Old 04-21-2012, 05:28 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
So, how are they made. Extruded ?
Never had a set in my hands. But thinking about getting a set of non offset shaft T&Ds for my High Ports.
They looked forged or cast to me. Im not saying they dont build from billets, its just that my are not made that way. Im pretty sure its not extruded, if they were you would see at least two sides of the rocker being machined.
  #282
Old 04-21-2012, 07:42 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
All 100% factual....spot on, you just dont see it. Good luck!
SEARCH WEB Editlmc3470AOL.com|Sign Out| Options NewIMTextCheck Today on AOLNew Mail
Customize500+ Results for “e.page”Narrow Results
I tried...
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
  #283
Old 04-28-2012, 11:09 AM
Tom Vaught's Avatar
Boost Engineer
Camshafts are like Girlfriends, everyone has one and sees different qualities in each one of them. My "Opinion" is just that, based on what I have seen that works in the parameters (that I was provided with).
I would add another name to your contacted list: Steve Morris. Steve has a great deal of boosted engine camshaft experience (verified with dyno testing). Really it boils down to what Ed thinks that he wants. Ed can try a bunch of camshafts (if he has the money) until he gets the one that HE is satisfied with. Everyone else is just providing Ed with information, based on their backgrounds.
Even with a background in Behavioral Psychology, lol, I cannot control how people buy camshafts and from whom.
Have a great day. Looking forward to Ed's final engine numbers with boost.
Tom Vaught
  #284
Old 04-28-2012, 01:04 PM
Travis Q Travis Q is offline
Originally Posted by cgeise View Post
ED
I looked at your list of "special" things to help the valve train - and had to say HMMMM -- isnt most of that what you would expect from any first class job done on a set of high end heads???? At 275lb he is prob more than ok for STREET USE, BUT raise the boost and the rpm and the pressure is going to effect it. Are those "custom" valves Titanium -- that would help -- some, weight to spring pressure and added pressure from boost is what it is. If the spring is to light to handle the weight AND the boost pressure the valve seat and its " special seat material" will not matter -- as the valve will not reach the seat -- or at least not when and how its supposed to. The key is -- rpm and boost pressure --up to a point he will be fine -- past that not so good - -so who is defining that point???
X1,000,000
  #285
Old 04-28-2012, 09:24 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
ED
Hi Curt,
To hit the day-1 1600hp Pump-Gas design goal, the data supplied by Turbonetics says ~20lb of boost assuming the base NA HP was 751.6. The one dyno sheet I've seen says the engine makes 660hp.
The valves are not Titanium. Victory stainless intake, inconel exhaust. This is another case where I don't have the actual part numbers.
  #286
Old 04-28-2012, 09:33 PM
RAIV-Z's Avatar
Tom Vaught
Hi Tom,
What parameters were you provided with for this build and were your opinions used in this camshaft design? I’ve gotten a few different stories regarding the origin of this cam.
  #287
Old 04-28-2012, 09:53 PM
R 70 Judge's Avatar
Hi Tom,
Sorry about all of your troubles. What a crappy situation
Cam designs for turbo applications are all over the place depending on who you are taking to. Some do a split with more intake duration than exhaust, other do the opposite similar to a supercharger type cam. Find someone you trust with a proven track record of making turbo cars run and go with them.
James
1970 Trans Am
  #288
Old 04-28-2012, 10:26 PM
RAIV-Z's Avatar
I'll work through it with the help of the guys on the board and get this thing running.
  #289
Old 04-28-2012, 10:43 PM
Tom Vaught's Avatar
Boost Engineer
Hi Tom,
Cam design for your turbo engine did not come from me, (to the best of my limited knowledge) on your RA-V deal. I had no info on your head flow and rpm targets so pretty hard to make a valid camshaft recommendation.
I think my ONLY input in the deal was I said "I would dyno the engine at Steve Morris' shop and then he can pick a custom turbo camshaft based on that dyno info". Steve Morris, in my opinion, based on observing several very high HP Turbo Dyno sessions that were successful at Steve's shop, had the ability to give you a very nice high HP Turbo Engine. Sorry to hear that you are having all of these issues on your build.
Tom Vaught
  #290
Old 05-03-2012, 05:14 PM
RAIV-Z's Avatar
Making some progress on the cage.
ID:	283507   Click image for larger version
ID:	283509   Click image for larger version
ID:	283510   Click image for larger version
  #291
Old 05-09-2012, 07:58 PM
RAIV-Z's Avatar
Default More Chassis Pics
Started mocking up the engine today.
ID:	284044   Click image for larger version
ID:	284045   Click image for larger version
ID:	284046   Click image for larger version
ID:	284047   Click image for larger version
  #292
Old 05-09-2012, 08:25 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
looks great! is the crank center line altered much from stock location Ed?
  #293
Old 05-10-2012, 05:37 PM
RAIV-Z's Avatar
Thanks Jeff,
The engine wasn't in the final location yet, I don't think we're going to be able to move it too far from the stock location due to header clearance.
  #294
Old 05-24-2012, 06:26 PM
RAIV-Z's Avatar
Got the rest of the SmithRaceCraft parts in this week and made some progress on the cage.
ID:	285489   Click image for larger version
ID:	285490   Click image for larger version
ID:	285491   Click image for larger version
ID:	285492   Click image for larger version
  #295
Old 06-14-2012, 02:37 PM
RAIV-Z's Avatar
Default Stretched Quarters
Almost ready for the rearend.
ID:	287626   Click image for larger version
ID:	287627   Click image for larger version
ID:	287628   Click image for larger version
ID:	287629   Click image for larger version
  #296
Old 06-16-2012, 02:04 AM
jdw_poncho's Avatar
Looks good, it seems your starting to catch up with me!
Are you going with a standard 9" or stepping up to a 9.5" rearend?
  #297
Old 06-16-2012, 11:44 AM
RAIV-Z's Avatar
Going with an ultra case, it will accept either. Haven't picked the gears yet.
  #298
Old 06-16-2012, 02:22 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
looking good!!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #299
Old 06-16-2012, 07:27 PM
RAIV-Z's Avatar
Originally Posted by Jeff Kinsler View Post
looking good!!!
Thanks Jeff,
Things are moving along, but it doesn’t look like the car will make it to Norwalk this year.
  #300
Old 06-21-2012, 01:44 PM
RAIV-Z's Avatar
I'll be sticking with the standard 9" ring gear. Does anyone make a 3.xx ratio 9.5 gearset?
