Old 02-20-2019, 06:20 PM
Chiefkey Chiefkey is offline
Default 63 Rear Differential Parts Needed
Shop called and said my differential carrier, spiders/ shafts were toast.... anyone out there have any NOS or good used Differential internals for sale ?
JK
  #282
Old 02-21-2019, 09:01 AM
c5farmer's Avatar
c5farmer c5farmer is offline
I have a couple differentials from Four cylinder cars. Let me look next week and get back to you. I am in Iowa.
  #283
Old 02-21-2019, 09:07 AM
sberbs's Avatar
sberbs sberbs is offline
JK
Mine will be available from my 62 LeMans
  #284
Old 04-12-2019, 06:25 PM
strawmann strawmann is offline
Anyone have the plate with buttons that attaches at the bottom of a convertible roof and want to trade it for money? It's for a 63 Lemans.
  #285
Old 04-14-2019, 06:00 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Convertible chrome top boot trim?
Hi, are you talking about the stainless steel trim that wraps all the way around the opening on the car that the top folds down into? The one that has the studs for the snaps in the soft boot; for the top boot to attach?
Peter Serio
Owner, Precision Pontiac
  #286
Old 04-14-2019, 07:42 PM
Yessir. It's this piece marked in the attached image.
  #287
Old 04-14-2019, 09:49 PM
I parted out a '63 Lemans convertible about 10 years ago and I did save those 2 pieces. PM me.
Peter Serio
  #288
Old 05-04-2019, 09:55 PM
heater63's Avatar
heater63 heater63 is offline
Default 62 windshield
Looking for a windshield for a 62 Tempest. Will be at Norwalk for Summit nationals June 2019 if that works for anyone.
"If you aren't first, your last." Ricky Bobby 2006
  #289
Old 05-06-2019, 07:00 AM
Nevin Nevin is offline
Default 4 Door Parts
I am trying to save a rusty 62 4 cylinder on a budget. would anyone happen to have door glass for a good price.I do not have the heart to part this car out. i will be at Pontiac in pigeon forge in June. also i may be removing some of the stock parts like the front drums if you someone will need cores. Thank You
  #290
Old 05-09-2019, 07:51 AM
1979birds 1979birds is offline
Hi looking for a rear emergency cable for a 62 tempest. Anyone have one or know of anyone making them?
  #291
Old 05-09-2019, 11:31 AM
I'd look at Ames and USA Parts.
http://www.amesperf.com/catalogs/T4.pdf
http://usapartssupply.com/uploads/US...ac_Catalog.pdf
  #292
Old 05-09-2019, 11:54 AM
Thanks. Ames has one for a 63. Does anyone know if it will also fit a 62?
  #293
Old 05-09-2019, 11:55 AM
Call and ask. They're really helpful and knowledgeable over there.
  #294
Old 05-09-2019, 12:05 PM
I called them and they say it is 63 only. He said doesn't know what the difference is. Does any one know if I can make it work?
  #295
Old 05-09-2019, 12:20 PM
tom s tom s is online now
Give Inline Tube a call.Tom
  #296
Old 05-21-2019, 09:10 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default WTB - 63 V8 Carb return spring bracket
Looking for this bracket, found on the V8 326, Carb return spring bracket.
Thanks!
  #297
Old 05-22-2019, 08:55 AM
beemergary's Avatar
They made mine for my 61 and 63 Ford nine inch conversions.
  #298
Old 05-29-2019, 02:34 PM
Default Front fender gills
Anyone have a set of left and right front fender gills for a 62 tempest that I wont have to get rechromed?
  #299
Old 05-30-2019, 06:42 PM
indiantony indiantony is offline
Default Powersteerting and Alternator Bracket and double Crank Pulley
I'm looking for a powersteering and alternator bracket for a 71 YS motor with 6x heads that I'm putting in my 63 Tempest. Also double crankPulley for same motor.
Tony
917-681-6534
  #300
Old 06-20-2019, 07:52 PM
Default Water Pump Pulley
Looking for a water pump pulley with these dimensions
Diameter 7 1/8"
Height 2 5/8"
Bolt spacing 2 1/8
Tony
917-681-6534
ID:	514540   Click image for larger version
ID:	514541   Click image for larger version
