Old 10-06-2014, 06:59 PM
heater63's Avatar
heater63 heater63 is offline
Default a work in progress, but coming around
Been working on this one on and off for the past year. In paint and going back together. there was more damage then I originally thought to both quarters but was able to straighten the passenger side and had a usable quarter to cut a patch out of from her old black car. Will post more pick once it is together and outside.
here is the original post of this car.
http://forums.maxperformanceinc.com/...t=bargain+year
"If you aren't first, your last." Ricky Bobby 2006
Old 10-18-2014, 07:04 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Classic Exhaust kit
Working on the Lemans convertible, today. The dual exhaust kit is in place via jack stands until hangers and clamps are figured out. The kit from Classic Exhaust is 2 1/4" from the exhaust manifolds to the mufflers and 2" out of the mufflers to the tail pipes. The kit uses the stock hanger locations. The mufflers are right and left sided and can't be switched. Adjustable jack stands make the install fairly easy to mock up.
ID:	379244   Click image for larger version
ID:	379245   Click image for larger version
ID:	379246   Click image for larger version
Old 10-18-2014, 10:51 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
I would also be interested in hearing about the details of others dual exhaust system. I am overdue for a new system and was planning to have it done this past summer. I now have both pipes running parallel under the passenger side floor into a pair of glasspacks and dumping straight down in front of the axle (previous owner installed). I would like to have the tailpipes exiting at each side out the back like in the pictures c5farmer posted. I have the clutch linkage and shifter rod to deal with on the drivers side so the layout like in the pictures works for me but I have to agree with Radman about the pipe curving over the swing axles. Anybody got a map of the layout of how the dual exhausts left the factory?
Old 10-19-2014, 12:21 PM
c5farmer's Avatar
Default factory exhaust system
Here is the '63 dual exhaust system per the factory parts book. It looks like the tail pipes are under the axle.
ID:	379285   Click image for larger version
Old 10-19-2014, 07:53 PM
heater63's Avatar
Jerry, I have 2 1/2" exhaust on my car. It was made custom so there isn't a part number I can give you. I have had zero problems with bottoming out for 3 years now.
Old 10-22-2014, 09:40 AM
c5farmer's Avatar
Default Finished Project
Well, it is finally done after 3 years of work. Yesterday the exhaust system was installed and the stock valve covers replaced with MT covers. Susan drove the car around the block and everything worked! Now, all the new car bugs can get sorted out as it gets more some road miles. As many original parts as possible were used after cleaning and /or rebuilding. It is not a competitive show car, be we think it turned out pretty well for a "home made" restoration and look forward to cruising next summer.
The next project is an engine replacement for the 63 Tempest hot rod. It runs fine, just needs more power! Nothing a blown 455 can't fix!
ID:	379564   Click image for larger version
ID:	379565   Click image for larger version
ID:	379566   Click image for larger version
Old 10-22-2014, 09:48 AM
c5farmer's Avatar
Default Finished Project 2
More pictures. What a feeling of accomplishment.
ID:	379568   Click image for larger version
ID:	379569   Click image for larger version
ID:	379570   Click image for larger version
ID:	379571   Click image for larger version
Old 10-22-2014, 09:49 AM
Transporter Transporter is offline
Hey Jerry, it turned out great best of luck to you and Susan with it!
Stan
Old 09-08-2015, 11:47 PM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
Awesome!... looking forward to seeing it at Norwalk maybe someday!?
Old 09-09-2015, 06:51 PM
indiantony indiantony is offline
Could you post a picture of the notches in the crossmember? Im thinking of getting a set of those manifolds. Thanks
Tony
Old 09-10-2015, 06:50 PM
c5farmer's Avatar
Default xmember notches for RARE 2.5" manifolds
The only area that really needed notched was at the bottom of the cross member where the side and bottom meet on the driver side. The engine has to be postioned as far back as the motor mounts and tranny cross member allow. I even added some space with a die grinder at the back of the crossmember/engine mount slots. Hope this helps.
ID:	407837   Click image for larger version
Old 10-12-2015, 12:06 PM
ahnuld's Avatar
ahnuld ahnuld is offline
Default New autogear m22w in car now
New autogear m22w in car now. Love it
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
Old 10-12-2015, 01:17 PM
c5farmer's Avatar
Default m22w
Is the gearing the same as a muncie m22? Bet it is smooth shifting!
Old 05-08-2017, 11:42 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Boy have you been busy! I hope my trans looks that good when I get to it. Thanks for sharing Mike.
Old 05-08-2017, 03:20 PM
AzMike AzMike is offline
For the last few months I have been going through all the systems of my 63 convertible to get it ready to pull the motor and interior for a new paint job.
Here are a few pics of the progress.
Old 10-12-2015, 11:01 PM
ahnuld's Avatar
Yep basically the same. It shifts so nice now. Loud as hell with engine alone never mind the whine of gears on top of it. Love it. Gonna take it to track in spring for sure.
Old 11-04-2015, 04:01 PM
tom s tom s is offline
As some know I bought a garage find 63 tempest conver 4 cyc 3 speed car.Just got paint on yesterday.They will color sand and polish tomorrow and will be home friday to start putting back together.
ID:	412240   Click image for larger version
ID:	412241   Click image for larger version
ID:	412242   Click image for larger version
ID:	412243   Click image for larger version
Old 11-04-2015, 07:31 PM
c5farmer's Avatar
Default Looks Great
Tom, The garage find looks smooth and bright. You will have quite the looker when it is assembled. The color is one I don't see very often and is original to the car. Like the 3 speed manual/195 ci combo.
Old 01-31-2018, 11:52 PM
Deadendcustoms79 Deadendcustoms79 is offline
Default 1963 tempest 4dr
Another pic of driver side floor
Old 02-02-2018, 01:44 PM
blueghoast's Avatar
Default 4-door Tempest
Is there more info on this Tempest?
Is that a lenco or are my eyes playing tricks on me.
Floors look great by the way. More pics.
GT.
