto trans and fully loaded, white on white in 91 and the guy wanted 15k cdn and that was way off the scale at the time.
Old 10-29-2007, 09:30 PM
My inner voice tells me you're jerking everyone's chain with this request in the first place, but all in good fun either way, IMO.
I think you nailed it with regard to why the '71s got no respect. In general the world doesn't really care how hard automotive engineers have to work to overcome the obstacles (fuel quality, emissions, safety, etc.) that are thrown at them. And anyway, increasing displacement wasn't rocket science. Fact is the car was (within driver capability and car-to-car tuning variability) no quicker than a '70. And the 455HO was the "standard" engine (at least in a T/A). The fact that the air flowed through round shaped passages instead of D-shaped passages probably didn't excite too many people back then. Low compression, milder cam, calmer idle, lower RPM.... zzzzzzzzz.
By '73 everyone knew the musclecar was a dying breed, and the SD was clearly the "last gasp". That's why there are so many more low mileage SDs around than HOs. People knew when they bought them that they were the last of an era, even if they weren't necessarily quicker than the '70-'72s.
As for the separate forum thing... I actually migrated from CP over to PY because I liked the segmentation by model. But lets face it.... there aren't many '70-'73 birds or owners/enthusiasts around, period. Don't really need to try to cut it any finer, IMO. There's only a couple of new/different posts that pop up on most days anyway... is that too much to have to sort through?
cheers-
Old 10-27-2007, 08:56 AM
GonicGM's Avatar
GonicGM GonicGM is offline
It would be neat to have two of each castings available, one each casting exactly OEM for restorers. One each cast in iron with KRE, ALLPONTIAC modern technology, oversized ports, better flow, relocated spark plug towards exhaust valve, Heart shaped chamber, better swirl, tumble, more quench. These would be killer for F.A.S.T. then!
Gregg V.
Old 10-27-2007, 09:48 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Seems like the 7F6 is the red headed step-child, they skipped right over us! Not complaining, I know it's a numbers thing on how many he feels are out there needing them. I am amazed he has put the kind of money into the repro heads that he must have in the tooling for these, hope it is profitable and he can continue to make needed parts like this. I wonder what the original head values will do. Also will be interesting to see if these flow as well as the original heads.
Old 10-27-2007, 10:58 PM
2manyT/A'S's Avatar
Default NOS 455 HO Q-JETS
Pick your year!
I'm almost tempted to ABUSE my credit card for this one!
http://cgi.ebay.com/ebaymotors/ws/eB...174496552&rd=1
The carb for the "red-headed stepchild" is a bit spendier. That's the price you have to pay for having a clutch pedal,I guess.
http://cgi.ebay.com/ebaymotors/NOS-1...QQcmdZViewItem
Old 10-28-2007, 01:53 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i have both an H.O. and a S.D. so i won't get into whos the fastest but this could be a good idea a H.O. forum.
love the idea of new heads,wonder if this is why the others stopped trying to get theirs produced?price wise,don't know.think the real ones will still bring good money for those trying to restore round port cars,but for someone trying to put a stock looking fast car out there they can now buy these and not ruin a set of real heads.myself i would like an SD intake to port out for my SD project.was going to use a standard intake port it out and tig weld the LS2X on it.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 10-28-2007, 09:33 AM
74 SD455 Formula 74 SD455 Formula is offline
There not going to create a HO forum as they did not and will not create an SD forum and should'nt have created a Judge forum.After all what is a Judge ? It's just an option for a GTO. This is just my opinion and for the record I do own both an SD and HO car's.
My 74 Formula is still wearing it's original coat of paint which is code 51 Sunstorm Yellow.This Yellow is a softer Yellow,like a pastel color.GM also used the same color and code in 75.
Old 10-28-2007, 11:16 PM
carcollector's Avatar
carcollector carcollector is offline
As for this separate forum thing, I have alot of respect for 2many and his posts are always well thought out,
so HO has my vote for their own forum.
Old 10-29-2007, 12:51 AM
greyno3's Avatar
Have your forum! That's fine. Seems like your demanding respect when you already have it. Just consider the people that can't jump that high these days. I got a '75 Bimini Blue Firebird for free in 1995. It was perfect but a 6 cylinder. Perfect black standard interior and rear spoiler. My girlfriend gave it way under my nose. That was when I had the '74 Laguna S-3 and put the '69 RAIII in it. I wish I had it now.
It's hard to find a '70-'73 bird in any style around here. I know of a black one and can't never get ahold of the owner. It sits under a carport next to a garage. That's been 3 years now. You can only see it for a second or two when driving by.
Old 10-29-2007, 01:22 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Hey Greg:
Chill, my friend - it's all good.
I don't think that anyone here is thumbing their noses at folks who don't own a rare car. Having separate HO and/or SD sections certainly wouldn't exclude those who don't own one of them. Heck - I post over in the Judge and '74-'76 'bird sections, and I don't own either of those. Never have owned a Judge and most likely never will.
All that aside, I certainly see folks point with having HO and SD sections, but . . . it AIN'T GONNA HAPPEN. I've spoken with the "powers that be", and it simply isn't in the cards. In fact - I'll wager that if Chris could go back in time, there might not even be a separate section for Judges.
Regards,
"455HO" Lloyd
Old 10-29-2007, 12:13 PM
RAM AIR 1967 RAM AIR 1967 is offline
I have had 4 of my round port car's for over 13 years. 1972 GTO WW5 in 1991 $2000.00, 1971 TA $6000.00 in 1993, 1971 TA $2800.00 in 1994, and a 1974 SD TA $5000.00 in 1994. This cars were hard to find at a good prioe way back then.
