#261
Torque Techs are set up for offset-offset and I had mounted my electric pump on the frame rail and used offset-center outlets so we added enough between the two piece tailpipes on mine.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#262
Back in 2009 when I first ran this combo I was pretty happy running low 12's at 114..that was in another 80 trans am with 3.42 gearing..I messaged Dave Bisschop at SD performance..and he was pleased I was happy...but told me there is a lot more left in that combo..7 years later and its running 11.3's at 120/121 with less gearing!
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#263
#264
#265
Have you been to their website lately? Sadly it turns out Torque Tech is closing its doors..."retiring".
#266
This is Not the Cheapest way to go fast but for me there is a couple reasons i enjoy cars that can do what Ernies does!
1. No reason to Build a High RPM engine to go fast unless you can't go fast with a Low RPM Street setup! He is Achieving his goals with out having 7.000rpm shift points and 4.000rpm on the freeway at 60mph! 2. Its much easier on parts! Saves money so you can spend it on building an even bigger beast! 3. Its the Biggest Ego Bump ever when you tell people your combo and they are looking everywhere for the nitrous! Lol 4. Since you are not tearing stuff up all the time you get to go out and enjoy your car more! And you can even hear your radio because you aren't buzzing down the road at 4k rpm with Dual 3" exhaust! 5. You are Playing into a Pontiac Engines Strengths! Massive Power Right F'n Now! I use to run Big Block Chevys when i was young and even with a really nicely built 454 with a solid cam and "Small" Oval Ports at 255cc, RPM intake it couldn't hold a candle to any Pontiac i have ever built on the Street! Sure i can build a 496 chevy that makes great power but the pontiac just flat kills it on the street!
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
#267
I've got some 3" mandrel 45s I'm going to have welded to look like splitters and polish.
Might have to order some for future projects if they are going to close.
#268
I follow and enjoy reading about your car alot. Freaking fast. I also want to drive my car on the street and the track. My goal will be to run low 11's, I won't be running 3.08 gears since my 69 firebird has a Dana 60, 3.54's. But that's all good. Can't wait for you to hit a 10 second pass.
#269
Meant to add stainless steel 45s.
#270
Cool video comparing full 2.5" to 3" exhaust
https://m.youtube.com/watch?list=PLG...&v=_PVXvHkr-Vs
#271
Last night discussion with an expert racing engine designer/builder/tuner almost got sideways for me when I defended the use of 1/4 mile performance evals for the use of evalating road-race engines.
The fella was completely correct that "every part and everything done to a 1/4 mile engine needs to be thrown away when applied to a road race engine. 8700 rpm, 5000 stall converters, gears, tires, chassis. Then i said:" well yea except i do an off-idle launch with highway gears to get the numbers."
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#272
I watched every single Hotshot Corvette owner fail in the Corvette World fail to Street Race & Beat the Hellcats.
All I talked about was Pontiac Musclecars Street Racing in the End. Also Said Fick You & Chevy Power. Going back to my Pontiacs. Real Thunder. |
#273
Sorry, i didnt see this!
Yeah luckily he is going faster than without the port work lol I told him Good or Bad i want him to post the results! Its valuable information and if it didn't work like i thought i would go back to the drawing board ya know! Next up i want to do one my fully ported RPM intake, i want to get someone in the tens on pump gas with a car/engine like TAMAN's Take Care! Derek Stewart Racing engines Quote:
#274
BBC 467 10.1 compression AFR 265 heads (340 CFM) Edel RPM intake. 228/238 @ .050 hyd roller, .549 lift 111 LSA 573 fl.lbs at 3800 RPM TQ through mid is 585 - 590 591 HP at 5300 RPM HP ramps up to 628 HP at 6200 RPM Looked at a few "mild" 496 dyno sheets - TQ numbers are 640 plus In most cases traction is the primary issue on the street. |
#275
Pontiac 455's pull those numbers quite often, its not till you get over a 1,000hp that chevy has an advantage and thats because of aftermarket support!
541 pontiac 785hp at 6400, pump gas, Standard port SD 350 E-heads, no big deal Mild Setup Pump Gas Street 467 660hp 632tq mild hi ports, single Carb Pump gas 498cid Pontiac SD Street Engine 700hp 650tq standard entrance E-heads, single carb, not pushing anything hard. Notice how many 625-675hp 496 BBC's are running 11.50's and slower! Same power in a Pontiac runs Low 10's! PHR i think it was had some Bad Azz 496 that made a bunch of power on the Dyno went on to run so slow in the car they had 3 pages of excuses of why it didn't run 9's Pontiac's basic Design Functions Much better as a High HP Street/Strip Engine Cube for Cube From My Experience And Way to go Ernie! Wait till you guys see what he ran today! He is getting Faster!!!
#276
I think a lot has to do with Pontiac guys don't give up.
#277
I remember about 20 years ago being told The Pontiac V8 is dead.
It was by a well respected Mopar engine builder. I mentioned Arnie Beswick. He had norhing to say back to me. |
#278
690 HP on the same dyno as post 274 ran consistent 9.9s in a 3700 lbs Chevelle.
BBC 502 10.5 compression Out of the box Brodix 270 (340 CFM) Edel RPM Ultradyne solid roller - 255 @ .050 intake 4.10 rear axle. I don't care what some kid on the web claims. There are MANY happy dynos pushing high numbers! (saying half of dynos may be a stretch, maybe not) |
#279
I used to know a chebby guy. He had a 71 Chevelle 496 rectangular port iron heads, low rise single plane, Dominator, solid roller cam 11:1 CR. Ran 11.40's every outing at the track. But it wasn't immune to engine troubles. Broken valve train hardware, very rough idle, can't hang in traffic, overheating, he would never cruise long distances with his 4.11 gears, 4000 stall converter and tempermental combo. Yes it ran great ET's but was not well suited to street duty which is why he went LS eventually. A well built and well tuned Pontiac street machine will always be the best in my opinion and reliable to boot! Anyone of the other brand guys would have to see it to believe it and then they still would be skeptical to see a pump gas Pontiac running low 11's with 3.08 to 3.55 gears, HR cams, 3000 stall converters, Qjet or 4150 cam, etc. We all know there's a lot of tuning and know how to get there but that's not supposed to happen!
#280
Here is a far better PROVEN combo. Downsize to a 454 Factory iron OVAL ports, 2.19 / 1.88 installed and bowl work. 9.5 compression Ultradyne hyd flat 231/239 - 110 LSA - .555/.570 Edel RPM HP 1000 Carb 1.75 inch headers 4.10 rear axle. 11.4 @ 115 in a 3800 lbs car |
