Old 01-07-2019, 11:43 AM
tom s tom s is offline
Darin,Quality Restorations in south county SoCal.He has done WAY too many wheels for me.You might have to take a second on your house.I think he is up to like $1400 for them nowI had 3 of them done in one year.I think I have the first tempest wheel he did.Tom
  #262
Old 01-07-2019, 05:32 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Looking for right and left core supports, the front sheet metal that bolts to the fenders. This is for a 63 LeMans.
Driver's side is rusted and passenger side is dented.
  #263
Old 01-08-2019, 02:00 AM
blueghoast's Avatar
Are you talking per wheel and are you talking about Tempest steel wheels?
GT.
  #264
Old 01-08-2019, 11:42 AM
Darin is looking for a deluxe STEERING wheel,the clear one.Tom
  #265
Old 01-08-2019, 04:20 PM
Radman's Avatar
Radman Radman is offline
Originally Posted by mchlmacdonald View Post
Looking for some '62 Tempest parts:
stock-sized spare rim in good condition
Driver-side front fender in good condition
Plastic gauge-cluster cover
Aluminum-body Distributor for 4-cylinder (have a Pertronix electronic ignition that will only fit that style)
4 barrel intake
also looking for a spare 4-cylinder motor, shortblock or complete
thanks
Pictures of the parts
Name:	blue front.jpg
ID:	502314   Click image for larger version
ID:	502315   Click image for larger version
Name:	brown front.jpg
ID:	502316   Click image for larger version
ID:	502317   Click image for larger version
Name:	Rim front.jpg
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
  #266
Old 01-08-2019, 04:22 PM
Radman's Avatar
4 barrel intake
thanks
More parts
ID:	502319   Click image for larger version
Name:	engine exhaust side.jpg
ID:	502320   Click image for larger version
Name:	Engine front.jpg
ID:	502321   Click image for larger version
Name:	engine intake side.jpg
  #267
Old 01-10-2019, 12:45 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Default Deluxe steering wheel
Yes I am hopping to find deluxe one. It is the clear and black one with the clear horn button and inside is the arrowhead. I’m sure it’s hard to find and at 1400$ it may nor even be the deluxe style. I may have to resort to an aftermarket time period substitute. It’s not my first choice but don’t see a way of getting a decent replacement so far. Keep a lookout for me please. I would love to have the correct wheel in my hands after all of my efforts to make this car updated driveline but stock appearing look interior and exterior for the most part. Thank you for all the help again! Love Darren 203-650-4188
  #268
Old 01-10-2019, 11:34 AM
Darin,the 63 deluxe wheel uses the same horn button as the 61 deluxe wheel,I might even have one.If your really interested give Dennis a call and see if he has a core already.NOTHING you will put on your car will compare to the deluxe wheel.The first thing you look at when you get in!The blk with clear is stunning!My 63 is gold but my 62 GP is blk and they dont compare in look IMO.Tom
  #269
Old 01-11-2019, 01:48 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
The clear wheels, as you described, are the custom wheels. Deluxe is just a trimmed out version of the standard wheel.
I have 2 custom wheels, but you'd have to paint the non-clear parts black.
  #270
Old 01-15-2019, 05:55 PM
hobbygto65's Avatar
Default Wtb
Nos or a really good used manual steering pitman arm for a 63 LeMans..
  #271
Old 01-15-2019, 08:35 PM
I think I have the pitman still on the link bar.Will check when it stops raining.Left over from my power steering switch.Almost threw it away.Tom
  #272
Old 01-28-2019, 11:10 PM
sberbs's Avatar
sberbs sberbs is offline
Looking for the bottom rear window trim and the top front fender chrome pieces for 62 LaMans and the dash piece that is roundish on top of driver's side dash...not sure what that's called
Sent from my Pixel 3 XL using Tapatalk
  #273
Old 02-10-2019, 03:08 PM
hobbygto65's Avatar
Default WTB Junction block
Anybody have a good one of these to get rid of. Battery and S terminal junction block. Littelfuse 548719 stamped on back.
ID:	505286   Click image for larger version
  #274
Old 02-10-2019, 03:34 PM
Jmanaster Jmanaster is offline
Originally Posted by hobbygto65 View Post
Anybody have a good one of these to get rid of. Battery and S terminal junction block. Littlefuse 548719 stamped on back.
Super hard to locate. No repro but obviously there are other styles that work. The bakalite overheated and cracked on all I have seen. It seems to be a one year only and only for V8 at that. Wishing you all luck!
  #275
Old 02-10-2019, 04:46 PM
sberbs's Avatar
I have a 4cy l
4 barrel intake
thanks
  #276
Old 02-10-2019, 04:49 PM
sberbs's Avatar
What are you asking for the speedo / top of dash?
  #277
Old 02-10-2019, 07:40 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Can't you just use JB Weld epoxy to repair it and nobody would know the difference?
  #278
Old 02-10-2019, 09:05 PM
sberbs's Avatar
Here is my 62 4cyl
  #279
Old 02-10-2019, 09:30 PM
hobbygto65's Avatar
Johnfromventur, that's my next step if I can't find a good one.
  #280
Old 02-17-2019, 05:40 PM
hobbygto65's Avatar
Default 63 radiator baffles.
I guess that's what there called. Looking for undamaged left and right. Passenger side for sure. Mine is not repairable.
ID:	505880   Click image for larger version
