Old 06-06-2015, 08:47 PM
Agree!
Old 06-07-2015, 06:13 AM
gavin gavin is offline
The M/T salt car was rumored to have cranks cast from nickel. The reason I bring this up is because a casting pattern for a flat crank would be quiet easy to make and simple in design. Perhaps a short stroke flat crank 3" or 3.5" in a 301 block could give intake and in particular exhaust tuning that could help.Smokey noted that a tempest 4cly engine made more HP per ci than the 421 sd with the same head and cam timing. This was most likely because of exhaust tuning as X design V8s tune as two v4s while a flat plain tunes as two inline 4s.While 180 degree headers get round that the tube lengths you end up with are too long for a high rpm engine.It may be that nickel is not strong enough for a big stoke engine but maybe ok for a short stoke with pin to mains overlap.Of course you then need a custom camshaft but that cost maybe moderated as you need a less exotic valve train for smaller lighter valves and shorter push rods ect.It wont win pro stock but it might come close to your HP to ci target.
Old 06-07-2015, 11:27 AM
Tom Vaught's Avatar
Boost Engineer
We like the Flat Crankshaft so well we put it into production:
https://media.ford.com/content/fordm...0-mustang.html
Tom V.
Old 01-22-2016, 03:10 PM
dci dci is offline
Bringing this back to the front for discussion. I need to see some creative thinking this time of year to keep my brain from freezing.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 01-22-2016, 05:12 PM
Mike Davis's Avatar
Creative thinking---
send me a set of RAV to put on my 446CI motor with a 2x4 intake. I will supply headers, carbs and gaskets. See if it will take a 3700lb NSS car from 10.10 to 9.75.
Then I will get them approved in NMCA.
Hows that for creative?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 01-23-2016, 02:50 PM
dci dci is offline
Mike I'm pretty sure my pump gas 455 with my RA5 heads will put you in the mid nines with a single 4. I like the way you're thinking though.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Old 01-23-2016, 06:39 PM
Mike Davis's Avatar
Well that would be nice if I could run a single 4.
Rules limit me to either 3x2 Rochesters or Dual AFB's.
i have tried to get Holley's approved but no dice.
Included in my above offer is another free 30- 35 mile ride around Norwalk OH in my car----again--lol
421 CID
Old 01-25-2016, 11:24 AM
dci dci is offline
Does anyone have a formula that's accurate for determining CSA needed for different cubic inches, rpm, and or piston speed ? Also what wave should the intake and exhaust be tuned for to produce better than 100 % VE's ? Here is a good short article I found for some to get a basic understanding of what I'm talking about.
https://performancespecialties.wordp...system-tuning/
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Old 01-25-2016, 01:36 PM
dci dci is offline
Stan, do you have any formula's that can be used and edited for those parameters? I'm sure they are out there or dyno simulators couldn't be used.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Old 01-25-2016, 02:32 PM
Stan Weiss's Avatar
Don,
I sent you an email.
Stan
Pontiac Pump Gas List
Old 01-25-2016, 01:49 PM
dci dci is offline
Here is some creative thinking I found. Notice the cfm increase in the different stages of porting.
https://www.facebook.com/photo.php?f...type=3&theater
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Old 01-25-2016, 02:35 PM
Half-Inch Stud's Avatar
dimples
Old 01-25-2016, 04:29 PM
I have a few calculators that might help:
Intake Runner and Peak Torque calc
Intake Mach Calc
Plus many others under the Head - Intake section here:
Automotive Calcs
Figure out what specific parameters wanted, I might be able to make one.
Old 01-29-2016, 12:31 PM
mike leech's Avatar
mike leech mike leech is offline
biggest bang is sealing the hood as you may know. then sheet metal, then dray sump(maybe, should help under inertia....=go faster.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 01-29-2016, 04:15 PM
John,
I tried alcohol and got no improvement.
Glenn, did you use carbs with the alcohol when you tried it?
Old 01-29-2016, 07:11 PM
slowbird's Avatar
slowbird slowbird is offline
I agree with Mike sealing the hood and intake will proved most gain. Guessing you could find .1 maybe .15 with those changes.
Old 01-30-2016, 04:35 PM
dci dci is offline
Glenn, please correct me if I'm wrong, but your peak HP and peak TQ numbers look to close together to me. That needs to be investigated because if you can spin the engine a little harder you will obviously make more power. Typically you should see about a 1,500 rpm spread between HP and TQ.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Old 02-01-2016, 03:37 PM
Glenn Sedig Glenn Sedig is offline
I wonder if a sheet metal intake would increase hp and rpm? My intake runners may be a bit long and making more torque? Or, would sealing the carbs to the scoop make the intake closer to optimum?
Old 01-30-2016, 06:04 PM
mike leech's Avatar
Fwiw i would say its not as unusual as it might think don. For the stroke the torque is high IMO. That would lend to a more efficient head/combo. Although i would like to see pk hp and tq occur higher. Like a 1000 rpm
EHTTFMF!
Old 01-30-2016, 06:47 PM
dci dci is offline
Mike I agree he has a pretty efficient combo, but even pro stock engines have about a 1500 rpm split. Just seems odd to me. It may be valve springs or pushrods making it so peaky I don't know for sure. Just a stab from what I've seen with engines I have dynoed. I could be wrong ?????
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
