| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
Since I moved the Lemans into the basement today, I decided to start a thread to document the project. I purchased the Lemans through eBay in April. The car was located about 80 miles from my house so I was able to inspect the car before I bid on it. The condition of the car while not great is also not that bad. The car spent most of its life in a garage, however the shelf between the rear window and the trunk is rusted and there is rust on the quarter panels under the vinyl roof. I am worried about the roof, but until I pull the vinyl I won't know. The floor pan and the trunk floor are not rusted. I purchased the car without an engine. The eBay seller bought the car only for the engine block (matching numbers) for a 68 firebird project he was working on. It looks like the fenders and hood was removed since a number of bolts are missing and nothing comes close to aligning and there are no alignment shims.
EBay Picture - This is before the seller removed the engine and the front end. Why the hood and fenders were painted green with a spray can I don't know. Under the green is the same shade of red. ![]() My plans are to restore the car to have a stock appearing interior and exterior with improvemnets that would not stand out. For the interior I plan on using a radio that supports USB/MP3. No need for CD now that 16GB memory sticks are available. I plan to add power windows, power door locks (electric) and 6 way power seats for both the driver and passenger side, cruise control and a rear view mirror with temperature/compass readout. Other updates include a tilt steering column and a Hurst dual-gate shifter with the mod that supports the 4L60. I plan on using the stock 68 guages and tach. Exterior Upgrades - I have a GTO hood, GTO tail lights, and Enduro Bumper and hidden head lights to install. My goal for this project is to create a car that could be used as a daily driver with good street manners. I'm not looking to make this a race only car or have a rock hard ride. If I want that I can drive my 06 GTO. That said I do want to improve the handling over the stock 68 suspension. Perhaps my 06 GTO was modified by its former owner, since its ride is bone jarring and hard cornering produces no body roll. I don't want my Lemans suspension to become like that of my 06 GTO. I want it to be somewhere in between. |
Dragging the car into the basement.
![]() I plan on installing the engine and transmission before I do the restoration work. After sorting out the swap problems and making sure the engine and transmisiion are fine, I plan to remove the engine and do a body off frame restoration. And the LS3 engine.
Nice! Good luck on the project. There are two threads that can help you along the way.
Andrew |
I took a few hour today and pulled the front end. It's clear that the front end had been removed since bolts were either missing or loose. Total time to remove the front end was slightly more than two hours.
![]() Major parts that I have for this are: GM LS3 crate engine 430HP 4L70E (Has shipped, due next week) Speartech Harness and computer Edelbrock Engine swap mounts LS series gas tank - Rick's Hot Rod Shop Autokraft Oil Pan Radiator with electric fans ![]() Although I have quite a bit of the suspension/front end parts, i'm not going to install any of them until after getting the engine installed and running. I have Global West tubular Negative Roll A-arms. These arms use a b-body spindle and rotors or 1LE rotors (5-4.75 instead of the b-body 5-5). I don't yet know what coil springs to order. I probably need to wait until I get the engine installed. Then I can weight the car. I am guessing that the car will loose between 200 and 300 pounds when completed. I have orderd Pontiac Rallye II, Steel, Chrome, 16 in.x 7 Wheel Vintiques from Summit. These have been on back order for almost 3 months. Although I wanted the 8" wide wheel the quoted time on the 8" wide wheels was summer 09. I plan on running 255/50/16 on the rear. I'm not sure what will fit the front. |
Ideally a 8" rim would be my choice but Wheel Vintiques appears to have no interest in making them although they appear in their catalog. However my 7" wide wheels are now 5 weeks over due and no longer have a estimated delivery date. I didn't want 15" wheels since almost every tire I find has only a S or T speed rating. There are many tires available for 16" wheels with Z or W speed rating. As to fitting a 255/50/16 on the 7" wide rim, every tire that I looked at stated wheels with a 7-9" range. One of my thoughts was to use 245/50/16's front and rear. My brake/suspension upgrade is now in limbo since discs are not going to work with the 14" wheels that are now on the car. I want a Ralley II type of wheel and not an aftermarket wheel. The 17" Wheel Vintiques Ralley II wheels doesn't really look like a Pontiac wheel and a set of them would be more than $2000. It looks like I'm SOL on the wheels at the moment.
fbrown, did you have a chance to test fit the engine yet? Im about to test fit my 04 gto engine trans in my 70 lemans sport. I have the brp mounts but im wondering if the edelbrock long tube headers are going to fit with the engine sitting higher. I will post some pics soon.
