Old 04-01-2015, 06:09 PM
Glenn Sedig Glenn Sedig is offline
Default 2.3
Originally Posted by dci View Post
WOW that's really cool, good job !!! Do you mind sharing engine specifics?
IA II block
473 cu
4.310 bore
4.050 stroke
6.800 alum rods
1.9 rocker ratio
1000 lb open spring pressure
All Tiger heads Port work by BES Racing 450 ish cfms 55cc chambers
7/16 push rods
Wenzler 2 X 4 intake manifold Port work by Vintage Mechanical Works per BES specs.
(2) 1150 Dominator carbs 102 main jets Q-16 fuel
Comp cams .995 lift 282 intake 300 exhaust @.050 4 - 7 swap
Headers built by Vintage Mechanical Works Step 1 1/4 dia to 1 3/8 dia
  #282
Old 04-01-2015, 06:24 PM
mike leech's Avatar
mike leech mike leech is offline
Originally Posted by Glenn Sedig View Post
Don,
I don' usually blow my horn but we just spent Monday 3/30/2015 on BES's dino and got to 1075.5 hp and 763.0 ft/lb trq out of 473 cubic inches. Need 12 more hp to get to get 2.3 hp/cu. We could possibly get 12 hp but it will take more manifold and carburetor work. I need to improve the performance of the rest of the car before I spent ???? on 12 hp.
Congrats Glenn those are great numbers!
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #283
Old 04-01-2015, 06:30 PM
slowbird's Avatar
slowbird slowbird is offline
IA II block
473 cu
4.310 bore
4.050 stroke
6.800 alum rods
1.9 rocker ratio
7/16 push rods
Congrats Glenn! Looking forward to seeing it run.
One question, what was the hp peak rpm?
  #284
Old 04-01-2015, 06:45 PM
tom s tom s is offline
Nice job Glenn,CU at Norwalk!Tom
  #285
Old 04-01-2015, 06:50 PM
Default 2.3
7900 rpm peak hp.
7100 rpm peak trq.
  #286
Old 04-01-2015, 07:12 PM
dci dci is offline
VERY VERY NICE!!!! I bet that thing sounded awesome on the dyno. Looks like your the man of the hour when it comes to HP per cube. Thanks for sharing Glen. Not allot of people will do that and Kudo's to you Sir.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #287
Old 04-01-2015, 07:33 PM
And a small motor!
  #288
Old 04-01-2015, 07:43 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Wow, Awesome numbers Glenn!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #289
Old 04-01-2015, 07:51 PM
slowbird's Avatar
And a small motor!
Your race this year could be pretty interesting.
  #290
Old 04-01-2015, 08:18 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by john marcella View Post
At 500 cid I think we have the induction capabilities now with several heads. But its still going to take king kong lobe area above .200 to get it done IMO. A build like this is not just heads cam and intake, ITS EVERY THING!
Truth
TV
  #291
Old 04-01-2015, 11:24 PM
2.2737843551797040169133192389006 HP per cube... Wow! Odds are good the missing 12 may show up as track time loosens things some plus small tweaks as you go... Agree, too close to race season to chase for it on the dyno...
WTG! Good luck this season.
  #292
Old 04-02-2015, 07:40 AM
Gary H's Avatar
Gary H Gary H is offline
IA II block
473 cu
4.310 bore
4.050 stroke
6.800 alum rods
1.9 rocker ratio
7/16 push rods
First off. Great power, very impressive! Question on the headers. I think you meant 2 1/4 dia to 2 3/8 dia. Did you try any different size headers on the dyno though?
  #293
Old 04-02-2015, 08:28 AM
Chris Uratchko Chris Uratchko is offline
Don,
Very nice, great work!
Uratchko Racing Engines
www.ure-racing.com
  #294
Old 04-02-2015, 09:54 AM
Default 2.3
Yes 2 1/4 dia. to 2 3/8 dia. with 4" collector. We did not try any other headers, maybe 12 hp is hiding there. I asked Tony if one of his BOP intakes and 4 barrel carb could make more power, his first reaction was no and then he said with major work on the carb and cutting the manifold to get the runners right it may make a little more power.
  #295
Old 04-02-2015, 10:01 AM
60man's Avatar
60man 60man is offline
Wow!! Very nice numbers out of a "small block " Pontiac.
Guess Purple Prix will be quick. Assuming it gets motor.
See you at Norwalk.
ECM member.
MANDRA
  #296
Old 04-02-2015, 12:07 PM
Hooter's Avatar
Hooter Hooter is offline
Nice job Glenn. Can't wait to see it at the track.
67 Bonneville ragtop
  #297
Old 04-02-2015, 05:40 PM
cfmcnc cfmcnc is offline
Default 2.3 per cu-in
Nice job Glenn and all involved.Maybe a can of VP C45 will put it over the number.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
  #298
Old 04-02-2015, 08:59 PM
dda72's Avatar
dda72 dda72 is offline
X2. Congrats Glen!!
  #299
Old 04-02-2015, 09:04 PM
Half-Inch Stud's Avatar
Should ride-up with wear
  #300
Old 04-02-2015, 09:52 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Well done Glenn!
