Old 09-21-2023, 10:27 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default Manulal Trans Pinion
I have this pinion for a 3 or 4 speed. This came in a car years back that was converted to an auto trans.
$50 plus shipping
  #342
Old 10-28-2023, 08:37 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Default Delivery Possible
Hood 700
Valance 300
Engine 500
Radiator 100
Bell 20
Delivery possible along pictured route.
ID:	622407   Click image for larger version
ID:	622408   Click image for larger version
ID:	622409   Click image for larger version
ID:	622410   Click image for larger version
  #343
Old 10-28-2023, 08:39 PM
63Banshee's Avatar
Originally Posted by 63Banshee View Post
Hood 700
Valance 300
Engine 500
Radiator 100
Bell 20
Additional pictures.
ID:	622412   Click image for larger version
ID:	622413   Click image for larger version
ID:	622414   Click image for larger version
  #344
Old 10-28-2023, 10:55 PM
Sanduners's Avatar
I'm in for the bell, I'll email you.
  #345
Old 10-30-2023, 01:53 PM
63Banshee's Avatar
Haven't seen anything come in yet.
  #346
Old 11-01-2023, 11:21 PM
Sanduners's Avatar
Sorry Dave, it would help if I used your correct email address. Sent.
I have 2 distributors available. The part numbers are 1111020 and 1111039.
1963 326 2bbl 1111020 AT and MT
1962 P/8 421 HO 1111039 except TI
1963 P/8 421 HO 1111039 except TI
1963 T/8 1111039 -EXC TI
1964 T/8 1111039 except GTO
1964 P/8 421 HO 1111039 except TI
$50 each plus shipping
ID:	622690   Click image for larger version
  #347
Old 11-10-2023, 02:04 PM
tekuhn tekuhn is offline
Default Offenhauser Dual Quad Intake #5499 ('65 and later heads)
I have an Offenhauser #5499 dual quad intake manifold for 1965 and newer heads for sale. It is in excellent almost new condition with nearly no pitting from water corrosion. The ports are untouched. It accepts WCFB carbs directly and includes the adapters for AFB-style carbs. I have removed the exhaust heat crossover and had a piece of aluminum bar-stock milled to the same thickness as the manifold flange to make block-off plates from. They just need to be cut out. I would do it, but don't have access to a band saw which is the easiest/best way to do it. The ports on one side have been marked with a Sharpie for a gasket match to a Ram Air IV flange but have not been cut. There is a small notch on the outside of the manifold that's ground into the #1 intake port that I assume was made for linkage clearance. It is shown in the first picture. There are new gaskets under the adapter plates. Asking $350 and will ship to lower 48 for $25. Located in East Texas. Limited to 5 pictures but can provide more upon request.
ID:	623112   Click image for larger version
ID:	623113   Click image for larger version
ID:	623114   Click image for larger version
ID:	623118   Click image for larger version
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures
  #348
Old 11-15-2023, 10:28 AM
Item is also listed on eBay - I received a bid, so I must now let the auction run it's course:
https://www.ebay.com/itm/235295777432
  #349
Old 12-02-2023, 12:18 AM
Sanduners's Avatar
Default 1963 Convertible RH Door
I have a 63 passenger door available. Has a dent and some rust but overall in great condition. $125 plus shipping.
ID:	624174   Click image for larger version
ID:	624175   Click image for larger version
ID:	624176   Click image for larger version
ID:	624177   Click image for larger version
The Following User Says Thank You to Sanduners For This Useful Post:
  #350
Old 01-08-2024, 12:55 PM
CatalinaWMixxer's Avatar
CatalinaWMixxer CatalinaWMixxer is offline
Default 1963 Doghouse for sale
My front end was year incorrect when I purchased the car (mines a number matching 64, with a 63 front end). So I’m selling the 1963 Catalina hood, both front fenders, front bumper and grill.
I’m located in La Porte, IN. I’m willing to travel within reason. Not all images fit in the upload. You are more than welcome to text me with offers or call 219-814-3504.
ID:	626221   Click image for larger version
ID:	626222   Click image for larger version
ID:	626223   Click image for larger version
ID:	626224   Click image for larger version
  #351
Old 01-09-2024, 04:04 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Just to let you know this is the Tempest Lemans forum. There's a different section to list big car parts. You'll have better luck there.
The Following User Says Thank You to hobbygto65 For This Useful Post:
  #352
Old 05-21-2025, 11:15 PM
rdtripn_rte66 rdtripn_rte66 is offline
I have all kinds of parts for sale for the 63 Tempest/ Lemans cars. Contact me here or my cell phone is listed as well. I am on Fb also. May be parting out the 63 Lemans HT w 14 options if there's enough interest. I also have a 421 HO block and O heads, 63 Tripower unit completely restored by Mike Wasson of pontiactripowers.com a couple 326/336 blocks PS, PB, auto floor shifter other body parts coming off this HT. Let me know - can deliver to Norwalk. Want to restore this HT- I'll make a deal. It's posted on the forums.
Thanks-
Robin Triplett
Midwest Director of the Little Indians Club
417-456-9858 cell
63 Lemans convt. Present
1970 350 Firebird motor built to 69 350 HO specs
Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals)
700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup
65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8")
  #353
Old 07-17-2025, 08:12 AM
PLongen PLongen is offline
Looking to replace my 4cylinder to v8 what do you have to complete this?
Thank you
Pat
  #354
Old 07-17-2025, 09:02 AM
firefour1 firefour1 is offline
Hi Pat,
The easiest way to upgrade to a V8 is to find a parts car that came with this engine combination:
1. Engine, will want to use the front cross member and associated motor mounts from the V8 car. Also will need the flywheel, bellhousing, starter, alternator, and power steering brackets from the V8 Car.
2. Torque tube, the diameter is different, meant to handle the extra torque
3. Transmission:
a. If a manual, can only use the 3 speed which was derived from a larger car Borg Warner design. The 4 speed which came from an earlier Corvair design isn't robust enough to handle the torque.
b. If an automatic, the 4 cylinder powerglide has a smaller clutch pack and won't handle the V8's torque. Would need to use the transmission from the V8 car
c. Transaxle, the drive ratio needs to be different in the V8 car as the torque and power is greater which means you'll need to change this as well.
As you can see, it's a major undertaking which may be worth it depending on how much you enjoy the car and how much benefit you'd get from the increase power and drivability.
Let us know what you eventually decide.
  #355
Old 07-17-2026, 08:34 AM
I have a complete carb to pan 1963 326/336 for sale, will need rebuild. $100
