Old 06-19-2016, 01:01 AM
69FIREBIRD76MM's Avatar
My buddy built a ford Mustang fox 306 cid. block, Pretty basic. That thing will run 7.20 at the 1/8. Drove it every where. There is other brands with smaller engines running faster than bbc.
  #282
Old 06-19-2016, 01:53 AM
ta man ta man is offline
I wasn't expecting huge results due to the hot weather compared to the last outing..I will check the DA of both days to see what it was...Ran five times..1st pass 11.23/121.28 1.6469 60ft,2nd pass 11.21/121.52/1.6457 60ft,3rd pass 11.2179/121.97/1.6810 60ft,4th pass 11.2052/122.23/1.6782 60ft,5th pass smoked the tires track got dirty from some trucks 11.566/121.92/1.8879 60ft
Beat the old best by quite a margin in warmer weather..the tailpipes were a restriction.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #283
Old 06-19-2016, 07:54 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Are you running just the dumps after the muffler?
  #284
Old 06-19-2016, 08:27 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Do you think the gain was from less restriction or from the shorter pipe length of the system tuning to a higher rpm and helping the top end charge? Those Ultraflows look like a straight pipe to the motor so maybe tailpipe length affects the torque curve somewhat.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #285
Old 06-19-2016, 08:31 AM
Steve C. Steve C. is offline
Related ?
"As far as power is concerned, tail pipe length after the mufflers has no measurable effect on the power if a large change in cross section is present up stream (toward the motor) of the tail pipe. An open-type muffler, or a resonator box, provides this cross-sectional change. The tail pipe length exiting most glass pack installations is also of little consequence if a resonator box is used, but is of significant influence if not."
http://www.superchevy.com/how-to/exhaust/0505phr-exh/
It won't be long and he will be making 10-second passes
Old information here:
  #286
Old 06-19-2016, 09:31 AM
wheneaglesfly wheneaglesfly is offline
The Annular Booster 950 Holley Worked.
Netted real world gains.
  #287
Old 06-19-2016, 09:37 AM
TCSGTO's Avatar
I don't think he's tried it yet.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
  #288
Old 06-19-2016, 10:00 AM
Ok.
I have Torque Tech Daul 3.00 on my 1970-1/2 Trans Am.
Tailpipes included.
3-1/2 to 3.00 Long length collector Merge Reducers.
About 18.00" overall lengths.
The 1085 Bo Laws carb of mine I was told to run True 4.00" ID On the 410 sbc of mine with that carb.
Open 4.00" Header collectors preffered.
The Math Science of Pontiac V8 is unique.
Test with what he has.
See what happens.
  #289
Old 06-19-2016, 10:11 AM
pastry_chef's Avatar
NOT
Exactly why the fastest Pontiac guys have their stuff done by builders who do NOT specialize in Pontiac. FACT
  #290
Old 06-19-2016, 10:19 AM
How much HP ARE WE TALKING ABOUT ?
HOW MUCH MONEY REQUIRED ?
2 MILLION DOLLARS ?
4,000-10,000 HP ?
ITS STREET PERFORMANCE. & STREET RACE SECTION HERE.
PONTIAC BUILDERS.
HOME DONE BUILT.
LIMITED BUDGETS.
YOU CAN TRUST CHEVY.
I WON'T.
ONLY FORD GUYS TOO.
  #291
Old 06-19-2016, 10:21 AM
slowbird's Avatar
slowbird slowbird is offline
2 MILLION DOLLARS ?
4,000-10,000 HP ?
PONTIAC BUILDERS.
HOME DONE BUILT.
LIMITED BUDGETS.
I WON'T.
ONLY FORD GUYS TOO.
What?
  #292
You should meet Rick Johnson.
Fick & Fick non stop.
  #293
Old 06-19-2016, 10:23 AM
Originally Posted by slowbird View Post
What?
Exactly .
  #294
Old 06-19-2016, 10:27 AM
grandville455's Avatar
grandville455 grandville455 is offline
Thats Awesome ernie!!!!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #295
Old 06-19-2016, 10:38 AM
PAUL K's Avatar
PAUL K PAUL K is offline
X 2
Go fast, see Elvis!
  #296
Old 06-19-2016, 10:41 AM
slowbird's Avatar
What has Rick done?
  #297
Old 06-19-2016, 10:45 AM
slowbird's Avatar
X 2
X 3
  #298
Old 06-19-2016, 01:16 PM
Chicagogoat's Avatar
Chicagogoat Chicagogoat is offline
I gotta say Pontiac is unique in that it doesn't take "race parts" to go "fast". Show me a Ferd or Chebby guy going low 11's with 3 speed Autos, 3000 stall converters, 240ish duration and .600ish lift HR cams, and friggin 3.08 gears in 3800-4000 lbs street machines!
  #299
Old 06-19-2016, 01:24 PM
PAUL K's Avatar
^^^Truth^^^
Go fast, see Elvis!
  #300
Old 06-19-2016, 01:28 PM
And doing this with pump gas while not overheating in traffic, hard to beat a well built Pontiac! Plus we actually work harder on our stuff to squeeze more performance and reliability than your average Chebby guy.