Nice project. One I hope to take on for a 69.
does anyone know of or have pictures of a late model dash installed in an A-body? I know it is real common among F-bodies. John |
Looks like you have a good start. I have a similar project. A 68 LeMans with LS1/4L60E, a Firebird dash, wiring, gauges and center console. One of these days it will be finished. Right now it's out getting rear quarters and outer wheelouses installed. It had LOTS of rust, so it has been a long haul (Damn Ohio winters). There's a link to the build pics in my sig. Any questions, just ask.
http://s118.photobucket.com/albums/o...view=slideshow Tony
1998 GOLD Pontiac Firebird Formula HT, M6 1968 Pontiac LeMans Convertible 1968 Pontiac Lemans HT - Frame-off restomod with LS1 transplant 1955 Pontiac Chieftain - 2 Dr Wagon - Newest project 2008 Chevy Silverado 4X4 - Daily driver |
Tony-
Looks great in there. How wide is the space and how wide is the dash? I thought maybe a full size truck dash might work too. John |
Cool project, doing the same with my 70 lemans sport. Are the edelbrock engine mounts beter than the brp mounts? I was going to use there mounts and crossmember.
The BRP mounts require you to figure out where to mount the engine by trial and error and then either drill holes or weld the mounts in. It does not bolt to your existing holes. I didn't know this until after I received their kit and decided that using the BRP would take too much effort to install. BTW I have the BRP mounts and crossmember. PM me if you want to purchase.
Thanks for the info. So if the edelbrock mounts use the existing holes in the frame, do they make a crossmember for the trans also? what are you thinking about using? Do you have to cut the frame to make the engine fit with these mounts? Ive seen people have to do this.
Edelbrock does not make a crossmember. I think it is possible to move the stock crossmember and re-drill the frame. Information about crossmembers for automatic A-body conversions seems scarce since almost all of the conversions I have read about used a manual transmission. The down side of the Edelbrock engine mounts is that you need to relocate the AC compressor or notch the frame. At least this is what most people say. I will be doing a test fit soon. (When my 4L70E arrives) You are able to keep the AC in the stock location with the BRP kit. The BRP kit will also allow you to use a less expensive oil pan.
As soon as my transmission arrives I will find out about relocating the stock crossmember. |
That might be okay, I'd play that by ear.
Looks like things are moving right along.
The minor dent in the header tube is a non-issue as far as any reduction in flow is concerned. The door gap can be adjusted out for the most part, but these old warriors do have some pretty big gaps compared to the superior fit of the body panels on the newer cars. Just wait until you get that endura front bumper aligned, the gaps are always big on those. Could you please share the part number of the serpentine belt you found that works? Did you have to change any of the pulley sizes like you thought you might need to do? Thanks, Bart |
Belt - Gates - K061010 13/16" x 101 5/8"
No changes were made to the GM supplied parts, other than the Kwik AC bracket. Perhaps the belt listed in the Kwik sheet correct if you use both their AC and ALT brackets. |
How many pounds less will this car be when it's done? With only the aftermarket hood, bumper and battery left to install this car is almost on the upper stops. With me standing on the front frame it only goes down maybe 1/2". ( I weight 225)
This makes me think I would need custom made springs for the front. It would appear none of the standard Pontiac springs would work. I guess I could start cutting coils off the spring to get the height down. How much did the Pontiac 350-2V weight?
I bet you are saving at least 200 pounds compared to the Pontiac engine. Maybe even 300 if it had iron heads and intake.
What upper radiator hose did you use? Did it have 1.5" opening on the radiator side and 1.25" on the engine side? Andrew |
Upper hose is Dayco 71132, 1.5" radiator, 1.25" engine.
The original engine was all steel and an AC car. EBAY pictures showed that it had a normal ride height before the engine was removed. I may have cut 400 pounds off the weight of the car. Other weight reduction items are new core support, hood, power steering box, radiator, fan shroud removal. My guess is the 4L70E is lighter than the powerglide I removed. (at least my back thought so) |
