Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-30-2010, 12:04 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Anyone need the following parts?
70 lemans grille mount parts
John
Email [email protected]
My Website www.minnesota-muscle.com
  #302
Old 12-31-2010, 06:38 PM
DOC DOC is offline
Free to a good home, . The coffee can is full of screws, pull-offs, fast idle solonoids, do-dads and whatchamacallits, a few hangers and secondary metering rods as well. Just pay shipping or pick up: $10.70 or $14.50 for flat rate boxes.
[email protected]
ID:	229402   Click image for larger version
  #303
Old 01-01-2011, 03:10 PM
Rack776's Avatar
Rack776 Rack776 is offline
[email protected]
Email sent for carb parts. I can use all of it.
Thanks! - Jason
Jason Rackawack
1975 455 Trans Am - 1975 Firebird 400
  #304
Old 01-03-2011, 03:23 PM
DOC DOC is offline
Jason, They are on the way! Email sent w/ the details.
Doug
  #305
Old 01-07-2011, 10:46 PM
Rack776's Avatar
Big box of carb stuff arrived and has a lot of what I need,
Thanks alot! I wish everybody was as easy to deal with as DOC.
On sunday I'll take some photos of some freebies to post on here in case anyone needs them. I've gotten alot of favors on PY lately and I'd like to add a deposit to the
"Lucky Break Bank"
Jason Rackawack
  #306
Old 01-09-2011, 02:14 PM
mysticmissle's Avatar
im looking for a 90* oil filter housing. not sure it isnt going to create more problems then it will solve but I'd like to see how it fits. thanks in advance
  #307
Old 01-14-2011, 08:05 PM
got one thank you Ron Genovese!
  #308
Old 01-25-2011, 10:27 PM
Rack776's Avatar
Default Comp Cams Carb Spacer - Free plus shipping.
Here's a freebie, send me the shipping cost and its yours,
I think it will fit in a USPS $5 priority mail box.
New in package Comp Cams 1" carb spacer for standard Holley Square Flange.
Part #VH311
Shoot me a PM and I'll arrange shipping details.
Jason Rackawack
  #309
Old 01-25-2011, 10:37 PM
Rack776's Avatar
Default Aftermarket T/A wheel spoiler
Free to good home, just send me the actual shipping costs.
Aftermarket Rear Drivers Side Wheel Spoiler for 70-78 Trans Am
-Perfect for race car or low buck driver that needs repair.
-It mounts to wheel well lip
-No inside mounting points included, it must be fabricated if needed.
-I belive it was made by A&A Fiberglass in the 1990s
-It is made of flexable polyeurothane
-Part Number 53614-LS
-I only have this one - I do not have the other three
PM me your shipping info and I'll get a quote on the actual cost.
Jason
ID:	232168   Click image for larger version
Jason Rackawack
  #310
Old 01-25-2011, 10:52 PM
Rack776's Avatar
GONE!
The carb spacer is spoken for,
Awaiting shipping payment.
Jason Rackawack
  #311
Old 01-27-2011, 01:04 PM
Drew W's Avatar
Drew W Drew W is offline
I'm looking for a 4 bbl throttle cable bracket for a '72 LeMans.
thanks
Drew
Fifteen hundred years ago everybody knew the Earth was the center of the universe. Five hundred years ago, everybody knew the Earth was flat, and fifteen minutes ago, you knew that humans were alone on this planet. Imagine what you'll know tomorrow. - K (from MIB)
1972 LeMans Sport convert (T41) '70 XF 455, TH400, 3.31 12-bolt Posi
  #312
Old 01-29-2011, 02:18 PM
antique69lemans antique69lemans is offline
Default Rear defogger pieces
This is not performance parts, but maybe someone can use it. I have a rear defogger housing, gasket and grill for 1968 and back. Pay shipping and it's yours.
http://s1133.photobucket.com/albums/...t=IMG_7233.jpg
I could use a good thermostat housing for a 1969. Mine is pitted too bad to use.
  #313
Old 02-02-2011, 04:38 PM
Got a thermostat housing , Thanks !
  #314
Old 02-02-2011, 05:05 PM
marxjunk marxjunk is offline
i could use the defogger stuff...mine is missing the grille...is there anything you need?I see you got the waterneck, i have alot of detail stuff...
  #315
Old 02-03-2011, 06:42 PM
Default carb spacer
I have a used " 4 hole phenolic carb spacer, in perfect condition. (moroso 64930).
Shipping should be $5 or less.
I am looking for engine fasteners for intake, oil pan,(need one pan rail reinforcement), water pump etc.. I don't want to strip my original motor for this build.
I also need the linkage rod for a 1972 divorced choke (4V). I have the coil and cover.
Defogger parts are taken.
Old 02-22-2011, 10:07 PM
stracener stracener is offline
antiquelemans: I have fasteners from an original '72 GTO 400 for the oil pan (w/corner reinforcements) and intake (it was a Performer intake). Will be glad to trade for the spacer, or just send you the bolts if someone has already spoken for the spacer. Let me know.
DAve
  #317
Old 02-22-2011, 11:33 PM
DAve
I'll take that deal,
Spacer is yours.
  #318
Old 02-27-2011, 11:17 PM
form74's Avatar
form74 form74 is online now
Originally Posted by form74 View Post
Can't seem to throw stuff away, so come get it or pay for shipping only.
Pinion Gear 3.08 from a 75 Formula Rearend
Heat Shield mid 70's Std Pontiac engine
Air Cleaner PCV Tube from a standard air cleaner
Tire Irons
Left Side 74-78 Firebird, Formula, Trans Am Taillight,
Bump, still got this stuff
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
  #319
Old 02-27-2011, 11:18 PM
form74's Avatar
Water Pump and Crank Pulley from mid 70's cars.
pickup or pay for shipping.
Bump, still got these also
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
  #320
Old 03-09-2011, 10:35 PM
shook1's Avatar
shook1 shook1 is offline
Default 1970 GTO grilles -Pontiac Trans and converter wanted NJ
Jobstown, NJ 08041.... I found three 1970 GTO grilles in the scrap yard. One side with emblem, and two of the other side. I removed the GTO emblem, and used it for display on my shelf. Does anyone local need the grilles? I can take pictures, or describe them, but I'd rather not ship them. There's no charge, as long as you need them for your car. (Emblem not included).
I'm looking for a good, ready to bolt in, th350 Pontiac transmission with converter, for my 66' Tempest. Does anyone have a cheap or free one in NJ?
