Old 04-07-2015, 11:15 AM
dci dci is offline
Originally Posted by Chris Uratchko View Post
That's awesome. There's more hp left too.
Agreed Chris, I see about another 40 HP there maybe a little more.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #322
Old 06-06-2015, 08:22 PM
Dragncar Dragncar is offline
The HO Racing 326 was a 1956 316 .060 out of a GMC armored truck because the block and crank were heavy duty. The shift point was 8500 and the red line was 9300. It had a Isky roller cam but the rockers were Pontiac RAIV as were the heads. They were ported by Craig. It had a custom stud girdle and Isky Vasco Jet triple springs. They never broke any engine part.
The car was a NHRA legal E/MP 65 Le Mans. 58 big Pontiac rear with 6.14 gears and had a M22 Muncie.
Must have been a blast.
If it was not for guys like the HO racing folks we would be in the same shape as Olds and Buick fans. Thanks.
  #323
Old 06-06-2015, 08:47 PM
Agree!
  #324
Old 06-07-2015, 06:13 AM
gavin gavin is offline
The M/T salt car was rumored to have cranks cast from nickel. The reason I bring this up is because a casting pattern for a flat crank would be quiet easy to make and simple in design. Perhaps a short stroke flat crank 3" or 3.5" in a 301 block could give intake and in particular exhaust tuning that could help.Smokey noted that a tempest 4cly engine made more HP per ci than the 421 sd with the same head and cam timing. This was most likely because of exhaust tuning as X design V8s tune as two v4s while a flat plain tunes as two inline 4s.While 180 degree headers get round that the tube lengths you end up with are too long for a high rpm engine.It may be that nickel is not strong enough for a big stoke engine but maybe ok for a short stoke with pin to mains overlap.Of course you then need a custom camshaft but that cost maybe moderated as you need a less exotic valve train for smaller lighter valves and shorter push rods ect.It wont win pro stock but it might come close to your HP to ci target.
  #325
Old 06-07-2015, 11:25 AM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by Glenn Sedig View Post
IA II block
473 cu
4.310 bore
4.050 stroke
6.800 alum rods
1.9 rocker ratio
1000 lb open spring pressure
All Tiger heads Port work by BES Racing 450 ish cfms 55cc chambers
7/16 push rods
Wenzler 2 X 4 intake manifold Port work by Vintage Mechanical Works per BES specs.
(2) 1150 Dominator carbs 102 main jets Q-16 fuel
Comp cams .995 lift 282 intake 300 exhaust @.050 4 - 7 swap
Headers built by Vintage Mechanical Works Step 1 1/4 dia to 1 3/8 dia
Great combination of parts and matching of the parts vs displacement.
Tom Vaught
  #326
Old 06-07-2015, 11:27 AM
Tom Vaught's Avatar
Boost Engineer
We like the Flat Crankshaft so well we put it into production:
https://media.ford.com/content/fordm...0-mustang.html
Tom V.
  #327
Old 01-22-2016, 03:10 PM
dci dci is offline
Bringing this back to the front for discussion. I need to see some creative thinking this time of year to keep my brain from freezing.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #328
Old 01-22-2016, 05:12 PM
Mike Davis's Avatar
Creative thinking---
send me a set of RAV to put on my 446CI motor with a 2x4 intake. I will supply headers, carbs and gaskets. See if it will take a 3700lb NSS car from 10.10 to 9.75.
Then I will get them approved in NMCA.
Hows that for creative?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #329
Old 01-23-2016, 02:50 PM
dci dci is offline
Mike I'm pretty sure my pump gas 455 with my RA5 heads will put you in the mid nines with a single 4. I like the way you're thinking though.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #330
Old 01-23-2016, 06:39 PM
Mike Davis's Avatar
Well that would be nice if I could run a single 4.
Rules limit me to either 3x2 Rochesters or Dual AFB's.
i have tried to get Holley's approved but no dice.
Included in my above offer is another free 30- 35 mile ride around Norwalk OH in my car----again--lol
421 CID
  #331
Old 01-25-2016, 11:24 AM
dci dci is offline
Does anyone have a formula that's accurate for determining CSA needed for different cubic inches, rpm, and or piston speed ? Also what wave should the intake and exhaust be tuned for to produce better than 100 % VE's ? Here is a good short article I found for some to get a basic understanding of what I'm talking about.
https://performancespecialties.wordp...system-tuning/
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #332
Old 01-25-2016, 12:08 PM
Stan Weiss's Avatar
Not to mention rotating weight. Things that need attention as well will be piston pin height, ring thickness, ring tension, how far up the piston the ring package will need to be. Crankshaft counter weights, bearing diameters, cam drives. The list is pretty lengthy at this level. That's why I thought it would make a good topic. As things are brought up, I would like to see each one get broken down and analyzed.
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Don,
Different head designs (like valve incline angle) will each want something a little different. So some empirical always helps. Also VE needed to be used in the CSA calculation. 7000 RPM @ 110 VE will see able the same needs as 7700 RPM @ 100 VE.
Stan
Pontiac Pump Gas List
  #333
Old 01-25-2016, 01:36 PM
dci dci is offline
Stan, do you have any formula's that can be used and edited for those parameters? I'm sure they are out there or dyno simulators couldn't be used.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #334
Old 01-25-2016, 01:49 PM
dci dci is offline
Here is some creative thinking I found. Notice the cfm increase in the different stages of porting.
https://www.facebook.com/photo.php?f...type=3&theater
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #335
Old 01-25-2016, 02:32 PM
Stan Weiss's Avatar
Don,
I sent you an email.
Stan
  #336
Old 01-25-2016, 02:35 PM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
dimples
  #337
Old 01-25-2016, 04:29 PM
I have a few calculators that might help:
Intake Runner and Peak Torque calc
Intake Mach Calc
Plus many others under the Head - Intake section here:
Automotive Calcs
Figure out what specific parameters wanted, I might be able to make one.
  #338
Old 01-26-2016, 05:53 PM
Glenn Sedig Glenn Sedig is offline
Default Opinions needed
IA II block
473 cu
4.310 bore
4.050 stroke
6.800 alum rods
1.9 rocker ratio
7/16 push rods
Headers built by Vintage Mechanical Works Step 2 1/4 dia to 2 3/8 dia
14.5 compression
1075.5 hp @7900 rpm
763.0 ft/lb trq @ 7100 rpm
With this combination (473 cubic inches, 3070 lbs) we qualified with a 8.491 et at 158.09 mph at Tom's Heads up race at Norwalk in 2015. Still not as fast as Picket's wagon. So was wondering if you guys have an opinion on the improvements I can gain with the following changes:
Dry sump
New custom built headers
Sheet metal intake
Seal hood scoop to the carburetor (Ram Air)
Thanks for the help
Glenn Sedig
  #339
Old 01-26-2016, 06:12 PM
Probably mis-typed?
What is the compression ratio?
Also what RPM range or peak HP?
That's some stout numbers already!
  #340
Old 01-26-2016, 06:47 PM
Probably mis-typed?
John,
I made the changes on post #338.
