Old 09-25-2013, 07:53 AM
Judge273's Avatar
Judge273 Judge273 is offline
Nice work!
Mike/Illinois
Old 11-27-2013, 02:43 PM
hdinch's Avatar
hdinch hdinch is offline
Originally Posted by REFORMULATED View Post
Going to add Ram Air, and RA intake with divorced heat crossover, interested to see how my 455 responds and if it helps the heat soak we see with crappy CA fuel. Was messy and a bit scarey at first. Since my car is NOM going to make it they way I would have ordered it new, don't flame me to hard, will do my best to make everything look as OEM as possible, why I bought this car vs an OMN one so I can make it the way I want with no guilt. My body guy will shoot in the inlets for me when I have him do some other things in the near future. Whole process took an afternoon with a couple of cold ones.
Taped everything well with delicate surface tape and carefully cut out the block off's with a Dremmel, used a flat and rat-tail files to profile the openings.
Used SEM high build primer to fill in any file-sanding marks and sanded carefully with 400 wet. Applied two coats sanded in between.
Back taped a narrow reveal with fine line tape and shot over the primer with some SEM Trim Black.
Before a good car wash, white residue is sanding dust.
Looks decent after I cleaned it up, but not 100% correct yet.
Media blasted the screens to give them some tooth and shot with SEM etch primer and Trim Black.
Hope it helps others who are thinking of doing the same.
What is holding down the metal screens inside the scoops?
Old 12-02-2013, 11:54 PM
REFORMULATED's Avatar
REFORMULATED REFORMULATED is offline
They screw into two reinforced tabs or bosses on the underside of the hood behind the slits the screens slide into. The bosses are thicker and made to accept the screws. This post shows them and what the OEM screws look like. Hope this helps
http://forums.maxperformanceinc.com/...am+air+screens
70 Formula 400
69 Grand Prix 428
70 Buick GS 455 Convertible
66 Oldsmobile Toronado
Always looking for more
Old 09-25-2013, 11:14 AM
Formulabruce's Avatar
looks stock, nice job!!
Old 09-25-2013, 02:26 PM
unruhjonny's Avatar
wait a second!? ~ this car has changed owners?
I totally missed this...
Did a correct vinyl rear "hump" cover ever get installed ~ or is there just carpet there like the older pictures show?
(Just curious, I think many people have forgotten that the early cars didn't actually have the carpet inbetween the seats.)
1970 Formula 400
Old 09-26-2013, 12:01 AM
I bought the car from Chris in June, turns out we grew up in the same neighborhood. It has carpet in back, did not know it should be padded vinyl. Do you have a picture you could post that shows what it should look like for reference?
Old 09-26-2013, 04:08 PM
rhaasjr rhaasjr is offline
Default lower door panels
restoring my 70 formula. Anyone know where to get those map pockets for the deluxe interior lower door panels?
Old 09-30-2013, 08:41 PM
unruhjonny's Avatar
mine has been out for some time;
I wasn't happy with the cheap vinyl provided with my carpet set, so here is one lousy link which show this;
http://blog.hemmings.com/index.php/2...bird-trans-am/
If you really want to see more, I am sure I could load some pics up to my photobucket.
1970 Formula 400
Old 09-30-2013, 07:59 PM
Baba O'Riley's Avatar
Baba O'Riley Baba O'Riley is offline
rha -- most parts houses sell the hard-molded ones Pontiac switched to in -- I think it was mid-'71. I have a pair of the older, padded kind I might take an offer on if that's what you're looking for. PM me if interested.
"A MAN IS ONLY AS OLD AS THE WOMAN HE FEELS."
-- Groucho Marx
Old 10-02-2013, 08:04 PM
I am interested if they are for a 70 with deluxe interior. I do have the bottom door panel just not the arm rest/map pockets that get screwed into. That being said I'd still take them if they have those pieces with them. Can I get a picture and a price?
Old 10-13-2013, 02:36 AM
Default Detailed Front Brakes and a Few items
Detailed front brakes and replaced the inner fender rubber flaps. Fighting the staples loose and tight again without damaging the paint on the inner fender wells took some finesse. There was some faint markings on the rotors and I looked at a few posts here and other forums to attempt the correct markings and finish but have no idea if they are really correct. Once the wheels go on it's all moot anyway. Cleaned everything with a wire wheel on a drill, used 3M Metal prep and VHT grey primer and VHT cast blast on rotors and caliper. Have some new dust covers on order but in no hurry to replace.
Before
After
Old 10-22-2013, 02:01 AM
Default Changed Rear Gears, Detailed Rear Axle, Corrected Pinion Angle Issue
When I changed my rear gears the shop confirmed the pinion angle was at 1.5 degrees up, causing a slight shudder under hard acceleration, it should be 1.5-2.0 degrees down. Installed Custom Works Products Comp Axle Pad/Locators and 3 degree wedges, shudder is now gone. Added a set of Bilsteins and painted the boots and housings grey to look close to stock while I was there. Rear end is much more solid and planted, handles better too. Used Solvents, wire brushes, a wire wheel on a drill, and a pressure washer to clean all the gunk. Then shot it with Black SEM self etch primer and Napa Semour Chassis Black. Was a very messy job but was worth the effort. Will touch up some of the undercoat in the middle and call it a job.
Custom Works Products Comp Axle Pad/Locators:
Old 11-03-2013, 06:32 PM
Default Ram Air Conversion Complete
Finally finished the project, runs better with the new Repop Ram Air intake, added a bit more timing and no more heat soak issues. Really notice the difference on the freeway. Found a correct air cleaner with chrome lid, do not think the decal is correct but looks OK for now. I gasket matched the intake and clear zinc plated the crossover tins. Shot some spray rubber on the ends of the boots to keep them from chaffing the air cleaner pan. Soda blasted the pan and used SEM self etch primer and Duplicolor acrylic lacquer.
70 Formula 400
69 Grand Prix 428
Old 11-03-2013, 07:32 PM
rohrt rohrt is offline
Thats interesting about the heat soak.
Old 11-03-2013, 08:08 PM
Held for Ransom's Avatar
Why would you put that "400-4 RAM AIR" decal on and ruin the looks of the underside...
Can't see the decal you used on the side, but it's too close to the snorkel.
Old 11-03-2013, 08:11 PM
It came on the lid, I did not add it, need to get some goo gone to take it off.
70 Formula 400
69 Grand Prix 428
Old 11-10-2013, 03:41 AM
Default Does look better without decal
70 Formula 400
69 Grand Prix 428
Old 11-10-2013, 10:08 AM
Nice.
Old 07-03-2016, 01:49 AM
Chieftain54 Chieftain54 is offline
Found this same car original owner , she ordered in 69 Trading in a gto ,been sitting since 89 ruff but all there. I hope to do a third of what this resto was.
Old 07-15-2016, 11:46 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Is it a Ram Air III or standard?
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
