Message sent. I found all of the distributor internals just need the front bumper and air cleaner stuff as well as the headlight trim rings.
Need a passenger side door window channel for a 62 Tempest lemans 2 door sport coupe. Mine is rusted out.
I also need a distributor hold down bracket for my 4 cylinder.
Andy 1962 Tempest Lemans 4 cyl auto 1967 Camaro 1969 C/10 1969 D300 1972 K/5 1974 'Cuda 2005 2500HD Duramax |
I am looking for a park cable for a 63 LeMans.
Thank you |
Dash or floor shifter?
Parts for sale!!! [email protected] https://www.facebook.com/groups/Dave...acStuffForSale |
did you find a parking brake cable? I have it from the pedal assm back to the rear axle but nothing to the rear wheels.
Robin
Robin Triplett Midwest Director of the Little Indians Club 417-456-9858 cell 63 Lemans convt. Present 1970 350 Firebird motor built to 69 350 HO specs Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals) 700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup 65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8") |
WTB complete signal light switch for 63 Lemans.
They did not make a 2bbl 4cyc intake.1bbl and 4 bbl.Tom
Looking for a new or like new pitman arm for a manual steering 62 Lemans
Wayne 918-697-6965
Pump gas and hydraulic cams are for minivans..... ![]() www.smotherssupercars.com Check out my Performance Engine Building and Carburetor Tuning DVD......... |
These are sometimes on ebay but for the most part hard to come by.
Several good places, amesperf.com or rareparts.com Note that rareparts.com will rebuild your existing one. You box it up and ship to them, they rebuild and send it back in about 10 days. |
Looking for a V8 cross member
Sent from my SM-G998U using Tapatalk |
WTB Stainless windshield trim for gasket style window. 63 sport coupe.
Same as any pontiac V8,available from our sponsor.Tom
Thanks Tom!:
Floor but I am told I could use a dash one if I coil it.
Thank you, Pat |
Looking for a 63 Tempest coupe taillight panel. Located in NW Ohio and can pick one up at Norwalk if you are willing to bring one. May consider just the RH half.
Thanks, Todd
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
In need of a 63 lemans flex plate and bell housing. Automatic application. My flywheel is stamped steel not a cast iron flywheel. "Flex plate" I have been having starter issues since purchase. I have had 2 OEM starters and two aftermarket torque drive starters and all have chewed up the gear on the starter and flex plate. I talked to a local re-builder that told me to check the clearance between the flex plate and flywheel gear and the measurement is no where close. He said since there is no way to shim the starter on a bell mounted starter I need to try a different bell housing. And since, now, my flywheel teeth are chewed up he told me to source another flywheel/flex plate as well.
If you built it, drive it. red 62 Tempest total stock restoration. white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train. |
Its a 326
Still in need for bell and flexplate 326 auto in 63 lemans. Car is now DOA and can not be driven. Willing to pay appropriately for these parts.
