Old 05-01-2018, 06:18 PM
stobin's Avatar
stobin stobin is offline
Default Grand Am Dyno Session Video
I had a dyno day at Westech Performance to tune the GA and get some numbers on power. Car ran fantastic. The final numbers were 482 RWHP@6300 and 484 RWTQ @4600. I am very happy with the numbers. The torque curve is huge and flat. The technician said to figure a factor of 20% give or take for flywheel power. That equates to around 600 hp/tq. As far as the way it runs, it spins the tires in 3rd gear!!Put it in 6th gear and just climbs the hills on the freeway. Car is very easy to drive. I could have went for a bigger cam profile and got the hero HP numbers, but that would ruin the idea behind fitting catalytic converters on the car, and building huge torque to match the feeling I had with the Pontiac 455. The car was fast with the 455, but the LS7 pulls so hard from down low to 6500 it's amazing. I would like to take it to the track and see what it runs. I took the car to the scales right after the dyno session and weighed it. It weighs 3950. So I would like to see the car hit the 11's, but traction will be the deciding factor. Enjoy. https://www.youtube.com/watch?v=9RzyMP0RraY
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme.
Old 05-01-2018, 06:27 PM
stobin's Avatar
Default Retro Picture of Me and The GA
My buddy took this picture when I was waiting to weigh the GA. He photo-shopped it to B&W, and I think it came out AWESOME!! I am going to turn this into a big poster size picture and hang it on my garage wall. Car weighs 3950.
Old 05-02-2018, 09:45 AM
HWYSTR455's Avatar
Wow, nice numbers for sure! And the pic is cool! That's a wall hanger!
Old 05-03-2018, 06:27 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
car looks and sounds great. The wheels/stance are perfect.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 01-08-2012, 08:01 PM
stobin's Avatar
Default Got Bored....Painted the Cowl Area
Until I get the frame back, I have to keep myself occupied on this project by doing some of the liitle things that need to be done, or the things that bug me. The cowl area was painted back when the car was painted in 2002. I didn't like the way it looked lately. The paint was a little dull. So I decided to redo the area with a little texture. I used Duplicolor Armour bedliner. I taped off the car, sanded the area down and shot it with the spray can bedliner. Three coats, followed two light coats of low gloss black. I think it looks a lot better?
ID:	269986   Click image for larger version
ID:	269987   Click image for larger version
Old 01-10-2012, 04:14 PM
stobin's Avatar
Default Corvette Accessory Drive Parts Received
Today I received the Corvette accessory drive with A/C, Corvette water pump and GMPP Pontiac valve covers that I ordered from Superior Chevrolet. GM does a nice job with the instructions, and even has every bolt in the kit labeled with part numbers to make installation easy. I plan to get the mock up block back into the chassis so I can fit the A/C on the block to see if I need to notch the frame for the A/C pump. The only part of the accessory drive I will not be using is the belt tensioner. I decided to go with Katech belt tensioner instead. I will be taking the power steering pump to Lee Manufacturing next week to have them modify the internals to accept the hydroboost.
