Old 02-23-2014, 09:11 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Thanks Glenn for going back and taking more shots of the transmission pan.
So it says.... HYDRAMATIC DIV OF GMC.... that is cool. Pontiac and GMC have a long history together.
PS...nice cat.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #262
Old 02-25-2014, 03:50 AM
transam1972 transam1972 is offline
Default HARNESS DETAIL
Name:	1976 WIRE SHIELD DETAIL.jpg
ID:	354385......according to the 1972 assembly manual only the positive battery cable runs through the securing clip, the negative cable does not..also the positive cable routes through the power steering hoses as shown
Name:	1976 wire shield.jpg
Name:	battery cables.jpg
Name:	clip detail.jpg
Name:	cables run seperate.jpg
  #263
Old 02-25-2014, 04:12 AM
Default ENGINE HARNESS INSTALLAION
Name:	harness and cable.jpg
Name:	HARNESS AND SHAKER GROUND CLIP.jpg
Name:	SHAKER GROUND CLIP.jpg
Name:	harness to solonoid.jpg
Name:	STARTER CONNECTIONS ON SOLONOID.jpg
  #264
Old 02-25-2014, 07:12 PM
Default UNITIZED DISTRIBUTOR INSTALL
Name:	2133 UNITIZED DISTRIBUTOR.jpg
Name:	M AND H TACHOMETER  CONNECTOR TO UNITIZED DISTRIBUTOR.jpg
Name:	NOS LOOM 2ND QTR 1975.jpg
Name:	NOS ROTOR.jpg
  #265
Old 02-25-2014, 07:19 PM
Name:	WIRE LOOM PASSENGER SIDE.jpg
Name:	WIRE LOOM DETAIL.jpg
Name:	UNITIZED DISTRIBUTOR INSTALLED.jpg
Name:	DRIVERS SIDE LOOM DETAIL.jpg
  #266
Old 02-25-2014, 07:25 PM
428RA4's Avatar
428RA4 428RA4 is offline
Just wondering here.
Do you have all the parts to make the shaker flapper function?
  #267
Old 02-25-2014, 07:27 PM
Name:	WIRE LOOM DRIVERS SIDE.jpg
Name:	DRIVERS SIDE LOOM ROUTE.jpg
Name:	unitized distributor detail.jpg
Name:	1972 uni.dist.2133.jpg
Name:	PASSENGER SIDE LOOM DETAIL.jpg
  #268
Old 02-25-2014, 07:29 PM
Default SHAKER PARTS
...yes..but my shaker is out right now to be painted..did you need photos?
  #269
Old 02-25-2014, 07:31 PM
428RA4's Avatar
Thanks for the offer. I have extra parts if yours was missing.
  #270
Old 02-25-2014, 07:37 PM
RamAir's Avatar
RamAir RamAir is offline
Glen, I'm interested in the spark plug wire guides/holders. Do you know if they're available?
  #271
Old 02-25-2014, 08:01 PM
Default WIRE RETAINERS
YES...page 185 of AMES #FN417R for $10...for 4...P.Y. may sell them as well as INLINE TUBE...my N.O.S. looms came with them....they are for the unitized distributor and points wires...any problems and I have an extra set, I could give you
  #272
Old 02-25-2014, 08:04 PM
Default PURGE HOSE CLIP FOR A/C CARS
I AM MISSING THIS CLIP????...ANYONE...Click image for larger version
Name:	1972 EVAPORATIVE HOSE CLIP.jpg
  #273
Old 02-27-2014, 07:58 PM
I DID A REVISED ENGINE HARNESS ROUTE...THIS LOOKS MORE CORRECT..AND I AM KEEPING THE 1976 POSITIVE BATTERY SHIELD..APPEARS THIS DESIGN STARTED IN 1973Click image for larger version
Name:	alternator removed.jpg
Name:	alternator installed   note harness route.jpg
Name:	engine harness routing.jpg
Name:	revised routing.jpg
Name:	wire loom routing along valve cover.jpg
  #274
Old 02-28-2014, 05:17 AM
Default HARNESS INSTALL
I have been looking at my 72 assembly manual,,,I do not think the last post with pics is correct,,,one more try,,,the harness should turn right down the front of the valve cover on an 80 amp set up...opinions?
  #275
Old 02-28-2014, 07:37 PM
Bentwheelbob's Avatar
Glenn,
On the Black Car the harness turns down and runs down the face of the block on the passenger side of the alternator/power steering bracket. You can see this in Figure 12-55 of the service manual or the pictures below.
  #276
Old 03-01-2014, 02:21 AM
Default PHOTOS
thanks for posting the photos Bob!!!Click image for larger version
Name:	UNIITIZED  AND POINTS WIRE RETAINERS       HARNESS AND BATTERY CABLE CLIP.jpg
  #277
Old 03-01-2014, 03:00 AM
Default 3XS A CHARN HARNESS INSTALLATION
I have decided this will be the final engine harness routing...my original harness did route this way and the 1972 assembly manual shows a diagram of a close up of the 80 amp alternator and the harness goes to the left of the front valve coverClick image for larger version
Name:	1972 assembly manual     note harness route with 80 amp alternator.jpg
Name:	engine harness route.jpg
Name:	harness rout in groove.jpg
Name:	harness route next to batterry shield.jpg
  #278
Old 03-02-2014, 07:03 PM
Default REAR ALTERNATOR BRACKET INSTALLATION
Name:	80 amp alt diagram.jpg
Name:	80 amp alt 2.jpg
  #279
Old 03-06-2014, 08:24 PM
Default REAR ALTERNATOR HARNESS CLIP
trying to get things together for the 80 amp. rear alt. bracket..I never thought I would get this part, in fact I assumed it was plastic..I need to invest in a magnifying glass to read some of this assembly manual as I am certain my 20/20 is 40/40..anyway I somehow stumble upon this clip, by itself for sale on E BAY!!..I am like..I need that!!..shipping cost more than the part..anyhow I know GM uses some of these weird clips but I have never seen a one like it on my car..but it is used to secure the harness to the rear alt. bracket with the 80 amp.alt. (see 72 assembly drawing)..so I just thought I would post it..I am certain someone will see it and say they have 10, but I had none!...the other pic is a photo of a heater hose bracket that I may have to modify if I cannot find a purge hose clip..it features the same turned up ends..probably the same piece of steel used to form different clips...last is a pic of a valve assembly used near the firewall on the 72 a/c cars..however I got a similar black/white one and the end is made larger and it does not fit like the original all black one so I can not use itAttachment 355805
Name:	80 amp alt wire harness clip.jpg
Name:	harness clip for 80 amp alt.jpg
Name:	clip that i may modify for puge hose clip.jpg
Name:	repo valve assembly    2 styles available one end is differant than original.jpg
ID:	355812..I hate when that happens...
  #280
Old 03-06-2014, 08:31 PM
SD73's Avatar
SD73 SD73 is offline
Originally Posted by Bentwheelbob View Post
Glenn,
Hello Bob, I'm checking out your throttle cable bracket and it jarred a new quandary in my noggin. Do you know if that's an original part to your car? I'm not sure, but I thought the ones with two holes on the side were for hipo motors and the 3 holed ones were for those that got the turbo 350 trans. Any clarification you or anybody else has would be terrific!
