Old 07-14-2020, 11:54 AM
rdtripn_rte66 rdtripn_rte66 is offline
Default ebay items
Originally Posted by Sanduners View Post
I just put on EPay a couple of items, a pair of re-chromed top fender spears and a convertible mirror bracket if interested. I still have lots of parts from my last rusted out car.
JIM - you should post ur eBay id store name - make it easier to find all parts
Robin Triplett
Midwest Director of the Little Indians Club
417-456-9858 cell
63 Lemans convt. Present
1970 350 Firebird motor built to 69 350 HO specs
Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals)
700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup
65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8")
  #282
Old 07-14-2020, 12:28 PM
1963 PARTS - I have several Trunk lids, HT doors, convt frame, windshield valence panels, lower front cowl, 1 fr fender that was cut off at the front bumper bolt but is solid for patches, hood hinges, headlite buckets, bumpers, complete auto transmission and axles, 63 HT parts car w bench seat and rear seat, steering wheels, drums, break cyl, manual brake reservoir, misc bolts, rear conv arm rests, 63 power window setup out of Buick Special, emblems, tons of stuff.
GOING TO THE PONTIAC UPRISING IN GREAT BEND KS SEPT 18-19 2020. CAN BRING STUFF ALONG THAT WILL FIT INTO TRUNK OR BACK SEAT (DRIVING MY CAR).
Let me know if I can help you Thanks -
Robin Triplett
417-456-9858 cell
  #283
Old 07-15-2020, 02:15 PM
firefour1 firefour1 is online now
Do you have any of the drive train parts? Engine / Bellhousing / drive-shaft etc?
  #284
Old 07-26-2020, 02:51 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
Lots of them and I'll be driving thru Iowa in the coming days. What do you need?
  #285
Old 07-27-2020, 10:00 AM
Default Drivetrain Parts
Looking for the bellhousing, flywheel, starter, rope-shaft & housing.
  #286
Old 08-07-2020, 02:28 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Auto or manual. I am in Jesup Iowa and have automatic transaxle parts...ropeshaft, torque tube, bell housing, etc
  #287
Old 08-14-2020, 08:09 PM
I have two complete auto trans (1 out of car 1 in). The 1 in is a 4 cyl auto so rope shaft and components all in tach. Some pcs off engine.
I sent Jim Colln the v8 rope shaft that I bought last summer from Chicago. That auto rear end is from a V8 and out of car. Torque tube in my shop.
Give me a call if you have specific questions. Thanks -
Robin Triplett
417-456-9858 cell
  #288
Old 08-15-2020, 01:32 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
I don't have any connection to this seller; on ebay right now there is a 1963 Tempest-Lemans NOS fuel tank sender which is something that many people, I think would need.
https://www.ebay.com/itm/383665801158
Peter Serio
Owner, Precision Pontiac
  #289
Old 09-03-2020, 08:10 AM
newmexguy newmexguy is offline
Originally Posted by newmexguy View Post
Pair of doors, loaded. Marked by yard as '63. Willing to package and ship for serious customer. No interested in parting - unless someone needs door hinges, which are with these doors. Or ALL the guts in both doors. Will need to go Bus unless willing to step up for truck freight.
$500 before shipping. Dave S - Carlsbad / dona Ana NM
To the Top, still available. Dave S Dona Ana NM 88032
ID:	548577   Click image for larger version
ID:	548578   Click image for larger version
  #290
Old 09-05-2020, 01:23 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 63 carb linkage
I have a couple of these carb linkages, $20 shipped.
Hundreds of parts for the 63's and a few 62's available, PM or email me.
ID:	548754   Click image for larger version
  #291
Old 12-12-2020, 12:59 AM
Sanduners's Avatar
Default NOS BUMPER GUARD KIT 1961 1962 TEMPEST LEMANS 989790
A new pair of rear bumper guards for a 1961-62 Pontiac Tempest / Lemans. There is one bracket and a few bolts missing from this kit. $100 Free Shipping!
  #292
Old 12-12-2020, 12:22 PM
sberbs's Avatar
sberbs sberbs is offline
Originally Posted by TransaxleTempest62 View Post
That's a 62 subframe so I would say yes.
I have 3 speed if that interests you
Sent from my SM-N986U1 using Tapatalk
  #293
Old 01-22-2021, 05:05 PM
gem66 gem66 is offline
Default 1962 4cyl upgraded
Rebuilt with less than 2000 miles. 194 + .030 pistons, crank .010/.010, edelbrock d port 72cc heads, custom 4 barrel intake made from edelbrock performer intake, holley 600 vacuum secondary carb, 1.65 roller rockers with tall valve covers (needed to trim heater blower housing). Runs well, in the car now, moving to v8. I do not have the extra heavy flexplate/flywheel.
$2500 or best offer, local pickup in Barboursville, VA.
ID:	559131   Click image for larger version
ID:	559132   Click image for larger version
ID:	559133   Click image for larger version
ID:	559134   Click image for larger version
1970 Firebird 3200lbs - CVMS built, pump gas 461, 3.89 gear 29.5x10 inch tire,... 10.40 @ 129mph.
  #294
Old 01-22-2021, 05:06 PM
Sorry about the sideways pictures.
  #295
Old 01-23-2021, 09:40 PM
TransaxleTempest62 TransaxleTempest62 is offline
What is the compression ratio?
What cam?
Was it on the Dyno?
Thx
  #296
Old 01-23-2021, 09:41 PM
No thank you.
  #297
Old 01-25-2021, 08:16 AM
What cam?
Was it on the Dyno?
Thx
I believe the compression is around 11:1, runs really well on 93 octane with 32 degrees in the distributor. Cam is stock and have not had it on a dyno.
  #298
Old 01-25-2021, 08:19 AM
Compression ratio might be less than that, I'm not sure. 72cc heads, flat top piston with 6cc valve reliefs, standard stroke + .030 bore. it seems that the pistons were down in the cylinder a bit and not zero deck, probably around 10.5:1.
  #299
Old 01-31-2021, 06:39 PM
If someone is interested in just the head/intake or just the short block I am open to offers. Thanks.
  #300
Old 02-04-2021, 08:57 PM
ricks63 ricks63 is offline
I have a pair of rear quarter windows from a 63 Lemans convertible, very nice condition chrome is really nice. 150.00 for the pair plus shipping located in Ontario, Canada. Can text you pics if your interested . rick 807-629-4718 Thanks
