Velocity is an extremely important consideration. Agree about balancing factors in the combination. |
290's is enough for 10's, i went 11.50@117 in 4550 lbs... Ernie will do it!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
What gear?
I'm going to try and do it the hard way first!In decent air it would have went 11.1's..thats getting pretty close...and I've never expected to run 121/122...just the matter of getting to the track more..the 60's will come down a bit thinking 1.60's,still not leaving as clean and hard as it can.,testing this annular main body next..I have a small list of things to do this year..hopefully everything can get tested.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
More cfm may not be beneficial if the cam is too small for the head flow.
Has anyone tested this combo with a well adjusted q-jet?
If so what intake? And, Ernie what size headers? |
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
Cliff has ran a similar combo for years..
Don't know if it has been mentioned, but MPH will always be high when spinning off the line.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
Usually but not always true...Ok I will restate when we both were hooking he had a higher mph,when we both were spinning he had a higher mph..
Depends on the tire.
I have been running a Q Jet and a self ported RPM.
My best MPH is 122.3 with a 11:44 and spinning for 3-4 ft limited traction. Car has always ran flawless on the street and track. Have a T-2 and a Shaker(Jeff)) 455 4150 to bolt on very shortly. Im also trying to get the 60ft s down but im eager to see what the intake combo will do. |
It will definitely make more power!
And you will lose a little power before 3500-4000 with the T2 but that might help your car hook! Its Very Difficult getting near 600lb ft or torque and 550hp to hook out of the hole!! Ernies Car Would Pick up from a head swap especially if he had Dave do the 305 package on his heads, that plus bumping up the compression from 10.2:1 to at least 11.00:1, But on a combo like his you almost never want to trade low end power for top end power, there is a couple things you can do but not a whole lot with out moving the power higher in the RPM Range. I want to do a 501 or 523" cid engine with similar parts to see if i can get my Land Barge into the 10's, it wont be easy!
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
Question....why do yous guys run a 350 auto ..instead of the big brother 400 auto ?
I run a 350 because I've had decent luck..I've had one go a few years ago due to driver error,the last one held up pretty good no real issues..the current one is a Hughes with a low gear set.Also the 350's eat up a little less power,I can use the same crossmember and stock location,same driveshaft..
I'm running the T-350 because it came with the IA motor. It is a mystery trans because I got no information on it when I bought the car. It came with JW ultrabell, and was running low 10's, so I assume it was very well built. So far it has been flawless. I will be installing a cheater nitrous kit soon, so I am going to swap to a T-400. Trolling the web, it appears 800hp is the max the T350 is recommended for. I don't want to hurt it or the converter. The T400 may hurt ET a little, but I need the strength. May put the T350 up for sale here soon.
Its a crap shoot with transmissions, big torque and sticky tires will make u find the weak link. Sometimes its assembly or part failure.
My th 350 broke(carnage) one Friday night. Cant remember if Ernie was there? Sucks being on a flat bed with everyone watching. After the 140 tow bill i re evaluated . Went to the 400... |
I ordered a set of 3:73 gears yesterday. Still thinking about sending them back for a set of 4:10s. 3:08 doesn't cut the cake.
TA Man, I just read through all of this info about your low 11 sec ETs with this cool ride. Way to go, that's awesome performance
Congratulations TA Man !
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
